I drove an e-Golf
Posted: Sat Dec 28, 2019 10:26 pm
I'm back from Christmas holiday in my home town. To get around my father lent his e-Golf to me
There are a couple of little details that I wanted to note down:
- Top speed 155 km/h very softly limited but you cannot go above even downhill
- Winter consumption with heater set to 20°C: 20.8 kWh/100km
- heater seems to draw about 3.5 kW initially and later cuts back to 1 kW
- On acceleration the momentary consumption quickly maxes out at 99.9 kWh/100km
- very unscientifically speaking the consumption figures are very similar to that of my converted Touran (needs more evaluation)
- Very smooth transition between regen and acceleration
- When a gear is first selected the car creeps very smoothly as soon as you release the brake. When waiting at a stop light and coming off the brake it didn't creep
- The car will roll backwards slightly but is then stopped and held by the motor alone after about 1m (I couldn't hear the brake servo coming on)
- The actual hill-hold function (as denoted by the button) is implemented using the parking brake
- compared to a converted ICE car the transmission is unhearable
- While I was coasting down a hill on the Autobahn with regen disabled, the car suddenly decided to slightly regen anyways. Reason was an upcoming speed limit. I assume had I touched the throttle it would stop doing that.
