Zombieverter programming help
Posted: Tue Feb 14, 2023 5:56 am
by sigdigits
(Hopefully I’m not a complete idiot and only need 12v and ground to test)
Tl:dr zombieverter SEEEEMS to program correctly, and the web interface is correctly programmed and accessible (wemos d1), but no data/parameters appear. I’m suspecting an issue with uart, since I have the rs232 jumpers soldered and don’t get data (will update)
I’ve done the obligatory reading of the wiki and watching the videos and searching the forums. I’m not compiling from source, since I only recently set up a laptop with Ubuntu 22.04, but I might try that soon.
I have a Dropbox folder with a video and photos of the programming and soldering of the stm microcontroller.
https://www.dropbox.com/sh/ltyx9ad2in4k ... aZmOa?dl=0
Full disclosure... I had the GD variant chip on my board and gave up trying to program it. Without getting too much into that, I ended up replacing it with the ST made chip when it became available. The soldering was successful and I included pics of the pins in the link.
After rewatching Damien’s video, I can see the programming behavior is the same in both our videos. I have a solid red 3v3 led before programming indicating the power rails are all good. I’m using the stlink utility and uploading the hex files starting with the stm32_loader, then the stm32_vcu (latest release v1.11a). After programming I get the activity light blinking and all the checksums are matching.
I have used a couple different esp modules and was able to successfully program the web interface and access the webpage. I’m currently using the wemos d1 chips and they work great. I’m starting to wonder what’s the best way to check where my issue is, since it’s starting to look like I may not be getting uart communication between the stm32, and the WiFi module. I had an arduino connected to the rs232 pins on the connector, but I’m guessing I should disconnect the WiFi module to eliminate that from the equation. 115200 8 n 2
What should I see on a healthy board? Do I need anything other than 12v and ground connected for uart?
As far as the WiFi module, I should see something if I hook up the Arduino to its tx/rx pins and send a bin file uart update, no?
I can see from the webpage that the WiFi module is programmed, and from the zombieverter activity led, and confirmation from stlink utility, the board seems programmed as well. Up until just recently I was convinced that the stm32 wasn’t programmed because I wasn’t seeing any parameters and couldn’t use the OTA updates. I remember that I soldered the rs232 pads and I got no data on the tx/rx pins on the 56 pin connector. I tried swapping the tx/rx pins on the WiFi module even though I had found and triple checked them. No matter what I did, I have the same behavior of everything appears to be working, but no data/parameters appear in the web interface. I didn’t try disconnecting then completely and testing the two boards individually. Hopefully someone will see the pics/video/post and see something I haven’t
Re: Zombieverter programming help
Posted: Fri Feb 17, 2023 10:17 pm
by sigdigits
I'm getting SOMEWHERE, just not sure it's in the forward direction, lol
I think the zombieverter board isn't communicating over uart to the wifi module... I disconnected the esp board to make sure there was no conflicts, but when I power on the zombie, I'm seeing no data on uart3. I probed the pins where the wifi module connects, the solder jumpers for the external rx/tx connection, and the vias on the bottom of the board near the 56 pin header. I'm using an arduino connected to a serial monitor 115200 baud, and I get no data
