Page 1 of 1
2002 VW Caddy Conversion
Posted: Wed Nov 27, 2019 12:56 pm
by NIMMOEV
Hi Folks,
I'm converting a 2002 VW Caddy van using a Nissan E-NV200 motor and inverter
I thought it quite fitting that I convert the van using an electric van drivetrain
I started working on the van a couple of months ago & have been mostly refurbishing the front end in preparation for the conversion
I've been collecting parts over the last few months or so and now I’m about ready to start doing some of the conversion work
I will keep this thread updated as I make progress but the usual obstacles like time, money and a garage that is becoming extremely difficult to heat as the Scottish winter takes hold will probably make for fairly slow progress
Here’s a few pics of the van & the progress I’ve made so far
Cheers for having a look :D
Re: 2002 VW Caddy Conversion
Posted: Wed Nov 27, 2019 5:31 pm
by Kevin Sharpe
Great project :D
Posted: Wed Nov 27, 2019 11:10 pm
by Cookie6000
I like this! It will tick sooo many boxes for anyone looking to conv mk4/5 golfs, a3's, polo's, or ibiza's! Interested to see how close to the bulkhead the motor and box end up.
Good luck on the build!
Posted: Fri Nov 29, 2019 12:21 pm
by NIMMOEV
Kevin Sharpe wrote: Wed Nov 27, 2019 5:31 pm Great project :D
Cheers Kevin :)
Posted: Fri Nov 29, 2019 12:27 pm
by NIMMOEV
Cookie6000 wrote: Wed Nov 27, 2019 11:10 pm I like this! It will tick sooo many boxes for anyone looking to conv mk4/5 golfs, a3's, polo's, or ibiza's! Interested to see how close to the bulkhead the motor and box end up.
Cheers Cookie600,
I'm going to get the subframes back in at the weekend & get the gearbox mounted so I can start measuring up for adaptor plate
I'll post a pic so you can see the location of the motor/gearbox in relation to the bulkhead
Posted: Sun Dec 08, 2019 10:56 pm
by NIMMOEV
Managed to get a couple of hours in the garage tonight, got the subframes and the gearbox back in place and the motor roughly in position
Really happy with how its sitting, clearance is a bit tight between the rear of the motor and the collar of the driveshaft but it should be ok
It's a pity that the motor housing has the overhang at the top to support the inverter, would have been a simpler adaptor plate design if it was a flush face but it's not that big a deal
I'll hopefully get some time during the week to better align the motor and gearbox so I can get some measurements taken
Posted: Tue Dec 10, 2019 6:15 pm
by johu
Wow, thats what I call a clean work space :) I still get greasy hands when working on Touran sometimes.
If you need some inspiration for motor mounting, heres how I did it: viewtopic.php?f=11&t=32&start=40
Posted: Wed Dec 11, 2019 2:48 pm
by NIMMOEV
johu wrote: Tue Dec 10, 2019 6:15 pm Wow, thats what I call a clean work space :) I still get greasy hands when working on Touran sometimes.
After years of getting oily working on projects, it makes a nice change to be working on a clean (and green) project :mrgreen:
Thanks for the inspiration johu, I have been following your Touran build and had been considering your design as a way forward, I've now ordered some materials & will pretty much copy your design :evil:
Posted: Mon Mar 02, 2020 2:11 pm
by NIMMOEV
Hi guys, apologies for the lack of updates, the refurbishment of the van is taking longer than anticipated so the EV side of things has been slow.
I should be finished the worst of the refurbishment work in the next couple of weeks then I will jump back on to the conversion work.
I did get the charge port done 👍
Posted: Mon Jun 22, 2020 3:18 pm
by jalovick
NIMMOEV wrote: Sun Dec 08, 2019 10:56 pm Managed to get a couple of hours in the garage tonight, got the subframes and the gearbox back in place and the motor roughly in position
Had you ever considered installing the Nissan reduction gear and updating the driveshafts to fit? It does add some complexity, but you'd have a gearbox made for it.
Posted: Wed Jul 15, 2020 8:13 am
by NIMMOEV
I looked in to using the nissan gearbox with adapted driveshafts but it was cheaper going with an adaptor plate & coupler, if budget wasn't an issue I would have liked to go that route tho
