Page 1 of 1
2008 Corvette C6 Conversion
Posted: Mon Oct 23, 2023 3:58 pm
by eGrandpa
I recently completed (of course, never really done) my Corvette conversion using a Tesla LDU with the openinverter board.
I'm uploading monthly to my YouTube channel --
https://youtube.com/@e-grandpa9778?si=lKo2O2nWbbQaJuvP -- to spread out my build process.
Re: 2008 Corvette C6 Conversion
Posted: Mon Oct 23, 2023 5:20 pm
by johu
Now I understand how people feel who say "I can't get my head around the software part"
I can't get my head around the mechanical part. I wouldn't deem something like this even possible. And you just present it like "look it's done!"
Subscribed and will be following
Posted: Tue Oct 24, 2023 8:46 pm
by P.S.Mangelsdorf
Awesome! That looks really clean!
What batteries are you using?
Also, did the LDU work with the stock rear suspension? I had looked at various Corvette suspensions for my build and was concerned about it fitting. EDIT: I watched the video and answered my own question.
I'd love to see build photos if you have them!
Posted: Wed Oct 25, 2023 12:10 pm
by eGrandpa
johu wrote: ↑Mon Oct 23, 2023 5:20 pm
My education / background is mechanical & electrical so I like integration projects like conversions. It seems like all the conversions are older vehicles to eliminate the CANBUS issues with modern cars. I knew going into this project that there would be issues with the existing GMLAN system. I'm still working on a few tweaks, but for the most part I have it addressed. I will show it in my last video (probably Part 6 or 7) on how I did it. I essentially maintained the ECM after removing the powertrain. The ECM is the GMLAN network end point (the BCM is on the other end), I "faked" the critical signals so the BCM believed the engine / transmission / fuel system was still there.
I'm still fussing with the OpenInverter logic as well. It's minor. I don't like the tip-in delay from start if going slow -- seems to be about 10-20%. I have regen set comfortably for throttle off regen at brkmax -40. I have ocurlim set to 1400 to restrict over drawing current out of my DIY battery system (Part 4 video to be released later). I lowered boost to restrict my acceleration and therefore current. The car can be extremely fast. It exceeds my expectations for how I drive. I can't get over current tripping if I accelerate extremely fast even if I'm already going 60 kph. Again, I don't drive this way, but still want to get the bugs out. I believe if I raise fweak it may help??
Posted: Wed Oct 25, 2023 12:17 pm
by eGrandpa
P.S.Mangelsdorf wrote: ↑Tue Oct 24, 2023 8:46 pm
Thanks. Track my posts in my YouTube channel for build detail. I'm spacing them out over the next few months (Introduction, Motor, Controller, Battery, Ancillary and Vehicle Integration). I learned a lot from YouTube and Open Inverter so I thought it would be good to "payback" to show how I did it.
Posted: Wed Oct 25, 2023 2:07 pm
by johu
eGrandpa wrote: ↑Wed Oct 25, 2023 12:10 pm
ocurlim is just for power stage protection. idcmax limits battery draw and idcmin limits regen if needed. It's not very smooth the limit though...
Posted: Wed Oct 25, 2023 2:15 pm
by eGrandpa
OK. Good to know. I will update my idcmax parameter. If I want to limit it to 1400, do I set the value at 1400? Thx.
Posted: Wed Oct 25, 2023 7:51 pm
by johu
Sligthly higher, say 1500A
Posted: Sun May 05, 2024 11:01 am
by eGrandpa
eGrandpa wrote: ↑Wed Oct 25, 2023 2:15 pm
What happens when it reaches this level? Is it like a valve that restricts it beyond this value or does the relay kickout?
Posted: Sun May 05, 2024 5:41 pm
by johu
Yes like a valave it tapers down
Posted: Mon May 13, 2024 7:24 pm
by eGrandpa
Interesting. There doesn't seem to be any impact when I change idcmax. I have it lowered at 500 and the motor still draws current easily in excess of 1400a. Any ideas? If it ever stops raining in norther Michigan, I will continue testing. I see that I can change iacmax. It is currently at 5000. Seems that it would not be necessary given my idcmax setting. But, will try a low number to see.
In retrospect, I would not have put individual cell fusible links as that limits my max current out of my tesla 18650 cells. I can easily control how much current I pull, but it's when someone else takes it for a ride. I want to limit it to approximately 15a/cell so about 800-1000a.
