Toyota GT86 with Nissan Leaf Motor (Update 11/2022: 160Kw)
Posted: Fri Oct 25, 2019 11:19 am
by Zapatero
Hi folks,
my name is Philip and i'm from Germany, Ulm. I had plans to convert a car to electric since more than five years now. Finally i found a way to adapt an electric motor into a CAN Bus car and make it work - the Leaf Inverter Board from Johannes. As i'm an car enthusiast i find that most electric cars that are affordable aren't exactly fun to drive. So i decided i want an electric RWD fun car that still has the capability of transporting my whole family: The Toyota GT 86.
I've done plenty of engine conversions in the past, but always worked with ICE. This will be my first electric conversion. Also i build four wheel campers: http://www.weltreisewerkstatt.de
I already purchased the Openinverter board with the Nissan Leaf adaptor. Also i have the full set of CAN Bus codes from https://www.geraldjustprojects.com/. Yesterday i designed the gearbox adaptor for the leaf motor in CAD.
I have the complete Engine of the Leaf and also the whole 24 KWh battery system.
Now i only need the car where im already in negotiations to get my handy on a GT 86 with severe engine failure.
I Still need the Coupler for the Motor, but i think i've found a solution that i can manufacture in my workshop as NewElectrics didn't reply to my emails about the Leaf Spline Adaptor.
Technical Update #25 January 2020:
Motor Nissan Leaf 2014
Estimated Power 140Kw, 400nm torque
Connected to the OEM Gearbox by an custon made cupler and adaptor plate.
Battery Pack
24 KWh Battery Pack with 48 modules and 96 cells out of the Leaf 2012
Spread through the car in various places:
Custom modified spare wheel well for 24 modules
Custom made fuel tank boxes for 12 modules
2 Custom made boxes in front, one under the motor with 6 modules and one next to the motor with 6 modules
If i like the result of the project i will invest in a 30KWh battery pack out of a newer leaf
Battery Management System:
Orion BMS 2
Everything is fully CAN-bus controlled
Inverter
Nissan Leaf Inverter with Johannes Huebner main board, fully CAN-bus controlled
GT86 ECU
Arduino based replacement ECU for CAN-communication from Geraldjustprojects.com
Charger
ELTEK Valere 3Kw Charger, fully CAN-bus controlled
[']Chademo-Charging will be available, Orion BMS does support it. Just have to implement it physically in the car, i already have the parts
DC-DC converter
First GEN-Tesla Model S converter, just needs an +12 enable signal
Re: Toyota GT86 with Nissan Leaf Motor
Posted: Fri Oct 25, 2019 11:35 am
by Zapatero
Here are my drawings to fit the Motor to my gearbox. Several adaptor rings will be placed inbetween the tho adaptor plates. All parts will be laser cut out of 8mm aliminum. My idea is to get it all done without having to mill the adaptor to keep the cost low but still have high accurancy of the alignment of the motor to the gearbox.
Posted: Fri Oct 25, 2019 11:59 am
by Zapatero
That`s what the finished adaptor should look like:
Posted: Fri Oct 25, 2019 12:57 pm
by Kevin Sharpe
Zapatero wrote: ↑Fri Oct 25, 2019 11:19 amI Still need the Coupler for the Motor, but i think i've found a solution that i can manufacture in my workshop as NewElectrics didn't reply to my emails about the Leaf Spline Adaptor.
Sorry to hear you had no response from NE Amsterdam... I've asked them for an update.
Posted: Fri Oct 25, 2019 1:11 pm
by Zapatero
That would be awesome, I'd love to purchase one!
Posted: Fri Oct 25, 2019 9:22 pm
by Thatguyoverthere
FYI, some threads floating around on other forums state that the Fiat Multipla clutch friction plate has the same diameter and spline count and should fit the leaf motor shaft. Just ordered one for myself, so I guess I'll find out as well.
Posted: Sat Oct 26, 2019 6:21 am
by Zapatero
Unfortunately it does not, it has to much play on the shaft and will most likely wear out! It's the same with the Suzuki Samurai Clutch disc.
Check this video for the fitment of the Suzuki clutch disc:
Fiat clutch disc is 20,1x22,5-20N, which is by the way the same as every cheap Lada Niva disc!
