test bed current limiting resistor value?
Posted: Tue Feb 14, 2023 2:47 pm
I now have the O/I board installed in the SDU and I am setting up the test bed.
I have searched for the value of resistor to use for current limiting on the motor battery B+ (for test purposes only) and can only find "use a resistor or some heater wire". I understand that it is critical NOT to use a fuse as the B+ going open circuit while the motor is spinning will destroy things. This seems to preclude using a light-bulb as the current limiter.
What value / size resistor to use for this? I am going to use four 12 volt 100aH batteries (48 volt) in series for testing.
Thanks!
Thanks!
