Reconfigure Volt / Ampera Battery
Posted: Sun Dec 01, 2019 10:32 pm
Can a Volt battery be unbolted, reconfigured and bolt back up to keep a water tight coolant path?
For example, I'm starting a conversion on a 69 Bug. I'd like to make the longest segment of the battery (the one with the water inlet outlet midway the length) longer with one of the 24v segments from another segment.
Then I'd be able to place the resulting ~52 inch combo'd segment where the lower cushion of the backseat used to be and effectively use the entire width of the car. The remaining segments would then fit up front.
