question about bidir pedal control
Posted: Fri May 12, 2023 9:37 pm
by Romale
hello, people! I have such a question, in the case of using bidir mode, is it possible to hold the hill in both directions or not?
Re: question about bidir pedal control
Posted: Fri May 12, 2023 9:39 pm
by Romale
also, do I understand correctly that the average value of the throttle should output 1.65 volts, the maximum forward 3.3 volts, and the maximum backward 0 volts?
Posted: Sat May 13, 2023 6:58 am
Romale wrote: Fri May 12, 2023 9:37 pm hello, people! I have such a question, in the case of using bidir mode, is it possible to hold the hill in both directions or not?
Not tested, but in theory it should do just that.
Romale wrote: Fri May 12, 2023 9:39 pm also, do I understand correctly that the average value of the throttle should output 1.65 volts, the maximum forward 3.3 volts, and the maximum backward 0 volts?
No, calibration as always, midpoint is 0 throttle
Posted: Sun May 14, 2023 7:39 am
by Romale
johu wrote: Sat May 13, 2023 6:58 am No, calibration as always, midpoint is 0 throttle
strange. I connected a 5kohm variable resistor and the motor stands still when the middle position. I connected a voltmeter and yes, the voltage of the middle is 1.65 ! and a full 0 volt output (leftmost position) gives the maximum motor speed in the opposite direction
Posted: Tue May 16, 2023 4:47 pm
by Romale
One more question in this direction. How do I enable the rotation speed control option, not the power? (this is important to me for use in a houseboat)
Posted: Tue May 16, 2023 4:48 pm
by Romale
whatever experiments I did with the settings, I could not find the inclusion of this option.
Posted: Tue May 16, 2023 8:11 pm
Ah it's in cruisemode=ThrottlePot
Posted: Tue May 16, 2023 8:15 pm
by Romale
johu wrote: Tue May 16, 2023 8:11 pm Ah it's in cruisemode=ThrottlePot
thank you! I'm going to try right now)))
Posted: Tue May 16, 2023 8:19 pm
by Romale
alas! if you make such a setup there, then the set of revolutions occurs in spurts. for example, I add a pedal by 15%, but instead of smooth operation, acceleration-brake-acceleration-brake is constant for two seconds each action. in any direction of rotation.
Posted: Wed May 17, 2023 7:18 am
Cruise control does not work well with an unloaded motor. You can try lowering speedflt to 0
Posted: Wed May 17, 2023 7:23 am
by Romale
Posted: Wed May 17, 2023 7:35 am
by Romale
Throttle speed mode, throttle sets speed rather than torque (also for boats)
this part of the description interests me))
bidir mode works fine.
but he controls the moment. it is not very convenient for rotating the propeller under water.
the described ability to control the number of revolutions of the motor instead of the torque would be ideal.
but how to turn it on?
Posted: Wed May 17, 2023 8:34 am
cruise control = speed control ;)
For a propeller it does work with speedflt=0 and speedkp=0.1, tested before on a boat.
Posted: Wed May 17, 2023 10:23 am
by Romale
johu wrote: Wed May 17, 2023 8:34 am cruise control = speed control ;)
wow! I'm going to check again :D
Posted: Wed May 17, 2023 10:33 am
by Romale
it worked at speedkp 0.02 !
almost without hesitation.
Sorry, that cruise control stops working in this mode and it is necessary to make a control handle with a rigid fixation.
However, thanks anyway!
the following tests with higher voltage and already on the water!
I hope the house will float soon
Posted: Sat Nov 11, 2023 8:54 am
by Romale
thanks again for the help with the settings. everything works fine!
Posted: Fri Mar 21, 2025 3:42 pm
by Romale
Hello, guys!
I've lived to see the time when I needed BiDir mode and speed control again, not torque. And here's the trouble, the sadness, it was impossible to achieve rotation with the new foc firmware. Rollback to version 5.27 and everything works fine. So in the new firmware version (5.35 foc) something is broken with this mode.
Posted: Tue Mar 25, 2025 3:28 pm
Did the inverter even go into run mode? I found a bug there that it only enters run mode when throttle is in full reverse (i.e. status != PotPressed)
