Leaf based Rock Crawler
Posted: Sat Mar 16, 2024 7:43 pm
Hello,
I currently have a rock crawler that has the EM57 Leaf motor. The build is on instagram @wamort. A Thunderstruck CAN controller is currently used. I am trying to reduce the rate of torque increase by changing the "accellim" value which has helped but the motor becomes unstable if you reduce the value too low so I am thinking about using the replacement board.
My question deals with the openinverter replacement board. I am assuming the board has a setting that will reduce the rate at which torque is produced.
What would one adjust to reduce the rate of torque on the openinverter board and is there a practical limit to how low you can go? Any help would be appreciated.