I programmed a blue-pill board, and although I couldn't get data in the web interface, I did get the 2D2D2D heartbeat in the serial monitor...
I tried sending the stm32_vcu.bin over the uart OTA from the wifi module, and it was "successful" (still blue-pill) and showed an upload progress bar which I've never had show up in other attempts. Despite this, I still never got data/parameters showing up in the web interface. I've pasted the serial monitor data below, which makes me confident that the issue doesn't lie with the wifi module... "poop" was sending from the web interface with the "Custom Command" button
13:40:51.515 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6)
13:40:51.549 ->
13:40:51.549 -> load 0x4010f000, len 3460, room 16
13:40:51.549 -> tail 4
13:40:51.549 -> chksum 0xcc
13:40:51.549 -> load 0x3fff20b8, len 40, room 4
13:40:51.549 -> chksum 0xc9
13:40:51.549 -> csum 0xc9
13:40:51.549 -> v0005f060
13:40:51.549 -> ~ld
13:41:11.406 -> ⸮k⸮⸮R⸮⸮⸮⸮⸮,⸮
13:41:29.768 -> poop
13:41:34.737 ->
13:41:34.737 -> poop
13:41:46.979 -> ⸮⸮2D2D2D2D2D2D2D2D2D2D2D2D2rl⸮⸮r⸮⸮#⸮n⸮⸮⸮⸮⸮⸮p⸮<⸮⸮⸮⸮8⸮⸮ǒ⸮⸮p⸮nn⸮⸮;⸮nĒ⸮⸮⸮b⸮#l`$`nn⸮⸮܀⸮⸮⸮⸮l⸮⸮⸮⸮⸮b⸮n⸮⸮n⸮⸮⸮⸮⸮⸮b⸮⸮>~⸮n⸮⸮⸮⸮⸮l`⸮⸮⸮#⸮n⸮⸮;nr⸮⸮⸮;⸮⸮?r⸮;⸮p⸮n⸮⸮⸮⸮r⸮⸮⸮b⸮⸮⸮x⸮b⸮n⸮⸮n⸮⸮⸮b⸮ľ~⸮n⸮⸮⸮r⸮⸮#⸮n⸮⸮;nr⸮⸮⸮;⸮⸮?l`与⸮⸮;⸮⸮?l`Ğ⸮⸮l⸮⸮⸮r⸮⸮nĒ`⸮
13:48:09.208 -> ets Jan 8 2013,rst cause:2, boot mode:(3,6)
13:48:09.208 ->
13:48:09.208 -> load 0x4010f000, len 3460, room 16
13:48:09.244 -> tail 4
13:48:09.244 -> chksum 0xcc
13:48:09.244 -> load 0x3fff20b8, len 40, room 4
13:48:09.244 -> chksum 0xc9
13:48:09.244 -> csum 0xc9
13:48:09.244 -> v0005f060
13:48:09.244 -> ~ld
13:48:31.260 ->
13:48:31.260 -> fastuart
13:48:31.470 ->
13:48:31.470 -> poop
13:49:01.316 ->
13:49:01.316 -> poop
13:49:37.709 ->
13:49:37.709 -> reset
13:49:39.316 -> ⸮1P ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮q"⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮c⸮c⸮c⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮"⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮%"⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮c⸮c⸮c⸮⸮⸮⸮KhhhG⸮ ⸮ ⸮&⸮(⸮⸮⸮⸮ KJ`⸮
KH`⸮⸮@⸮ͼ
13:49:39.846 -> KH`⸮⸮@⸮ؼKH`⸮⸮@⸮KJ⸮⸮KJ⸮⸮⸮ < ⸮ ⸮ \ -⸮⸮A] ⸮⸮⸮⸮k⸮F^ ⸮⸮⸮⸮e⸮F_ ⸮⸮⸮⸮_⸮F` ⸮⸮⸮⸮Y⸮Fa ⸮⸮⸮⸮S⸮⸮FIKh⸮&⸮HKh⸮"⸮O⸮⸮q F⸮⸮@⸮ZQ F⸮⸮@⸮ya F⸮⸮O⸮dq F⸮⸮⸮O⸮⸮q F⸮⸮⸮O⸮⸮q F⸮⸮⸮O⸮⸮q F⸮⸮⸮@⸮! F⸮⸮⸮@⸮! F⸮⸮⸮@⸮3q F⸮⸮⸮@⸮!Q(F⸮⸮⸮@⸮"Q(F⸮⸮⸮@⸮#Q(F⸮⸮⸮@⸮$Q(F⸮⸮⸮@⸮%Q(F⸮⸮⸮@⸮&Q(F⸮⸮⸮@⸮'Q(F⸮⸮O⸮⸮a(F⸮⸮O⸮mq0F⸮⸮@⸮!0F⸮⸮@⸮!0F⸮⸮@⸮⸮!0F⸮⸮@⸮r!0F⸮⸮O⸮⸮q8F⸮⸮O⸮⸮q8F⸮⸮O⸮q@F⸮⸮⸮@⸮S8F⸮⸮⸮Kh\`⸮⸮⸮⸮( , ⸮⸮⸮o8⸮FFذ⸮⸮o&⸮@⸮#⸮Bh⸮,⸮@⸮r#⸮BY⸮@⸮#⸮BZа⸮⸮M⸮8K"Fh)Fh⸮h⸮G5Kx+[⸮"F)F3H⸮C⸮"F)F⸮⸮8@0H⸮H⸮⸮⸮"UF-⸮⸮⸮⸮ $(,@⸮⸮#⸮B;а⸮m⸮ѽ⸮8@F⸮G⸮⸮⸮8@⸮{⸮⸮⸮8@⸮⸮⸮⸮8@⸮⸮⸮⸮⸮8@⸮⸮⸮⸮⸮8@⸮⸮⸮⸮⸮8@𗼽⸮⸮8@⸮8@⸮F⸮⸮8@⸮ƸF⸮⸮8@⸮F⸮⸮8@⸮B⸮F⸮⸮8@⸮e⸮F⸮⸮8@⸮+⸮!F(F⸮⸮8@⸮⸮⸮8⸮⸮ % ⸮ ⸮⸮⸮h⸮2⸮8⸮ ⸮⸮⸮h⸮%⸮⸮⸮h⸮#⸮-⸮⸮A⸮L#x+@⸮!⸮ ⸮⸮D ⸮⸮⸮⸮K⸮OhF⸮N⸮ ⸮⸮⸮ 9h⸮⸮⸮ 1h⸮⸮⸮K⸮Mh⸮ ⸮⸮D⸮⸮⸮⸮ )⸮⸮⸮⸮⸮⸮0+@⸮Ҁ⸮Kx+@⸮̀,𭀈I:h x⸮BчI2h x⸮B⸮+⸮;⸮#⸮Jp⸮⸮!⸮ ⸮m⸮#x+⸮Ѷ⸮+@⸮"|K⸮⸮,@⸮ˀ3x+⸮⸮⸮xKx⸮⸮wJp,W⸮,2⸮.⸮(x⸮⸮⸮F(⸮⸮qO⸮ 9x⸮F⸮)FE =p⸮⸮+⸮+⸮⸮,hM⸮, ⸮⸮(gNW⸮gH⸮⸮h⸮(R⸮#3p+x+F⸮"`KpaH⸮⸮h⸮⸮⸮,!⸮"WKp^L#x3۲+#p⸮[M\H+x3+p⸮⸮T⸮ZH⸮⸮Q⸮)xYH⸮⸮⸮UH⸮⸮F⸮UH⸮⸮C⸮##p⸮⸮⸮⸮KJ,p⸮⸮H ⸮⸮⸮F- ⸮⸮⸮⸮B⸮⸮N ⸮⸮⸮F/ ⸮⸮⸮⸮B⸮⸮">Kp"9K⸮⸮?H⸮⸮ ⸮+x+⸮Ѵ⸮+x+⸮⸮@H⸮⸮
⸮0p⸮⸮?O?N;h+⸮2h;2;`2`K⸮".K> p⸮⸮O⸮⸮sXC8`3h⸮⸮⸮⸮#3`+⸮;+⸮⸮⸮0+⸮J⸮ Kx⸮"!Kp-Kx+⸮⸮⸮⸮+N3x+⸮B⸮,⸮,⸮'H⸮⸮⸮⸮,⸮5⸮$H⸮⸮⸮⸮M(x⸮⸮⸮(?⸮=⸮!ME )p⸮⸮⸮⸮ )x⸮⸮⸮"⸮,⸮⸮⸮⸮m 0 4 T d ⸮ ⸮ 8 ⸮ ⸮ ⸮ $ ⸮ ⸮ 4 t u ⸮ ⸮ <@< ⸮ ⸮ % ⸮ ⸮ -⸮⸮GR ⸮'⸮FD ⸮#⸮FZ ⸮⸮⸮⸮삁F⸮⸮⸮⸮⸮⸮⸮⸮0+
ѶKx⸮⸮,⸮,ѴH!⸮I⸮⸮H⸮⸮⸮⸮⸮0+⸮⸮⸮D ⸮⸮⸮(F⸮⸮⸮⸮@⸮⸮⸮?⸮8F⸮+⸮!F⸮?⸮(⸮ۀ ⸮⸮⸮(⸮Հ/⸮⸮O⸮⸮6NE@⸮ހ⸮⸮h[h⸮G⸮⸮%⸮⸮)Fhi⸮G⸮⸮hj⸮G!⸮⸮(⸮π⸮⸮hj⸮G⸮@⸮8⸮⸮)FR ⸮⸮⸮] ⸮⸮⸮N⸮3⸮⸮⸮3x+@⸮e ⸮⸮⸮#P"!⸮X#⸮{⸮F⸮⸮⸮⸮⸮⸮⸮⸮c ⸮⸮(⸮⸮⸮⸮Z ⸮⸮@⸮⸮⸮⸮1⸮⸮⸮⸮⸮R ⸮⸮P⸮⸮⸮F(F⸮⸮⸮FY ⸮⸮⸮(O⸮$Կ%@%⸮⸮⸮9F⸮⸮⸮(⸮!!
