Zoe 52Kwh Battery Storage
Posted: Mon Jul 03, 2023 1:10 pm
by lawrence
I wanted to share the project I've been working on recently, to set up home battery storage using a Renault Zoe 52kwh pack from a scrapped car.
The battery pack came from EV Breakers in Northern Ireland. The DC is connected to a FOX ESS H1 6kw high-voltage hybrid inverter via a MCB. The communications cable is connected to a Raspberry Pi based interface. This handle the can bus communications, the relays for 12v/precharge and the MOSFET to control the main contactor.
The Pi acts like a canbus bridge, communicating with the battery, and with the fox, so that they can talk to each other. It also handles Modbus to communicate with the inverter and the meters.
In the photos, you can also see a 12V battery backup power supply to maintain power to the control equipment in the case of a power failure so that the battery can still operate. There is also a small consumer unit for the essential power supply
This is only possible thanks to some code that woleg/rand12345 put on github showing the can bus protocol for both the Fox battery and the Zoe PH2 battery. Unfortunately it looks like that has since been removed, but there are some useful links I've pasted below
Fox Modbus:
https://github.com/StealthChesnut/HA-Fo ... usUSB.yaml
https://github.com/nathanmarlor/foxess_ ... ns.py#L180
Zoe canbus:
https://github.com/fesch/CanZE/blob/mas ... Fields.csv
Re: Zoe 52Kwh Battery Storage
Posted: Mon Jul 10, 2023 2:03 pm
by usus
Are you sending Modbus messages to the inverter?
Can you share the code?
Posted: Mon Jul 10, 2023 3:17 pm
by lawrence
Yes I'm using Modbus for both Zoe and Inverter comms. My code is quiet specific to the environment I use, but it's based on wolegs CAN sniffing here
https://github.com/rand12345/solax_can_bus
Posted: Tue Jul 11, 2023 7:56 am
by usus
I am ok on can side. running without problem.
But on the Modbus i don't have any registry description.
Being in Sweden i need to charge when the price is lowest may be in the middle of the day or the entire weekend.
For this i need to be able to tel inverter when to charge.
Second variant is to use CAN msg 0x1872-charge_max and set the inverters to charge all the time but I don't allow battery to be charge unless I want.
BR.
usus
Posted: Tue Jul 11, 2023 8:09 am
by lawrence
Ah sorry I got confused. I use CAN bus to talk to the Zoe and the Battery side of the inverter. Seperately Modbus to talk to the data side of the inverter. I've been controlling the charge from the CAN side, by setting the max charge amps to stop/start the charge. I only use the Modbus to read data from the inverter to check things are working.
I haven't yet implemented it, but I believe you can set the timed charge parameters via Modbus
If you set Time 1 to for example 01:00 to 02:00, with enabled off. The battery will go into standby at 01:00 to 02:00 and your house will use cheap grid power. If you set enabled to on, your battery will force charge up to the max charge limit set on the inverter settings. So you have to set Time 1 to have the same start/stop time to fully disable it.
I haven't implemented any of this yet as during the summer there is so much solar I haven't needed to use our cheap grid time which for us is 00:30 to 04:30.
Posted: Tue Jul 11, 2023 11:45 am
by usus
I leave in Uk 2 years and is simple to import power. Plus in the north is no gas only electricity. in a month here i use like in a year in UK
In nordic counties power is like the stock market and the pay for transport fees. For example tomorrow (12.07.23) the cheapest hour in SE3 it is between 13:00-14:00.
https://www.nordpoolgroup.com/en/Market ... view=table
I was thinking that is not the best solution to enable charging via CAN by max charge on the battery but for the moment i will go that way.
Still why do you use 3 converter for Modbus? Ca not be all on the same bus with different ID?
Posted: Tue Jul 11, 2023 12:03 pm
by lawrence
Ah okay. I've been controlling charging via max_charge amps and it seems to work well, it's very quick to respond and can keep the battery at a specific charge level that way.
One modbus talks to Fox on the normal RS485, another is for my main Modbus network with multiple devices, and the other is on the Fox Meter Modbus. I intercept the fox meter modbus because if it's on the normal main modbus network, it wants to be the master. There can only be one master on Modbus so then I wouldn't be able to talk to anything else on the modbus network.
I could put the normal Fox RS485 on the main network, I just haven't tried it yet
Posted: Wed Feb 21, 2024 7:15 am
by yasko
lawrence wrote: ↑Mon Jul 03, 2023 1:10 pm
Nice project!
Do you have a pinout of the LV battery connector? I'm unsure whether it is the same as previous models (22 and 41kWh).
The picture looks the same, but can you confirm that signals also correspond?
I'm on the way to doing a similar project, but I'm still researching.
Posted: Wed Feb 21, 2024 8:25 am
by lawrence
The connector is the same 12 Pin 7282-8854-30 but the pinout is different, pinouts attached. These are from Renault "New Dialogys" which you can pay for, for just an hour, to get diagrams and pinouts. For the relays to work you'll need to connect that "HYBRID 3 Relayed" pin, but I can't remember if it needs -12 or +12v off the top of my head.
