Driving with canbus
Posted: Tue Feb 27, 2024 10:02 pm
by medo
Can someone give an example of how I start the inverter via canbus, or switch the direction D N R, would like to install a nextion display, which I use to control the whole thing??
Re: Driving with canbus
Posted: Wed Feb 28, 2024 7:23 am
You need to read and understand this https://openinverter.org/wiki/CAN_communication
Start signal starts, forward/reverse selects direction
Posted: Wed Feb 28, 2024 4:11 pm
by medo
This no longer works starting v5.32.R! See above!
So it no longer works that you can start the drive direction or the inverter via canbus???
Posted: Wed Feb 28, 2024 7:15 pm
Yes it does. Read again ;)
Posted: Wed Feb 28, 2024 8:16 pm
by medo
oh my god, wenn das nur auf Deutsch wäre :-)
Posted: Wed Feb 28, 2024 8:38 pm
https://openinverter-org.translate.goog ... r_pto=wapp
It's a bit over-translated :D Cruise=Kreuzfahrt
Posted: Thu Feb 29, 2024 4:27 am
by Bratitude
Now with throttle pre defined,
Is controlling an inverter board via a zombieverter over can as simple as setting control to can and that’s it?
Posted: Thu Feb 29, 2024 8:02 am
I'm guessing by now someone has implemented it on the Zombie side. On the inverter side no mapping is needed, only can speed needs to match