C⸮u⸮9F⸮⸮⸮(⸮!!
C⸮m ⸮w⸮bO(@⸮aH⸮⸮⸮(@⸮;x⸮⸮^H⸮⸮⸮⸮]H⸮⸮⸮⸮]H⸮⸮⸮⸮!D ⸮h⸮⸮⸮$⸮⸮3x+@⸮,
13:49:40.199 -> ⸮QH⸮⸮(@⸮0⸮!D ⸮S⸮$-⸮)F%G ⸮J⸮,@⸮@Kx+⸮HH⸮⸮⸮3x+@⸮@H⸮⸮⸮(@⸮-⸮$⸮⸮!(F⸮q⸮(?⸮+⸮HF⸮e⸮F(F⸮⸮F!⸮⸮E⸮⸮⸮%⸮⸮⸮hj⸮G1⸮⸮e ⸮⸮⸮⸮#P"!⸮X#⸮⸮F⸮⸮⸮W⸮⸮⸮⸮⸮⸮c ⸮⸮⸮(⸮Z ⸮⸮⸮@⸮⸮⸮⸮⸮⸮D⸮+⸮n ⸮⸮⸮⸮⸮⸮H⸮6⸮(?⸮8⸮R ⸮⸮⸮⸮⸮Q⸮0⸮+⸮.⸮R ⸮⸮⸮⸮⸮⸮⸮&⸮;x+⸮]⸮Kx+?⸮X⸮
H⸮⸮ ⸮S⸮⸮⸮ & < % X ⸮ ⸮ | t ⸮ ⸮ ,⸮[⸮m ⸮⸮N⸮m ⸮⸮p⸮BH⸮⸮⸮FAKx+⸮%,⸮!O⸮qH⸮%⸮⸮w ⸮⸮⸮V⸮,⸮7Kx+?⸮S⸮M⸮⸮E⸮4H⸮⸮⸮⸮)FD ⸮⸮⸮g⸮⸮0H⸮⸮⸮⸮.H⸮⸮⸮⸮.H⸮⸮⸮⸮.H⸮⸮⸮⸮-H⸮⸮⸮⸮!Z ⸮i⸮)FD ⸮e⸮3x+⸮ H⸮⸮⸮$%N3x+.⸮$Kx+⸮,⸮⸮⸮⸮⸮⸮,
13:49:40.534 -> И⸮0+⸮⸮H⸮⸮⸮⸮"Kp⸮⸮⸮0+⸮⸮MH⸮⸮{⸮+x⸮⸮B⸮#+p7 ⸮⸮F⸮ ⸮%⸮F⸮⸮⸮a⸮3x+⸮⸮⸮⸮Kx+⸮ˮ$⸮⸮⸮ ⸮ ⸮ ⸮ | t ⸮ ⸮ ⸮ ⸮ -⸮⸮CuK⸮⸮⸮⸮h⸮q⸮⸮y⸮sKh⸮⸮⸮⸮RN⸮7⸮qI⸮<⸮F⸮ ⸮⸮⸮⸮⸮FF ⸮⸮⸮D ⸮⸮⸮jJFQxx⸮⸮C⸮#⸮xC⸮A⸮⸮dKR h⸮⸮F(FbM⸮⸮⸮⸮⸮(hh⸮h⸮G,^H@⸮⸮⸮⸮⸮⸮\N]O3x+ ⸮\Kx⸮⸮,⸮,⸮YH⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮^⸮8x⸮⸮⸮(Fp⸮;x⸮QK⸮⸮⸮"PK!E p⸮⸮(hh⸮i⸮GFe ⸮⸮(hh[i⸮GFf ⸮⸮(hh[j⸮G⸮⸮⸮Fx ⸮⸮(hh⸮i⸮GFL ⸮⸮⸮⸮⸮@2H,V⸮⸮⸮⸮F⸮/H⸮⸮⸮!Fw ⸮l⸮⸮⸮0+⸮3H⸮⸮⸮⸮Fw ⸮a⸮⸮⸮0+⸮⸮⸮( ⸮8⸮0⸮] ⸮4⸮⸮⸮⸮⸮(Kg h⸮K⸮8x⸮0⸮3x+L⸮$H⸮⸮x⸮⸮⸮⸮CF⸮ ⸮<⸮⸮⸮}⸮r⸮(⸮(⸮⸮FE ⸮1⸮Kx+⸮⸮Jp⸮⸮FE ⸮&⸮;x+⸮⸮Kp⸮⸮⸮⸮⸮⸮⸮⸮⸮ % h A⸮ X , ⸮ ⸮ & < ⸮ ⸮ < ⸮ m OH⸮⸮+⸮OOFOM(⸮⸮⸮,hT⸮D ⸮⸮⸮(⸮⸮6⸮(` F⸮J⸮⸮0⸮+h⸮d(⸮⸮*⸮+h⸮⸮(⸮ ⸮)⸮@H⸮⸮⸮D ⸮⸮(=M⸮+x[⸮#!E ;p⸮⸮⸮;xñH ⸮⸮F- ⸮⸮F1 ⸮⸮2K⸮BhE⸮}(⸮⸮} ⸮B⸮2`x⸮⸮- ⸮⸮⸮+K
13:49:40.534 -> 0⸮2 ⸮⸮⸮F⸮$⸮⸮⸮&Kp&K⸮ x⸮⸮1 ⸮n⸮F0⸮⸮⸮⸮H⸮⸮⸮⸮ Kp K⸮ ⸮⸮⸮⸮K⸮ x⸮{⸮⸮ )x⸮w⸮K~ x⸮r⸮⸮⸮⸮3x+⸮'⸮⸮⸮⸮⸮⸮⸮*⸮⸮:⸮⸮F8pE ⸮`⸮H⸮⸮⸮⸮ F⸮⸮,`⸮⸮⸮ ⸮ p ⸮ ⸮ l ⸮ ⸮ ⸮ ⸮ ⸮ ⸮ ⸮ '(8⸮F⸮⸮⸮⸮⸮(⸮⸮⸮,@⸮⸮⸮ ⸮
