Inverter GS450H 2006 Question
Posted: Sun Mar 10, 2024 2:28 pm
by gs450h
Hello,
i was browsing the internet and found this forum, there are a lot off people here with great knowledge with inverters and hybrid systems and i was wondering if someone could help me out.
I own a Lexus GS450H from 2006 with the G9200-30040 Inverter, a couple a days ago my son was driving it and it suddenly stopped and showd the Dreaded "Check hybris Systems" i can do a lot myself , i own a computerrepairshop for almost 15 years now and i used to drive Alfa romeo so i am capable of some diagnostics and work.
The car gives me a p0A1B code wich leads me to believe the inverter is faulty after some searching on the internet, i checked with techstream and i can not communicate with the module. I tried to clear the codes but that does not work, so i diconnected the batteries and tried to open the inverter up to see iff i have a burned board or something , the inverter is still in the car and i opened the lid to see but everything seems fine no burned components and no smell from it.
From browsing youre forums i believe the G9200-30040 is succeded by the G9200-30061 and the parts should be interchangeble, can someone confirm this . Am i able to swap the 30040 with the 30061 without reprogamming stuff , because the 30061 is a bit easier to get than the 30040 and also a bit cheaper.
Sorry for my poor English but it is not my native language.
Thanks in Advance, greetings Dave
Re: Inverter GS450H 2006 Question
Posted: Mon Sep 16, 2024 11:43 am
by dadiowe
If you go to this page, https://openinverter.org/wiki/Category:Toyota you will see a list of inverter part numbers that should help.
