Suspension changes require iva???
Posted: Thu Dec 28, 2023 6:36 am
I’m a little confused (as it seems is everyone else) on the wording regarding whether or not a vehicle is qregged and requires an IVA
I understand i should avoid cutting and welding like the plague, and then will be above 8 points after motor swap, new axles, and transmission swap.
Alas where i’m lost is what constitutes suspension modification?, does it have to be original oem parts? can it be swapped to coilovers? or does it just mean it has to remain the same system of suspension?
All of it seems very vague, and if i make one wrong move then i’ll be on the hook for a multi thousand pound IVA
Any help is greatly appreciated