⸮F] ⸮)⸮ ⸮⸮F^ ⸮"⸮ ⸮⸮⸮F_ ⸮⸮ ⸮⸮⸮F` ⸮⸮ ⸮⸮⸮Fa ⸮
⸮ ⸮⸮⸮Fc ⸮⸮ ⸮⸮⸮lMlL(` ⸮⸮⸮ `
13:49:40.534 -> ⸮⸮⸮⸮⸮h` ⸮⸮⸮`` ⸮⸮⸮eKeL`
⸮⸮⸮dK` ⸮⸮⸮bK` ⸮⸮⸮aK` ⸮⸮⸮_K` ⸮⸮^K` ⸮⸮\K` ⸮⸮#XC@⸮⸮XK` ⸮⸮WK` ⸮⸮UK` ⸮⸮TK⸮⸮p[ ⸮⸮ ⸮⸮PK⸮⸮p\ ⸮⸮* ⸮⸮⸮ p, ⸮⸮⸮KK!xpd ⸮⸮ ⸮z⸮ ⸮w⸮ ⸮t⸮5 ⸮q⸮CKCLp6 ⸮k⸮BKp#x+"⸮; ⸮c⸮?K`: ⸮^⸮=K`9 ⸮Y⸮<K`8 ⸮T⸮:K`< ⸮O⸮9Kp= ⸮J⸮7Kp> ⸮E⸮6K⸮4 ⸮@⸮ p> ⸮<⸮O⸮⸮sXC1K`8⸮)(⸮#⸮) ⸮0⸮Fb ⸮L⸮⸮⸮⸮⸮n⸮⸮)Khh⸮j⸮G⸮⸮⸮⸮⸮⸮*⸮⸮%Kh⸮⸮⸮⸮(F⸮⸮"K Fh⸮⸮⸮⸮(F⸮⸮⸮⸮⸮ ⸮ $ $ , ⸮ ⸮ ( & % ⸮ ⸮ ⸮ ⸮ d T 4 0 ⸮ ⸮ ⸮ ⸮ ( , Kh⸮j⸮h ⸮L F⸮⸮⸮(⸮⸮⸮ 0⸮⸮⸮
0⸮⸮
⸮O⸮@⸮⸮ch⸮⸮⸮⸮hF⸮⸮@⸮ bh⸮B⸮hF⸮ ⸮⸮⸮⸮x ⸮ ⸮J⸮Jx3۲d+⸮p⸮#pKh2;*`J⸮h1`h<9`h;+K⸮h1`h<9`h*⸮⸮I
13:49:40.534 -> h2
13:49:40.534 -> `h:`⸮⸮⸮ d T 4 0 ⸮⸮⸮T]⸮⸮⸮⸮)⸮"⸮I⸮H⸮⸮⸮"⸮I⸮H⸮⸮⸮"⸮I⸮H⸮⸮⸮"⸮I⸮H⸮⸮⸮"⸮I⸮H⸮⸮⸮"⸮I⸮H⸮⸮⸮"⸮I⸮H⸮⸮⸮# "⸮I⸮H⸮L⸮#⸮"⸮I⸮H⸮F⸮#O⸮B⸮I⸮H⸮?⸮#"⸮I⸮H⸮9⸮#"⸮I⸮H⸮3⸮#⸮"⸮I⸮H⸮-⸮#⸮IF⸮H⸮'⸮#O⸮B⸮I⸮H⸮ ⸮#O⸮B⸮I⸮H⸮⸮#O⸮R⸮I⸮H⸮⸮#O⸮r⸮I⸮H⸮⸮#O⸮r⸮I⸮H⸮⸮#O⸮b⸮I⸮H⸮⸮⸮#O⸮b}I⸮H⸮⸮⸮#@"qI⸮H⸮⸮⸮#O⸮⸮&9 ⸮rzI⸮H⸮⸮⸮#O⸮rjI⸮H⸮⸮⸮#O⸮rgI⸮H⸮⸮⸮#O⸮RlI⸮H⸮⸮⸮#"qIH⸮⸮⸮#"nI}H⸮⸮⸮# "kI{H⸮⸮⸮#@"hIyH⸮⸮#"]IwH⸮⸮#[IFuH⸮⸮#O⸮RQIrH⸮⸮#O⸮B[IpH⸮⸮#"JInH⸮⸮#⸮"PIlH⸮⸮#@"MIjH⸮⸮#@"GIhH⸮⸮⸮#"DIfH⸮⸮⸮⸮T⸮dIO⸮p⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮Y⸮⸮⸮⸮⸮ ⸮⸮>⸮JH⸮⸮⸮⸮TH⸮⸮⸮⸮#YJYI⸮⸮x⸮' ⸮M⸮⸮⸮²#UI(F⸮⸮⸮' ⸮C⸮
⸮⸮t²# FPI⸮w⸮(FOI⸮⸮⸮ FMI⸮~⸮MK`MK`⸮⸮⸮8⸮⸮⸮⸮⸮n⸮II F⸮v⸮HK" FHI`⸮⸮⸮
