Wanted: Power posts for Lexus GS450h inverter.
Posted: Mon May 22, 2023 8:09 pm
by acollins22
Does anyone have a pair of the brass power posts required for the GS450h inverter to squirt power in past the IGBT and Coil?
Thanks,
Andy.
Re: Wanted: Power posts for Lexus GS450h inverter.
Posted: Wed May 31, 2023 10:59 pm
by sigdigits
I bought some brass stock to make some, and when I finally get to it I have enough for a spare pair... I’ll post back when I make them
Posted: Sat Jun 17, 2023 9:37 pm
by sigdigits
I got a good start making the power posts before someone pointed out that brass has much less conductivity than copper (about 1/3)... I'm not sure if I'll continue down that path, as they also pointed out that using readily available aluminum spacers with a longer bolt will be a LOT less work.
Posted: Sat Jun 17, 2023 10:36 pm
by Bratitude
sigdigits wrote: ↑Sat Jun 17, 2023 9:37 pm
…..aluminum spacers with a longer bolt will be a LOT less work.
Watch out, don’t want to be mixing dissimilar metals, especially for a HV connection. Lots of galvanic corrosion
Copper and aluminum are not a good combo.
Posted: Sat Jun 17, 2023 10:39 pm
by sigdigits
Bratitude wrote: ↑Sat Jun 17, 2023 10:36 pm
Do you know what are the OEM bolts made of? I'm pretty certain they're neither copper OR aluminum, but the buss bars are definitely copper
Posted: Sat Jun 17, 2023 10:43 pm
by Bratitude
copper or zinc plated steel
