Page 1 of 7
[DRIVING] leaf powered 1983 Subaru BRAT (dual outlander WIP)
Posted: Thu Jan 02, 2020 8:36 pm
by Bratitude
Been collecting parts and lurking here for long enough I might as well start a build thread.
converting a lifted 1983 Subaru BRAT on a sudo budget
So far I have;
Gen2 leaf motor +inverter+charger/jb 750$ cad
Gen2 chevy volt battery (18kwh)1000$ cad
Gen2 Tesla slave charger 600$ cad
2015 Tesla dcdc converter 245$ cad
Volt wiring/ j1772 plug 130$ cad
Goal is to get this thing driving under 5k
plan, stage 1:
Coupler:
direct coupling from the motor to the brat’s 4spd d/r trany. I have connections to a few machinest, so I’m handing over the leaf motor to them to figure out the splines and mill a coupler. Hopefully all goes well and I can provide spline data on the leaf motor.
Inverter:
CAN control over the inverter using celerons and Damien’s work. Arduino due + can transceiver
Charger:
Damien’s drop in board for the Tesla Gen2 slave charger.
I can get some of the Tesla HV wiring and HVJB for 175 cad, not sure if I really need it at this point. Would like to implement CCS or chademo in the future. Thoughts?
BMS:
For the bms system I’m thinking of rewiring a gen1 volt bms to my Gen2 volt battery and using simpbms.
contractors:
Being the volt battery has the hv contractors/precharge unit built in, and I have all the cables, I’m thinking of just reusing it with a secondary relay control board.
2 Panasonic 120amp 400v contractors. possibly a bit on the small side?
* update 2023/08/24
-3 out of 4 standard ranger M3 batteries (72s)
-leaf motor direct drive to 4wd gearbox
-openinverter replacement brain board
-tesla model s dcdc
-tesla model s obc
-volt ibooster
currently my only vehicle. i daily drive it. 60-70% of the time its off road (on logging roads, etc) its seen a lot of abuse!
Re: Leaf powerd lifted Subaru BRAT
Posted: Thu Jan 02, 2020 10:20 pm
by Kevin Sharpe
Bratitude wrote: ↑Thu Jan 02, 2020 8:36 pm
The Model S/X HVJB is a very convenient way of wiring HV connections at low cost. If you can get the HV wiring then you have halved the number of HV terminations you need to make. Also offers very simple upgrade if you decide to add second 10kW charger in the future.
Both CCS and CHAdeMO will use an external controller. CCS using the Tesla Model 3 charge port ECU will be featured on the Super Yacht in a few months. CHAdeMO hardware is on the Gen 2 V4 charger boards but currently awaiting software support.
They won't last... remember the Leaf motor can produce more than 300HP
Posted: Fri Jan 03, 2020 12:10 am
by MattsAwesomeStuff
Share your secrets, witch!
Posted: Fri Jan 03, 2020 2:52 am
by Bratitude
Kevin Sharpe wrote: ↑Thu Jan 02, 2020 10:20 pm
Hmm plus the ease of single-3phase input switching/integrating dc fast charging
right, there’s the early work of Collin kiddler with some recent updates could put together, but I’m interested in seeing what you guys come up with for the Gen2 v4 board/ ccs with the tesla unit.
Now the leaf motor, yes been pushed to 305hp (with no signs overheating?)with a custom inverter.
Looking at some of the performance graphs, torque drops off around 2800rpm with the stock inverter +vcm. Now is the vcm throttling toque back or is the inverter?
Keeping the torque threw the rev rang and we should see upwards of 200hp+.
if it’s just the vcm, then I’m looking at contractor upgrades
Posted: Fri Jan 03, 2020 8:34 am
by celeron55
The gen2 leaf inverter factory software does the limiting to 250Nm and 80kW. (and 80kW means full torque to 2800rpm)
Posted: Fri Jan 03, 2020 11:46 am
by Kevin Sharpe
Bratitude wrote: ↑Fri Jan 03, 2020 2:52 am
None of this functionality has been implemented and it's unlikely given availability of low cost Model 3 parts and 350kW CCS chargers.
Lots news about Gen 2 charger boards in the next few days
Don't take any risks here... welding a contactor closed could result in serious injury
Posted: Thu Jan 23, 2020 10:41 pm
by Bratitude
I have all of the main parts now, and some time off
First off:
Tesla model s dcdc convert, supply it with 12v to the enable pin/case ground and it starts spitting out 13.5v!
- All pins inside the dcdc convert labeled :)
Established can communication between the Arduino due and the gen 2 leaf inverter.
Posted: Fri Jan 24, 2020 8:06 am
Bratitude wrote: ↑Thu Jan 23, 2020 10:41 pm
First off:
Can you post Tesla DCDC details with pinout diagram on car conversion hardware section?
This is a good info.
viewtopic.php?f=9&t=335
tnx
Posted: Fri Jan 24, 2020 5:54 pm
by Bratitude
arber333 wrote: ↑Fri Jan 24, 2020 8:06 am
tnx
Will do, although a wiki would be much more organized. Is the open inverter wiki an appropriate spot as well?