You can see canbus dumps from the HEV bus here
https://github.com/ljames28/Zoe-PH2-EV- ... nformation . It only really needs to see 0x373 to wake up and then you can talk to it using
However, I've had the battery running since, and the delta between the minimum and maximum cell volages has been rising. It's now sitting around 120mv. There is at least one other person with the same issue. As far as we can tell, the battery is never balancing. Presumably there is some sort of signal or something on the canbus in a certain sequence that it is expecting to see. I've even dissambled most of the LBC controller code but haven't yet worked this out.
Posted: Thu Feb 29, 2024 10:36 am
by lawrence
I believe the balancing issue is now solved by sending accurate time information to the pack via the canbus. There is more information about all the LBC can frames here
https://github.com/ljames28/Renault-Zoe ... nformation
Posted: Mon Mar 04, 2024 2:43 pm
by geamanug
Hello. I am trying to sniff data out of a 27 kw Dacia Spring pack so I can complete integration with a Fronius hybrid inverter. So far I managed to build a data extension cable and also bought a can reader out of aliexpress in order to use it with busmaster or savvycan. I did some work with rs485 in the past but limited knowledge with can protocol. Any guidance would be greatly appreciated. New to this forum so please be kind with my mistakes.
Posted: Mon Mar 04, 2024 3:05 pm
Hi, can you place the Dacia info into a new thread. Thanks!
Posted: Sat May 25, 2024 7:15 pm
by TeslaCoilkV
Hello I want to make an OBD 2 battery health checker
It worked for my nissan leaf, but now I bought a Renault Zoe used and I want to check a used bigger kWh battery in order to swap
For nissan leaf, I connect12 V DC and the pins for the canbus and a female OBD2 ( soldering the right pins I find out details at nissan leaf repair manual and on Dalas Ev repair GitHub for the record ) that you connect an ELM327 Bluetooth or konnwei or what is working with you phone app (for my nissan leaf LedLink^2 worked better for the record) and easy to use
I saw that you said 12 pinouts for the hybrid
My question is for Renault Zoe is if the pins on the Zoe is the canbus pins on the battery connector 14 pins or 12 pins , because I want to buy it from AliExpress
Thank you
Posted: Sat May 25, 2024 7:54 pm
by lawrence
TeslaCoilkV wrote: ↑Sat May 25, 2024 7:15 pm
Thank you
You can see a diagram of the connector a few posts up that shows the amount of pins
Posted: Sun May 26, 2024 12:33 am
by TeslaCoilkV
Yeah but in the photo has got 14 pins and is not clear
I will have my used car in a month to see this better , for the battery I will have to fly to Germany or Norway so is not easy to find out for use how many is the pins , I just want to save time to fix my testing plug.
I order the 12 pins connectors female and male from AliExpress , is very cheap and may be I can connect the 12 pins on a 14 with some configuration , but I am not sure because of the photo.
Besides that he connector of 12 pins is for the hybrid , but yeah I only need the can L can H to connect it. Thanks for the reply but we need a better quality picture or a schematic from the ZOE to be here for the record to help others. Keep up-dating
Posted: Sun May 26, 2024 8:26 am
by lawrence
TeslaCoilkV wrote: ↑Sun May 26, 2024 12:33 am
I believe Yaskos photo shows 12 pins. You can go on Renault ASOS/DIALOGYS to download diagrams of any Renault connectors
Posted: Sun Feb 23, 2025 4:06 pm
by tomspappola
Do you know where i can buy connectors for the "can and high voltage" for the 52000wh zoe battery ?
Tom
Posted: Sun Feb 23, 2025 5:58 pm
by lawrence
You can get the LV connectors on Aliexpress. HV I don't know, I got mine with the battery from the scrapyard.
Posted: Mon Apr 28, 2025 2:08 pm
by craig
Hi Lawrence my name is Craig Smith.
I have the same inverter as your you, well the H1.5.0-E-G2 version, do you manage to fill the ev battery in one over night charge, also have you got a
wiring diagram of what you,ve carried out?
thanks in advance craig.
Posted: Mon Apr 28, 2025 4:56 pm
by lawrence
It would depend how depleted the battery was, and what tarriff you're on. In my case, almost always yes.
No wiring diagram. If you're looking to replicate this, there is a community built up around
https://github.com/dalathegreat/Battery-Emulator
Posted: Wed May 21, 2025 3:54 pm
by craig
hi Lawrence ive been pricing up ev batteries so far not much joy.
Could i ask how much your battery was ,and where did you get it from
Thanks Craig.
Posted: Sun Jun 15, 2025 10:57 am
by craig
Hi Lawrence.
ive been looking at battery you are using, in dala s list of recomended batteries it only gets 1 star for intergration im wondering have you had any issues
Posted: Sun Apr 12, 2026 11:33 pm
by Lemlurker
Probably a little left field but from your pin out I see it has pins for both the precharge and main contactors. I want to get DC out of my pack for testing and development without having all the coms set up. If I pull these pins high (or low?) dies that close contactors even without the rest of the communication set up?
