Trying to use the Prius Gen 2 Inverter like a VFD w 3PH open loop motor
Posted: Sat Aug 12, 2023 5:00 am
by mining702
I can get the motor to just spin at a very low RPM's using opmode 5 sine. Using the sine mode as it is open loop. I have no idea how to speed this thing up. input is from AC rectified to 200 volts (I can go higher 300+ volts if need be)
I have tried numerous different values in the parameter boxes. I feel like I should try a earlier version of firmware? I saw Damien fire up a motor with the blue pill but how?
Any ideas where to move?
Prius Gen 2 VCU with 4.97.R-sine firmware
Motor: 3 PH 230 volt 60Hz 1725 rpm
params (1).json
(1.3 KiB) Downloaded 104 times
Re: Trying to use the Prius Gen 2 Inverter like a VFD w 3PH open loop motor
Posted: Sat Aug 12, 2023 5:26 am
Hello and welcome! APP: Always post parameters along with your question
Posted: Sat Aug 12, 2023 5:54 am
I'd think you need to set more boost, like 5000 or so.
Then try running in regular "Manual Mode" and increase fslipspnt in steps of 10 Hz or so.
