Auris TS 2016 remotely inverter turn on
Posted: Wed Jan 10, 2024 11:15 am
Hello. I m a beginner in this theme
. It is possible to turn on inverter in GEN 3 system? I mean car is off, lock. In the cold morning I start up webasto remotely via GSM relay module. Problem is: webasto drain the 12V bat plus AC ventilation is turn on whit webasto. It is work two times without external charging 12v bat and bat dies.
My theory is simply
. +12V signal from GSM module or webasto is turning on inverter, specifically DC-DC inverter to drain electric from big battery.
What is the right way to do this without heavy modified PCB or disassembly hole inverter.
THX for help.
My theory is simply
THX for help.