13:49:40.708 -> " FFI⸮⸮⸮d" FDI⸮}⸮⸮" FCI⸮x⸮B ⸮⸮(⸮⸮A⸮!C ⸮#⸮⸮⸮⸮⸮⸮⸮8⸮⸮⸮⸮@⸮ ⸮ @4 $ ( ⸮ ⸮ @< @⸮ L \ ⸮ @⸮ t | ⸮ ⸮ ⸮ ⸮ ⸮ d l D ⸮ ⸮ ⸮ ⸮ ⸮ ⸮ T ⸮ 4 , $ ⸮ ⸮@⸮⸮H@d@h@A( , @h Q]⸮⸮# J IpSp⸮pJ HSb⸮⸮ 0`KJ`KJ`⸮Ŀ⸮ ⸮⸮⸮ ⸮ < ⸮\ б⸮⸮ ⸮ ⸮⸮⸮O⸮⸮#(J@⸮0⸮⸮-⸮A⸮@⸮0⸮=⸮O⸮Ap⸮9⸮@⸮0⸮5⸮@⸮0⸮1⸮@⸮0⸮-⸮@⸮0⸮)⸮@⸮0⸮%⸮O⸮`p⸮!⸮@⸮0⸮⸮@⸮0⸮⸮O⸮ p⸮⸮@⸮ 0⸮⸮@⸮ ⸮
⸮O⸮@p⸮ ⸮@⸮0⸮⸮@⸮0⸮⸮@⸮0⸮⸮⸮⸮⸮@@⸮0⸮⸮⸮⸮⸮s⸮$M#F"F !(F⸮⸮D⸮⸮!F(F⸮⸮N(F⸮⸮(F⸮⸮0FO⸮ C"!⸮9⸮0FO⸮C"!F⸮2⸮(F⸮⸮⸮p@⸮8@@7⸮⸮s⸮$MO⸮⸮QO⸮p⸮O⸮#F"F !(F⸮⸮D⸮⸮⸮N(F⸮⸮⸮(F⸮⸮⸮0FO⸮⸮S"!⸮ ⸮0FO⸮c"!F⸮⸮(F⸮⸮⸮p@⸮<@@⸮L# F"!⸮⸮⸮#" F!⸮⸮DD⸮⸮⸮ FI⸮(⸮ F!⸮8⸮ F!⸮=⸮ F!⸮E⸮ F!⸮;⸮ F!⸮C⸮ F⸮⸮@⸮D⸮⸮@ ⸮⸮ ⸮⸮⸮! ⸮⸮⸮ ⸮⸮⸮! ⸮⸮ ⸮⸮! ⸮⸮ ⸮⸮⸮! ⸮⸮ ⸮⸮⸮! ⸮⸮( ⸮⸮O⸮@⸮⸮⸮!O⸮@⸮b⸮IO⸮@⸮⸮ ⸮⸮⸮⸮⸮@ ! ⸮@⸮O⸮q ⸮⸮ ⸮⸮ ⸮⸮⸮⸮⸮@ ⸮"⸮LFO⸮sH⸮k⸮ F⸮z⸮# "F F⸮W⸮ F!⸮u⸮" F!⸮t⸮! F⸮6⸮ F⸮⸮⸮ FO⸮zr!⸮w⸮ F@⸮4⸮`⸮ F⸮⸮@⸮O⸮,@@⸮#!FH⸮7⸮O⸮⸮@⸮E⸮#O⸮⸮@FF⸮!⸮!O⸮⸮@⸮>⸮O⸮⸮@⸮!⸮O⸮⸮@⸮'⸮⸮!O⸮⸮@⸮3⸮!O⸮⸮@⸮⸮"!O⸮⸮@⸮*⸮!O⸮⸮@⸮⸮⸮O⸮⸮@H"!⸮/⸮⸮⸮@O⸮⸮@⸮⸮@8⸮FFbF⸮⸮⸮ F⸮⸮⸮ F@⸮⸮!⸮⸮ FO⸮⸮q⸮⸮#(Fkb8⸮⸮⸮CjF+FF*⸮j⸮⸮⸮Ocj"⸮\ j⸮⸮⸮cj"⸮\ j⸮⸮⸮!cj⸮⸮⸮⸮D⸮#`⸮@$⸮P j⸮⸮! j⸮⸮⸮ j⸮⸮⸮cj3cb⸮⸮⸮0⸮-⸮⸮AF%'⸮⸮⸮⸮B⸮⸮⸮⸮⸮⸮⸮⸮ j⸮⸮⸮#j1⸮43S⸮% ⸮F
13:49:40.921 -> DC⸮% T⸮%0⸮G j⸮⸮⸮⸮⸮0⸮56⸮⸮!⸮⸮⸮A⸮s⸮!p⸮⸮Fj
13:49:40.921 -> %F⸮B ⸮F⸮$⸮jC⸮⸮⸮⸮3D1⸮⸮p⸮⸮$J⸮"⸮h⸮B ⸮i⸮B⸮JB⸮ ⸮⸮⸮⸮ ⸮⸮ ⸮⸮X KS⸮ pG KS⸮ @pG⸮ ⸮KS⸮ ⸮P⸮O⸮tQ⸮⸮⸮⸮ KS⸮ @CXBXApG KIC⸮ pG⸮⸮drX KC⸮ pG ⸮FFO⸮⸮A⸮}⸮⸮A⸮KC⸮$⸮⸮ p⸮F$M1Fhh⸮&⸮⸮⸮p⸮4⸮,⸮⸮ѕ ⸮⸮X #J⸮i⸮B⸮زpG3⸮+⸮⸮ѕ pGX "K⸮0pG⸮X "K⸮3⸮⸮⸮⸮ pGX #JI⸮i⸮PiA⸮#3⸮+⸮⸮⸮pGX KTpG⸮⸮ K\CTpG⸮⸮ J\#⸮TpG⸮ K\pG⸮⸮ KhK⸮⸮⸮'pG⸮ X 8⸮⸮}F#⸮⸮⸮8@⸮h⸮⸮⸮⸮ 0Bj⸮DD