Posted: Fri Jan 24, 2020 8:04 pm
Bratitude wrote: ↑Fri Jan 24, 2020 5:54 pm
tnx
For sure! Lets organize a Wiki page dedicated to EV hardware and its hijacking. Maybe main page as TOC and the rest inside its tree.
Posted: Tue Jan 28, 2020 9:00 pm
by Bratitude
leaf motor now spinning with throttle and brake inputs
Next, moved on to cleaning up all the oem parts and wire harness’s I’m going to use.
Being that I have a gen2 Chevy volt battery, and there’s no real good data on interfacing with it, I picked up a gen 1 bms.
I ordered 9 connectors that fit into the Chevy volt gen 1 bms and the the pins.
Part numbers:
ATLPB-21-2CD
SAIT-A02GF-M064
2 of the 9 connectors on the bms have a slightly different slot pattern, couldn’t find what part number they are so I plan on just shaving 2 of the new connectors down a bit.
Striped the gen2 bms loom and got the battery side connectors.
I have the pinout data on the battery side of gen 1, but not the bms side.
Anyone have the gen1 bms side pinout info?
Looks like every bms-to-battery connections is the same (expect the 2 different slotted connectors) on the gen1.
Posted: Tue Jan 28, 2020 9:24 pm
https://github.com/tomdebree/AmperaBatt ... slaves.pdf
This pdf should have all of the conenctors I believe.
Posted: Mon Feb 10, 2020 5:12 pm
by Bratitude
Still working on the actual splines but here’s what I have so far, this is a snug fit on to a gen 2 leaf motor. Mates with a rotex gs 38 coupler
https://github.com/angusjo/leaf-splines ... upler1.STL
Posted: Mon Feb 10, 2020 8:14 pm
by Igor
Looks great. Looking forward to more progress!
Posted: Tue Feb 11, 2020 2:58 pm
by JaniK
Great work on the coupler.
Good stuff found daily on openinverter.org forums
Posted: Tue Feb 11, 2020 6:53 pm
by zippy500
how much to you think something like that would cost to machine ?
Posted: Wed Feb 12, 2020 1:49 am
by Bratitude
zippy500 wrote: ↑Tue Feb 11, 2020 6:53 pm
Not sure, plan on getting it 3d printed out of steel or titanium and seeing how that Holds up. Which would cost around 30-50$ cad.
Something much simpler that would bolt to a rotex coupler might be reasonably priced if machined.
Posted: Wed Feb 12, 2020 8:59 am
I don't want to rain on your parade, but that drawing is meant for 3d printer. Is a bunch of triangles not dots. Did you by chance made an accurate machining part in Solidworks or other CAD software too? Can you export one?
Tnx
Posted: Wed Feb 12, 2020 2:01 pm
by Bratitude
arber333 wrote: ↑Wed Feb 12, 2020 8:59 am
Tnx
soildworks file is in the repo.
Splines are currently “straight cut” not involuted yet. still adjusting mesh and pressure angle. maybe I’ll post just the spline renderings i print in plastic, used for testing.
Posted: Wed Feb 12, 2020 7:20 pm
by doobedoobedo
Well I printed a plastic one from your STL and it is indeed a snug fit on the leaf shaft. Something like this might save me from having to butcher my leaf gearbox input shaft. I hadn't considered metal 3d printing.
Posted: Wed Feb 12, 2020 8:15 pm
by Bratitude
doobedoobedo wrote: ↑Wed Feb 12, 2020 7:20 pm
Awesome, you print the full part? I have only printed sections of the spline for testing.
Did it seal nice over the o-ring on the shaft?
The idea is to oil up the shaft and have it seal, just like in the gear box.
Posted: Wed Feb 12, 2020 8:55 pm
by doobedoobedo
Yes I printed the whole thing, not particularly solidly and at quite crude settings. I just wanted to see if it'd fit.
It will go over the o-ring, but I didn't push it on that far, like I said it's a snug fit, I had to knock it on and lever it off.
If I'd pushed it all the way on I would have had to destroy it to get it off. As it is the levering left dents. It's getting easier to get on and off though, as I'd expect.
Posted: Thu Feb 13, 2020 2:35 am
by Bratitude
doobedoobedo wrote: ↑Wed Feb 12, 2020 8:55 pm
Oh okay, yes I think the trough of the splines is catching the crown of the leaf, I’ll have an update next few days with it involuted as well
Posted: Thu Feb 13, 2020 12:57 pm
by damian.lo
Hello,
I'm really happy, that Bratitude did his 3d model of spline in last days, because I was searching my way to replace my spline from Multipla 1.6 clutch disc. First I want to go to to Honda 1.8 spline, which like Zapatero said was a little to loose ( about 0,2mm) but then I was curious how will fit spline from You.
Result after wire cutter EDM is visible on pictures. Like is written above: higher diameter is ok, lower 19,22 is a little to small and was needed to brush a little with sand paper, so in next version first I will cut by wire and next make chamfer on end and clean inside on internal grinding machine. Everything will be welded inside of Rotex also with small endpoint for motor axis.
I hope this will good and will be not necessary to take one more time gearbox out.
Bratitude: thanks for Your job
Posted: Thu Feb 13, 2020 3:47 pm
by JaniK
Hmm. I know a place where they could laser cut discs like that damien.io just posted. Should I arrange for group buy? Postage from Finland is propably high though..
