Page 1 of 1
Can beginning
Posted: Fri Feb 01, 2019 11:05 am
by D@F
hello all,
any one can tell me with wich soft and hard i could start to learn and understand CAN protocol ?
i usualy work on rs232, wiegan, modbus, but never on can.
Re: Can beginning
Posted: Fri Feb 01, 2019 1:48 pm
by Peter
Would like a quick demo on how to use the CAN area of the parameters please Johannes if you would be so kind
Re: Can beginning
Posted: Fri Feb 01, 2019 3:52 pm
by D@F
Re: Can beginning
Posted: Fri Feb 01, 2019 5:17 pm
by dima
I picked up CANAble
https://canable.io it is based on open-source
http://cantact.io
CANAble is a bit pricey but you don't need to waste time building one yourself.
You can build your own:
Hardware:
https://github.com/linklayer/cantact-hw
Software:
https://github.com/linklayer/cantact-app
Re: Can beginning
Posted: Fri Feb 01, 2019 5:21 pm
by johu
Peter wrote: ↑ Fri Feb 01, 2019 1:48 pm
Maybe this helps:
VIDEO
I use a CANDue that Damien donated to me and the software SavvyCAN.
http://store.evtv.me/proddetail.php?pro ... oduecanbus
That CANAble looks very good!
There is a lot of very expensive (500€+) CAN hardware out there that doesn't provide any benefits to the hobby user. So don't spend too much.
Re: Can beginning
Posted: Fri Feb 01, 2019 10:47 pm
by doobedoobedo
I have a cantact with the candlelight firmware. I've not had much of a play with it yet though.
https://github.com/linklayer/candleLight_fw
Re: Can beginning
Posted: Sun Feb 03, 2019 9:33 pm
by D@F
hi! thanks for your feedback, i think i will try the canable pro.
Re: Can beginning
Posted: Mon Feb 11, 2019 8:17 pm
by dima
I am also just starting to explore CANBus.
Does CAN transmits only happen in working start mode? or at any time? I have it on a bench with nothing attached to the board.
If I want to "debug/test" Canable in sniff mode. Will Hardware v3.0 be able to dump some info for me?
I get nothing. Pointers and examples needed.
ex:
