Zombie config setup wrong in wiki?
Posted: Mon Jan 01, 2024 6:37 pm
by 86elcamino
Zombie gs450h not working. After hours of double checking everything, I noticed that status was "potpressed", so I changed to pot min to slightly above offthrottle readings, and everything started working. Am I misreading the config directrions in the wiki?
Re: Zombie config setup wrong in wiki?
Posted: Mon Jan 01, 2024 11:43 pm
by royhen99
The wiki is just reflecting the release notes that go with version 1.06 where there were a lot of changes to the throttle code.
https://github.com/damienmaguire/Stm32- ... /tag/1.06A
Like you I found potmin needs to be above the minimum potval.
The change between 1.11A and 2.00A occured here
https://github.com/damienmaguire/Stm32- ... c4e8a7954a.
potpressed was changed from being based on potnom to potval > potmin.
Posted: Sun Jan 07, 2024 12:53 pm
by AdrianB
Wiki updated.
