ID a power connector (Toyota Prius & RAV4 EV, Nissan Leaf, and Tesla Model S related)
Posted: Sun Jul 30, 2023 4:02 am
I'm trying to ID this connector, as used on these vehicles:
Toyota RAV4 EV 2013-2014, G9081-0R013
Toyota RAV4 hybrid 2018-on (ref):
Toyota Prius 2012-2017 A/C compressor harness 82122-52070 (ref.):
Nissan Leaf 2018-2023 ? A/C compressor harness 297A6-5SA0A (ref.) or 2012-? 297A6-3NA0A (ref.):
I'd like to build a short harness that uses this connector, and because I'm interfacing with another unit that would be very difficult to obtain its terminals, and I'm trying to avoid a butt splice, this connector shell and terminals is what I'm seeking. Worst case, I buy one of the used harnesses above and butt-splice, but I'd prefer to do it cleaner.
[later]
Subaru 2019-22 Crosstrek Hybrid battery pack uses this connector.
Tesla Model S A/C compressor (2012-at least 2015) uses this connector on the harness that connects to the compressor, harness No. 6007383-00-C. KET (Korea Electric Terminal Co.) appears to be the harness mfgr.
Connector Experts sell it as a Toyota A/C compressor connector, their SKU CE2355-1, for $96, though not the terminals.
https://connectorexperts.com/i-25538322 ... essor.html
I suspect the female terminals in this shell are Sumitomo 8100-1555, which accepts a tab of 4.8mm and whose external dimensions are 6mm W x 3.8mm H x 18mm long; those dims match the terminals on the Toyota Prius etc. A/C harness above. A mismatch is that that terminal is rated for maximum of 3mm², which is well below what I think is needed for 40A (6mm²).
[later]
Toyota 82824-0R330 is the female connector shell only. Toyota doesn't sell terminals for a harness repair, they sell a pigtail with the terminal attached, and -- strangely -- there's no part No. listed for this connector's field replacement pigtail, though there are for the other connectors in this harness; go figure.
This shell is NLA from Toyota in the US, but apparently available from https://www.fitinpart.sg/index.php?rout ... d=51295085 Fitinpart canceled my order, naturally: it's NLA.
[later]
[later]