Suzuki Samurai Is 20,1x23,1-20N
Nissan leaf is 19,2x21,7x20N
I might have found something from a Porsche 911 (Sachs 1878005583) that should be a bit more tight. It's dimensions are 20,1x22,3-20N, so a it should sit tighter than the Suzuki or Fiat disc. So I'll try that
Posted: Wed Oct 30, 2019 7:37 am
by Zapatero
Unfortunately the Porsche Clutch disc which should be better than the Fiat Disc just by the specs doesn't serve it's purpose at all. Check for your self:
I'll order the Fiat Disc and try that - NE Amsterdam still didn't reply
Try calling Sachs or Sachs Performance directly. Maybe they can give you the center part of a clutch since that's all you need to fabricate the adaptor.
I ordered the Clutch - if you're right that is a GREAT find!!!!!!
Kevin Sharpe wrote: ↑Wed Oct 30, 2019 11:07 am
Not good news I'm afraid (here)
I'm sorry to hear that, but i think that they had their reasons to decide that way (economical reasons i guess)
Posted: Wed Oct 30, 2019 1:03 pm
by purplespark
I shall watch this with interest,as I'm still looking for something to fit the Leaf spline !
Are you 100% sure that 20x22-20N are the correct spline dimensions ? I've searched but can't find any specs.
It would be brilliant if this clutch centre fits properly !
let us know !
Posted: Wed Oct 30, 2019 3:18 pm
by zippy500
Google is referencing this clutch plate to a 1988 onwards Honda Civic-
Is anyone one getting this answer ?
Posted: Wed Oct 30, 2019 6:57 pm
by crasbe
zippy500 wrote: ↑Wed Oct 30, 2019 3:18 pm
That's what the linked page says as well. I attached screenshots of the compatible cars.
Posted: Wed Oct 30, 2019 8:52 pm
by Zapatero
As soon as the clutch disc gets delivered i'll let you know how it fits!
Really excited about this find!
Posted: Thu Oct 31, 2019 8:14 am
by Zapatero
The Board is finished and i'll drop it in tomorrow.
Then i'm going to connect the Inverter to the Car to see how unhappy the car is with the situation of the missing Engine...
Posted: Thu Oct 31, 2019 9:11 pm
by Thatguyoverthere
Zapatero wrote: ↑Sat Oct 26, 2019 6:21 am
Nissan leaf is 20x22-20N
You were right about the fiat disc, I'm sending mine back. In the meantime, I've ordered the Honda Civic 27/32"x20 spline friction disc as it actually had measurements listed on rockauto
Posted: Fri Nov 01, 2019 7:38 am
by Zapatero
The Toyota GT86 is finally here. Next week i'll take the engine out and also the fuel tank to see, how many batteries i can fit instead of it in place.
Getting all the batteries somehow appropriate in the car seems to be a bit of a challenge. In the worst case, some of them have to go in the trunk
Posted: Fri Nov 01, 2019 8:48 am
by Kevin Sharpe
Zapatero wrote: ↑Fri Nov 01, 2019 7:38 am
The Toyota GT86 is finally there.
Can you put the car on some corner scales? World be really interesting to see the weight distribution before and after conversion
I think we need to get to the bottom of this !
I've measured the leaf spline and I get an o/d of 21.65mm. I would have said that 22mm is not going to give a snug fit.
I,ve seen some Honda civic clutches that have an id of 27/32" which is .008" too small. I'm no expert but I spoke to one engineer who suggested
spinning the motor and applying some emery cloth , "might " get it to fit . Having said all that, Damien has used a samurai clutch centre (I think),
but he shrank a cylinder over it for his coupler to compress it slightly - maybe he might chip in with his thoughts ?
Posted: Sun Nov 03, 2019 5:13 pm
by Zapatero
purplespark wrote: ↑Fri Nov 01, 2019 12:45 pmI would have said that 22mm is not going to give a snug fit.
Your guess was absolutely correct! It's not the Honda clutch disc either. It has a little less play then the Porsche Disc, but it still isn't a snug fit.
Next attempt is:
SACHS 1864506031
Volvo 850
19,1x21,8-20N
I've finally measured the Leaf spine, too. My results are: 19,2x21,7x20N
so with just a tiny bit of emery cloth on the inside of the Volvo disc spline, to get rid of 1/10th mm, it could be the perfect fit. I'll let you know!
