not getting POTNOM %
Posted: Thu Oct 26, 2023 1:51 pm
by ardillolambo
Guys,
After I hooked up the throttle pedal (from a 2017 Model S) I followed the instructions as per https://openinverter.org/wiki/Schematic ... rottle_pot.
I set my potmin = 900 (actual reading 956) then set potmax = 4000 (actual reading 4095) but still reading 0% on potnom. I can see pot changing value accordingly with the pedal angle. I did save it to the flash. potmode = SingleRegen
What 'm missing here? or What I'm doing wrong?
Re: not getting POTNOM %
Posted: Thu Oct 26, 2023 2:07 pm
by royhen99
Those instructions are not very clear. I think potmin has to be a bit larger than the minimum value, around 1000 should work.
Posted: Thu Oct 26, 2023 3:57 pm
by ardillolambo
Regardless the scaling, I should see potnom different than "0", but I tried setting potmin = 1000, tried 1050 and 1100, potnom = 0 in all cases. Then switch to the 2nd throttle cables still potnom = 0 even when I can see the pot value icreasin/decreasing will the pedal angle.
Re: not getting POTNOM %  [SOLVED]
Posted: Thu Oct 26, 2023 5:31 pm
potnom also includes the deratings. So say you have programmed udcmin=300V and you are tuning without HV, so udc=0, potnom will never be positive because it thinks the battery voltage is low. Check the parameters und "Derating" and adjust them to not get in the way.
Posted: Thu Oct 26, 2023 9:16 pm
by alexbeatle
Watching this thread...
Mine does the same thing. So far I've been running the motor using half of my pack 116VDC (udcmin=100vdc) and the max I get out of potnom is 0.09. I can post the plots later. I'm on the latest firmware. The motor spins though.
I'm switching between different tasks of the conversion so haven't deep dived into this yet.
Posted: Thu Oct 26, 2023 10:50 pm
by ardillolambo
@Johu
Thanks for the info, that makes sense. Im following Damien's video word by word so I had udcmin =0, will try your suggestion and see. But I have to check the encoder 1st
Posted: Thu Oct 26, 2023 10:53 pm
by ardillolambo
alexbeatle wrote: Thu Oct 26, 2023 9:16 pm Watching this thread...
good to know that I'm not alone, awesome that your motor is spinning, will do a encoder test tomorrow, then try to spin for the 1st time. Any words of wisdom or something to watch out?
Regards,
Posted: Fri Oct 27, 2023 6:20 am
by uhi22
Docu note: added the hint with the deratings and the link to this thread to the description of potnom in the wiki: https://openinverter.org/wiki/Parameters
Let's together improve the documentation, with all the little things which are blocking the people longer than necessary.
