Characterisation of Prius Gen3 Inverter Over Current and Over Temperature Trips
Posted: Sun Mar 12, 2023 2:12 pm
Edit May23 - Have changed the thread title to better reflect the later contents.
Just looking at the DESAT/MGx_FAULT handling specifically for Toyota inverters running OpenInverter logic boards.
From what I've read the Toyota IGBT drive board actually handles the desat side by turning off the IGBT itself and the fault line is more to flag that it is happening. In this case there seems to be no real need for the inverter to fully trip.
I'm wondering whether, just on the Toyota inverter, it would be better to treat the fault output in much the same way as an over temp and derate instead of tripping. Specifically I was wondering whether to back off the throttle by 0.1% for each pass of the control loop in which the FAULT line was active (and light the MIL light so the driver is aware of the issue). This would give full throttle backoff in around 125ms, should still protect the inverter while also avoiding any an unpleasant side effects associated with shutting down the inverter above base freq. The reverse would happen in the FAULT flag was clear to restore full throttle availability.
Has this been tried before, if so did it work. Can anyone see any reasons not to try it or know of any other alternatives that might be better?
