Accord v6 IMA motor and OpenInverter
Posted: Thu Dec 14, 2023 8:10 am
Greetings all!
I am interested in repurposing a Prius battery and inverter setup to power an IMA unit for a hybrid V6 project.
I am unfamiliar with the configurability of the OpenInverter firmware, so hopefully someone can comment whether the IMA unit can be made to work with OpenInverter?
I guess the question is how many volts the Prius C inverter puts out.
As far as I understand, the v6 IMA from the 05-07 Accord Hybrid runs on 110v, but the EPA did testing and cranked it up to 200 which with the right cooling, it can do for sustained periods. In any case, the 20hp/110tq increase in power to the ICE unit is quite attractive for our race car.
Hopefully someone can chime in with their experience using OpenInverter on IMA hardware or if that's even a supported scenario.
Thanks in advance!
Thanks in advance!
