Battery advice
Posted: Sat Mar 02, 2024 6:37 pm
My front BMS was giving some odd readings so i thought for safety i'd pull the pack and check things out with a meter. Good job i did as clearly the suspect module on the BMS that was previously not working at all, has now woken up and decided fiction is the way forward. Gave me a fright as it erroneously reported one cell at 4.4v and another at 2.8
So I have 330e battery, 96s across 6 modules, so i took a meter to each cell in each module and also measured the overall module voltage.
What i see is that within each 16s module the voltages are pretty even , but across the modules there is a 2.6v difference.
What is the best course of action here:-
1) not worry about it, it's a small difference
2) try and balance the modules to better match ?
why do the packs get like this, especially given as all the time they're join in parallel to another 96s pack so one would think they would even out ?
If balancing is the way to go, i can either discharge the high ones to meet the low (not sure how), or charge all to the same level. I have a 60v charger that came with an electric scooter than had lead acid batteries in it, i could apply that to each module in turn and they ought to end up even ?
thanks
thanks