13:49:40.921 -> )⸮⸮⸮⸮*9⸮Mch"(Fy⸮⸮⸮⸮⸮⸮(0+⸮⸮chHy⸮⸮bjch2yH⸮⸮⸮7⸮⸮⸮ ch⸮⸮yH⸮2⸮⸮ch"yH⸮⸮ch Hy⸮⸮⸮⸮⸮ 0⸮⸮⸮⸮[ ⸮⸮ 0#⸮⸮(0cb8⸮2Bb⸮⸮@ !⸮h⸮缀h⸮ܼ8⸮FMCh(FYy⸮⸮⸮ch(FYy⸮)⸮⸮⸮ch(FYy⸮"⸮⸮⸮ch(FYy⸮⸮8@⸮¾@p⸮a@⸮
FJI⸮⸮`!"⸮u⸮⸮(F!⸮⸮"⸮⸮ BbCJ⸮`sB`bhh⸮B⸮@J`bh;⸮⸮h⸮⸮⸮29b`⸮⸮⸮⸮i⸮⸮"!⸮⸮⸮(FO⸮⸮1⸮7⸮(F!⸮G⸮(FO⸮Q⸮K⸮(F!⸮S⸮(F!⸮I⸮!(F⸮Q⸮(F⸮d⸮(F⸮f⸮ch(Hy⸮⸮⸮ch%Hy⸮_⸮ch.2Fy!H⸮s⸮ch"yH⸮&⸮ch"yH⸮⸮chHy⸮(⸮chHYy⸮⸮⸮ch2FYyH⸮W⸮ch"YyH⸮
13:49:41.076 -> ⸮ch"Yy
H⸮⸮⸮chHYy⸮⸮ch HYy⸮/⸮ F⸮⸮N⸮(F⸮⸮ Fp⸮⸮⸮⸮X⸮ @8⸮C}
FiK⸮!h9⸮(F⸮⸮⸮4⸮⸮#h⸮$ F8⸮8⸮FL⸮⸮⸮h⸮⸮⸮⸮⸮8⸮⸮FF⸮⸮⸮⸮⸮⸮#}"{⸮Bch⸮!auZ⸮i⸮⸮!"⸮Q⸮ F⸮⸮@ I⸮⸮ٿ⸮h⸮⸮⸮⸮!au:⸮i⸮⸮"⸮⸮@!⸮=⸮⸮h⸮⸮⸮⸮
13:49:41.076 -> ⸮8⸮FF⸮⸮x0+c}⸮O⸮⸮5O⸮a%;⸮ FIخ9E⸮⸮⸮⸮ FI⸮⸮⸮⸮)F⸮h⸮b⸮⸮h!⸮⸮8@⸮y⸮
13:49:41.139 -> ⸮⸮-⸮⸮AChFYyFH⸮⸮⸮F⸮⸮⸮ F⸮⸮⸮⸮⸮i⸮B⸮Z⸮a#D⸮⸮)⸮h⸮x⸮⸮⸮/r⸮e⸮⸮⸮0
13:49:41.139 -> +⸮
+_⸮"⸮⸮)⸮⸮) !0F⸮a⸮!⸮⸮⸮⸮F⸮⸮+⸮
13:49:41.139 -> !0F⸮⸮F⸮⸮⸮⸮+x#⸮
!0F⸮⸮F#0F+p&I⸮a⸮⸮⸮Fй F⸮⸮⸮]⸮ F⸮⸮|⸮⸮i⸮⸮h⸮V⸮⸮i F⸮[h⸮⸮⸮AGA⸮⸮⸮⸮⸮⸮0FI⸮⸮⸮F(⸮ F⸮⸮⸮j⸮⸮⸮1F F⸮⸮⸮=F⸮a⸮⸮-⸮c}⸮⸮ F⸮⸮⸮AI⸮⸮⸮⸮⸮)0!+ѣi+⸮ F⸮⸮C⸮#⸮a⸮⸮⸮⸮⸮@(⸮3⸮<⸮K⸮⸮hhFhG⸮ ⸮R⸮⸮I⸮⸮⸮'⸮⸮⸮7⸮⸮⸮⸮I⸮⸮⸮⸮]⸮⸮⸮⸮⸮⸮⸮-⸮⸮AFI⸮⸮⸮0FI⸮⸮⸮%⸮⸮H⸮⸮8F⸮⸮]⸮F8F⸮⸮a⸮p⸮8F⸮⸮⸮⸮⸮ ⸮ciAF⸮#i0F⸮⸮hbh⸮⸮5⸮-⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮̯⸮⸮⸮I⸮⸮$O⸮0F⸮⸮2⸮F0F⸮⸮j⸮⸮⸮⸮⸮8F⸮⸮⸮4⸮,⸮⸮⸮⸮⸮⸮⸮⸮-⸮⸮AF$
13:49:41.189 -> O⸮0F⸮⸮⸮⸮⸮⸮0F⸮⸮⸮⸮4FBF9F(F⸮⸮⸮,⸮ѽ⸮⸮⸮⸮'⸮⸮F⸮⸮⸮ F⸮⸮@I⸮n⸮0⸮C9⸮⸮/⸮
13:49:41.189 -> ⸮⸮B⸮Ѐ⸮ pG9⸮?⸮ppG⸮;⸮⸮F \⸮pG0⸮⸮FF⸮+
13:49:41.189 -> ⸮⸮B⸮⸮pG)F⸮ ⸮- ⸮ IBF⸮⸮⸮⸮⸮⸮01)p,F⸮⸮⸮F⸮⸮⸮#+p⸮B⸮3x"x⸮+⸮9⸮⸮⸮0"App ⸮ ⸮⸮0⸮x-+⸮O⸮⸮40!
