SDU/FDU Logic board not closing pre-charge relay with 12V IGN on
Posted: Sun Feb 25, 2024 7:25 am
by redman
Hello Everyone,
New to the forums and my first post. Looking for help with an SDU/FDU V7 logic board. That I have purchased fully assembled.
Doing everything that I can to stay safe and not let the smoke out of anything. I fully understand the need for pre-charging. However the pre-charge relay will not close once I apply the 12 IGN on signal. The pre-charge pin/cable from the logic board stays high. Therefore I get a "500 Pre-charge error-stop" due to the 5 sec limit.
I am using two EV200AAANA one as the main contactor and the pre-charge reply.
Should I be using a N/C relay for the pre charge? Then once the required voltage is meet the logic board will open the relay?
Re: SDU/FDU Logic board not closing pre-charge relay with 12V IGN on
Posted: Sun Feb 25, 2024 8:20 am
Can you measure the gate voltage of IC11? (voltage between left pin and right pin)
redman wrote: ↑Sun Feb 25, 2024 7:25 am
No. When the car is off then precharge is always on...
In fact I don't use the precharge output of the inverter at all, I just leave the precharge relay closed whenever ignition is on.
Posted: Sun Feb 25, 2024 2:12 pm
by redman
johu wrote: ↑Sun Feb 25, 2024 8:20 am
Hello John,
First off. Thank you for your quick response.
I have already put everything back into the motor inverter housing. Can I run the PCB on a bench power supply to get you that gate voltage reading?
Before I pull the PCB back out. If I simply trigger the precharge relay and leave it closed like you say. I should get the motor to respond if everything else it fine correct?
Posted: Sun Feb 25, 2024 4:17 pm
redman wrote: ↑Sun Feb 25, 2024 2:12 pm
I don't know enough to answer this for sure but if only the mosfet is broken then yes, you can still run the motor
Posted: Mon Feb 26, 2024 12:11 pm
by redman
johu wrote: ↑Sun Feb 25, 2024 4:17 pm
Hello Johu,
After your suggestion to lock the pre_charge relay at power up. I proceeded to attempt to complete the motor drive sequence. I noticed the pre-charge error went away. However now the main contactor was not triggering even though the system says ready to run.
I disassembled the inverter and checked between the two pins as suggested. I got zero volts. I then tested to see if the IC was shorted. It check good. I then checked IC 9 next to is same thing. So I decided to check continuity from the heat sink out to end of the pig tail. Nothing. I pulled the pre made harness and found no continuity on ground, pre_charge, main and forward wires. From the connector out to the pig tail end.
At this point I need to get my harness issues resolved before I go further.
I have reach out to the seller of the harness regarding the matter. Keep everyone posted.
Posted: Sat Mar 02, 2024 4:06 pm
by redman
The seller of the harness. Promptly shipped out a replacement for me. Installed it and everything works as intended. I am very happy with the service that I have received from this seller. They have been very helpful.
Now just need to figure out how to get regen working. I am using a Hall Effect Potentiometer for my accelerator.
Posted: Sat Mar 02, 2024 4:29 pm
Nice to hear.
Maybe this long and boring video is helpful for figuring out regen and other things
