Share parameters?
Posted: Mon Jun 19, 2023 11:20 pm
by Joxson
Hi!
Is it anyone who can share a working set of parameters for the LDU sport unit?
Im quite new at tuning and Im looking in to getting a little head start ;)
Thanks in advance!
Re: Share parameters?
Posted: Tue Jun 20, 2023 11:55 am
by bexander
Seem like these parameters are a bit old but might get you going.
https://openinverter.org/parameters/
Try the search function on the forum as well, specially in the Tesla section.
Posted: Tue Jun 20, 2023 12:16 pm
by P.S.Mangelsdorf
Here are the two Tesla parameter threads:
viewtopic.php?t=195&hilit=parameter+thread
viewtopic.php?t=126&hilit=ldu+tuning
I'd generally say start with Jon Volk's tune, and tweak from there. I believe the set attached here is his most recent. If I remember correctly he was on a base LDU, but its probably a good starting point for your Sport LDU as he was right to the limit of what a base can take.
I've also attached my most recent parameter dump (just called params). On my base LDU, I'm still having an overcurrent issue when going WOT with a full battery pack. I'm still trying to find a tune that eliminates that while maintaining the violence. There is a chance I've got some inverter damage, but unknown at this time. This was on firmware v5.20
Posted: Tue Jun 20, 2023 7:19 pm
by Joxson
Thanks for the replies! Will upload them and tune after that!
Posted: Wed Jun 21, 2023 7:23 pm
by catphish
On the topic of shared Tesla paramaters, please can someone (ie johu) change the tripmode on the official SDU and LDU paramaters? The current defaults are almost definitely responsible for some damaged hardware.
Posted: Thu Jun 22, 2023 11:28 am
by Bratitude
Sad nobody uses the pram data base :(
Posted: Thu Jun 22, 2023 6:01 pm
by catphish
Bratitude wrote: Thu Jun 22, 2023 11:28 am Sad nobody uses the pram data base :(
Unfortunately the param database is quite broken. I was planning to fix it but just never got time to do so :(
Posted: Wed Jun 28, 2023 6:08 am
by Bratitude
its such a good idea, the potential is there. forum sharing is such a mess
Posted: Wed Jun 28, 2023 9:40 am
Yes, could use a rewrite. Would prefer more server side, less js.
https://github.com/jsphuebner/parameter-database
tripmode updated.
