160kw vs 110kw inverter recommendations
Posted: Thu Jun 15, 2023 9:29 pm
by Jacobsmess
So as far as I understand the 160kw inverter isn't as well supported at present with the zombieverter or OI, I'm looking for an easy conversion path but I've also found a 2019 leaf being broken and agreed a good price for the motor stack but it's the 2019 e+ so I'm slightly reluctant to get it only to have a headache having to get it running.
I've read what little there is on the forums that I could find but I'm hoping others might have more knowledge on the subject than I do or be able to point me in the right direction. Thanks
Re: 160kw vs 11kw inverter recommendations
Posted: Fri Jun 16, 2023 6:45 am
by rstevens81
from my understanding is that no one yet has got the full 160kw (however i could be wrong now), from memory i think its only 125kw at present.
The difference between the 160kw and the 110kw, is that the maximum torque cure is extended a little further, before it goes into constant power region to protect the batteries.
some information i do know about ...
viewtopic.php?t=2846
https://www.automobile-catalog.com/curv ... #gsc.tab=0
https://github.com/dalathegreat/Nissan- ... er-Upgrade
https://www.youtube.com/@DalasEVRepair
https://www.youtube.com/@SouthWestEVUK/videos
Re: 160kw vs 110kw inverter recommendations
Posted: Fri Jun 16, 2023 2:27 pm
by Aragorn
Nissan material suggests the E+ has 340nm rather than 320nm of the 110kw variant, so its a bit more torque as well as the extended curve.
Posted: Sat Jun 17, 2023 12:52 am
by Zieg
I've always wondered how extending the curve is achieved.. is it boosting voltage?
Posted: Sat Jun 17, 2023 6:51 am
by Pete9008
Not sure it's extending as such, think it's more reducing the limiting that is there to protect the battery on the lower power inverters.