13:49:41.189 -> %C⸮⸮!⸮/0:в (⸮⸮⸮⸮0⸮$⸮⸮⸮LxF⸮⸮
13:49:41.189 -> ۲+⸮٢⸮F⸮⸮⸮⸮L8D⸮BF ⸮x8
13:49:41.189 -> ;۲+⸮$⸮⸮⸮⸮⸮#SpF⸮$⸮⸮⸮⸮⸮⸮⸮ @#⸮⸮B⸮⸮Q⸮#@@⸮#@3⸮⸮:⸮pG@⸮⸮⸮p⸮\⸮,
FF`⸮⸮⸮K]K]K]3F(F⸮i⸮+'⸮, ⸮1F(F⸮⸮p@⸮Y⸮$"!F⸮⸮p⸮⸮⸮⸮p⸮⸮⸮O⸮⸮3#\C3F⸮-#O⸮d⸮⸮;a⸮FTC0F
13:49:41.266 -> "⸮⸮?⸮."d ,2Tؿ0"⸮ؿZp!FO⸮
13:49:41.266 -> ̿X⸮⸮⸮-⸮(Fp⸮⸮x-+⸮O⸮⸮60$O⸮
13:49:41.266 -> ⸮F⸮TF⸮+⸮⸮0⸮ /⸮٪⸮⸮@"D⸮⸮⸮&⸮⸮@⸮e⸮⸮⸮⸮⸮⸮D⸮?0;߲ /⸮⸮⸮⸮
13:49:41.266 -> %"⸮F⸮⸮-⸮⸮CF
F$⸮"⸮\ ⸮2⸮⸮B⸮⸮F⸮⸮⸮ '0'⸮ԠF_⸮⸮⸮⸮⸮⸮$⸮⸮s⸮⸮⸮⸮ ⸮⸮⸮3h0Fh⸮G⸮⸮ '⸮⸮3hIF0Fh⸮G⸮⸮8⸮⸮#⸮⸮%F⸮⸮-⸮3h9F0Fh⸮G=⸮⸮,⸮⸮ ⸮ ⸮⸮⸮⸮⸮-⸮⸮GF⸮⸮⸮FF
Fa⸮0#⸮⸮⸮⸮0BFSF⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮#⸮
13:49:41.266 -> *-⸮)+⸮MB#⸮⸮⸮0::
⸮⸮⸮⸮⸮⸮Q )⸮⸮⸮01⸮B⸮⸮9⸮⸮d⸮⸮⸮⸮⸮⸮;h-!8Fh⸮G⸮⸮8SFBFIF8F⸮⸮q⸮ D⸮⸮$⸮⸮FKF⸮⸮-"$ ⸮,⸮⸮ ⸮⸮F⸮⸮⸮⸮-⸮⸮CFFF%O⸮
13:49:41.346 -> ⸮⸮⸮⸮⸮3x+x⸮%+o⸮sx+s⸮%+⸮g⸮-+
13:49:41.346 -> ⸮##⸮F⸮0)⸮C⸮⸮⸮"0F⸮⸮⸮0_⸮⸮⸮⸮⸮ ⸮F⸮⸮⸮⸮s)⸮!h4)⸮IF8F⸮⸮#⸮
⸮d)⸮a !F⸮⸮0#⸮
13:49:41.346 -> "8F h4⸮⸮^⸮D6⸮⸮x)⸮!Fa ⸮⸮0⸮#"⸮⸮X)⸮!FA ⸮⸮u)⸮a !F⸮⸮0⸮#⸮⸮f)
13:49:41.346 -> ⸮!h⸮⸮⸮#4⸮⸮⸮⸮⸮⸮#⸮⸮⸮c)⸮⸮!h4⸮⸮!⸮⸮⸮⸮⸮F;h8Fh1x⸮G5⸮⸮(F⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮R⸮KhF⸮⸮2⸮⸮g⸮⸮]⸮⸮⸮pG$⸮⸮⸮⸮R⸮⸮⸮⸮X⸮⸮]⸮⸮⸮pG8⸮)L)M F⸮@⸮ F⸮B⸮ F⸮I⸮ F⸮A⸮! F⸮⸮ F⸮⸮⸮ F⸮⸮⸮ F⸮⸮! FJ⸮9⸮ F⸮o⸮(F!J⸮⸮⸮(F!J⸮⸮⸮(FO⸮r!⸮⸮(FO⸮b!⸮⸮⸮T"(F!⸮⸮⸮(F⸮$⸮!⸮⸮(F!⸮⸮(F!⸮⸮ F⸮;⸮ F⸮⸮8@⸮⸮$@@, L$@8 F⸮BFݑBܓB⸮⸮FFpG⸮B⸮ܑB⸮⸮FpGs⸮nFh⸮*⸮54⸮,4⸮4⸮*⸮⸮⸮⸮*4⸮B&⸮⸮ѽ⸮0⸮⸮D⸮⸮0D⸮⸮0D⸮⸮⸮p⸮⸮
K⸮B⸮⸮⸮c⸮BУ⸮c⸮B⸮) ⸮Ȳ⸮)⸮1⸮⸮)⸮
13:49:41.440 -> 1⸮⸮⸮^⸮ ⸮⸮@#p⸮⸮@FF"FF⸮⸮ F⸮⸮)F F⸮⸮⸮⸮3hJ⸮J⸮⸮O⸮Tp⸮8 , KJ⸮`J`J`J⸮`
13:49:41.440 -> J⸮` J⸮
13:49:41.440 -> `J3`pG8 ⸮ ⸮ 4 $ ( ⸮ ⸮ JK0⸮S⸮!0R⸮!@F⸮B⸮⸮!Fh⸮⸮⸮BۣB⸮⸮#F⸮⸮⸮B⸮` 0⸮⸮B⸮` ⸮⸮Bȿ`⸮⸮⸮ )p⸮⸮KS⸮!PKS⸮!`⸮B⸮@⸮N⸮Fp⸮J⸮F F⸮N⸮I⸮⸮p⸮ ⸮⸮ ⸮B8⸮ҹ⸮⸮⸮⸮
KFhF(F⸮?⸮⸮⸮)F F⸮t⸮)FFH⸮o⸮FH⸮)⸮!F⸮r⸮8⸮ ⸮⸮⸮, ⸮B%Kp⸮hFF(F⸮⸮⸮,F!K!Fh(F⸮⸮⸮⸮,FN!F5h(F⸮⸮⸮!Fx⸮(F⸮ ⸮⸮⸮K(Fh⸮?⸮!FF⸮⸮⸮P⸮,F⸮(F⸮⸮⸮8⸮! F⸮⸮⸮⸮ F4`p⸮!(F⸮⸮⸮⸮%)F F⸮⸮⸮(⸮⸮K(Fh⸮⸮!FF⸮⸮⸮⸮ $ 0 ⸮ ( ⸮⸮F
