BMW 6x6 SDU Conversion
Posted: Tue Apr 25, 2023 1:38 pm
I am building a BMW 7 series (E38) 6x6. Per the reason I am posting here, it will be a hybrid. I have a twin-turbo V12 mated to a ZF8 auto trans with a BMW Xdrive system powering the traditional 4 wheels, and I intend to put the Tesla SDU on the rearmost axle. I am considering an LDU but I think space is a limiting factor as I have to contain the motor within the original subframe. I have the engine and the rest of the vehicle controlled by a mix of OEM and standalone hardware. I am thinking that the electric side will almost operate as a mostly standalone system. I do not necessarily want the ECU and the openinverter to talk via Can or other means, as I don't think they need to, but I want to ensure I am not oversimplifying it. In my mind, I will just send the open inverter the same throttle signal that goes to my ECU, and that would get me roughly in the ballpark of everything playing nice. The rest would just come to tuning the systems together.
Has a hybrid setup like this been done before? I don't see why it wouldn't work but I am expecting significant pains in tuning the two systems to play nice with each other.
I am not looking to drive the truck as a pure EV. The motor is there to give more umpf when I am looking for fun or while I am towing and to provide an additional source of braking. My engine makes about 600HP, but it is a turbocharged gasoline engine, so torque isn't immediately available, my goal for the motor is to help alleviate this. Is it possible for the openinverter to have configurable 'drive modes'? I would like to have something like a regen-only mode, low power, and full power. I will likely have around 25kWh worth of pack on board.
Thank you for the advice in advance! Here https://www.youtube.com/channel/UCOucit ... OviNuH_cAQ is my Youtube if you're interested in more of the engineering of the project.
