Inverter options for Lexus IS300H gearbox
Posted: Fri Jun 09, 2023 7:51 am
Hi, I've picked up one of these for £250 which was affordable enough for me to give it a go but I'm just wondering what Inverter options I have to pair it with?
Obviously the OEM inverter and likely the GS450H inverter would work but are there other inverters? I'm trying to keep costs to a minimum at the moment because I'm a tight ass because I'm still learning about all this stuff.
U-Pull-It likely have Prius inverters for around £70 or thereabouts which would be a very affordable option, and I guess these are dual motor inverters also as the Prius has the same option.
What about other Lexus models? The price between different models can be quite large but I reckon a CT200H would also work, although may be a bit down on power output (perhaps this would be over ridden by using Damien's Zombieverter anyway, I've no idea as of yet.