FF⸮⸮⸮O⸮⸮A(F⸮⸮!F⸮⸮⸮⸮⸮M4h! F⸮⸮⸮⸮)F F⸮⸮⸮,F(FI4`⸮⸮8⸮ ⸮⸮M⸮⸮%⸮⸮⸮G9F F⸮⸮(⸮⸮<F⸮⸮HB⸮B⸮⸮KFhF8F!⸮⸮⸮ȱ.h!0F⸮⸮⸮⸮9F F⸮⸮I⸮⸮⸮!F⸮_⸮⸮$!F0F⸮Y⸮⸮4F,`⸮⸮K Fh⸮⸮I⸮⸮!F⸮g⸮⸮$!F0F⸮a⸮⸮⸮ ⸮@ p⸮FNFI0h⸮⸮!F⸮⸮⸮O⸮vQ⸮⸮⸮0`.hF#⸮>!0F⸮:⸮!F⸮⸮Kh⸮x⸮I⸮⸮!F⸮⸮⸮$!F0F⸮1⸮⸮4F,`p⸮
Kh⸮c⸮
13:49:41.515 -> I⸮j⸮!F⸮"⸮⸮$!F0F⸮⸮⸮⸮⸮⸮4 pA⸮ A p⸮FK.hh⸮$$!0F`⸮⸮⸮⸮
13:49:41.598 -> KhH⸮4⸮$⸮⸮p⸮⸮⸮FF0F⸮⸮⸮⸮4F,`p⸮8 ⸮ K⸮;⸮⸮pG⸮z⸮⸮ K`pG⸮L ⸮⸮ K`pG⸮P ⸮⸮ K`pG⸮T ⸮⸮ K`pG⸮X J⸮3⸮
13:49:41.598 -> "⸮⸮0⸮⸮⸮⸮J`pG\ < ⸮⸮ K`pG⸮D ⸮⸮ K`pG⸮@ ⸮⸮ K`pG⸮H 4#⸮"⸮⸮0#_ ⸮⸮0⸮⸮ ⸮⸮0⸮⸮0⸮⸮0⸮⸮0⸮⸮0⸮⸮⸮⸮⸮#jF@⸮A⸮⸮⸮]⸮⸮2#⸮⸮⸮0#_ ⸮⸮0⸮⸮0⸮⸮0⸮⸮0⸮⸮0⸮⸮0⸮⸮0⸮⸮⸮⸮⸮p⸮#jF@⸮A⸮⸮⸮]⸮⸮4#⸮⸮⸮0#⸮⸮0⸮⸮0#_ ⸮⸮0⸮⸮0⸮⸮0⸮⸮0⸮⸮0⸮⸮⸮⸮⸮N⸮#jF@⸮A⸮y⸮⸮]⸮⸮⸮⸮%K $pB'⸮⸮⸮⸮d&⸮⸮?⸮_ ⸮⸮@⸮⸮p⸮⸮P⸮⸮`⸮⸮P⸮⸮P⸮⸮P⸮⸮P4⸮⸮⸮⸮⸮#⸮⸮#jF@⸮A⸮M⸮⸮⸮ ⸮⸮⸮⸮⸮⸮⸮⸮),⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮ ⸮F@⸮⸮ ⸮B8⸮FA⸮X0⸮B(⸮F
13:49:41.598 -> "⸮⸮⸮⸮⸮"⸮⸮ "⸮⸮0^ ⸮⸮ ⸮⸮0⸮⸮ ⸮⸮ ⸮⸮ ⸮⸮ ⸮⸮h⸮⸮⸮⸮#jF@⸮1⸮⸮⸮]⸮⸮⸮I⸮⸮xH⸮⸮0⸮#⸮⸮0#x⸮⸮02Ҳ*⸮⸮pp⸮⸮0⸮⸮0⸮⸮0⸮⸮0x⸮#p⸮+⸮+⸮^ ⸮⸮3⸮⸮⸮#jF@⸮)1⸮⸮⸮⸮]⸮⸮⸮#⸮⸮⸮#⸮⸮_ ^ ⸮#⸮⸮⸮0⸮(#⸮0#⸮#"⸮⸮0⸮⸮ ⸮#⸮"^ ⸮⸮0⸮⸮0⸮⸮ ⸮⸮0⸮⸮0⸮⸮⸮⸮~⸮#jF@⸮?A⸮⸮⸮]⸮⸮#⸮⸮#⸮⸮#⸮⸮⸮#~"⸮⸮0⸮⸮0⸮⸮0⸮⸮0⸮⸮ ⸮⸮0"#^ ⸮⸮ ⸮⸮0⸮⸮⸮⸮⸮⸮⸮U⸮#jF@⸮EQ⸮⸮⸮⸮]⸮⸮⸮⸮⸮⸮x⸮⸮⸮⸮ESBSAppG⸮⸮⸮⸮hJ#⸮C⸮B⸮⸮⸮B=2⸮B
13:49:41.749 -> ⸮J⸮B⸮#"⸮pKpx"K⸮#"⸮pKp⸮"KppG#"⸮pKp⸮"K⸮⸮-⸮t⸮⸮ ⸮ a#7⸮⸮⸮0⸮#⸮⸮0CxFk⸮%^ ⸮⸮⸮⸮⸮⸮⸮#jF@⸮21⸮)⸮=⸮⸮#cp⸮0⸮#CppG@⸮⸮#⸮B⸮⸮⸮FK`_#⸮⸮0Y#⸮⸮0⸮#⸮⸮0#⸮⸮0⸮#⸮⸮0⸮#⸮⸮⸮⸮⸮
13:49:41.749 -> ⸮⸮^ ⸮⸮0⸮⸮L⸮⸮⸮⸮#jF⸮!⸮⸮⸮⸮]⸮⸮d (-⸮⸮C⸮d!!⸮⸮,⸮!$⸮⸮&⸮⸮rSF۲⸮#O⸮⸮ ⸮⸮0#⸮⸮^ BO⸮⸮0⸮⸮⸮⸮@⸮⸮@⸮⸮`⸮⸮⸮⸮⸮⸮⸮⸮jF⸮!#⸮⸮8M;x^ ⸮⸮0+x⸮⸮@⸮⸮0y#⸮⸮0⸮#⸮⸮0#⸮⸮0⸮#⸮⸮⸮⸮⸮0⸮⸮⸮⸮⸮q⸮#jF⸮!⸮⸮(L)K!xx⸮⸮`B⸮⸮sF⸮⸮⸮ &۲⸮#⸮⸮^ ⸮⸮0⸮⸮⸮⸮`⸮⸮`⸮⸮⸮⸮⸮L⸮#jF⸮!⸮x⸮IJx x3p⸮⸮003⸮⸮0;x p3;p+x3+px3۲\+p
13:49:41.820 -> Ѿ#p⸮#;pM#p⸮#⸮⸮`.p#p⸮⸮⸮⸮⸮` ⸮ a ⸮ ⸮ ⸮ ⸮ xpG⸮xpG⸮KLx^ ⸮⸮0#⸮⸮0⸮#⸮⸮0#x⸮⸮0⸮#⸮⸮0⸮⸮{⸮⸮⸮⸮#jFO⸮⸮q⸮"⸮#x3۲⸮+⸮
##p⸮⸮⸮ b pGpG@ipG⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮KxpG⸮ 8⸮#H⸮⸮⸮⸮F"H⸮⸮⸮⸮F F⸮⸮F⸮ ⸮⸮l⸮(F⸮⸮F⸮ ⸮⸮e⸮ F⸮⸮⸮⸮⸮#⸮⸮⸮⸮⸮#⸮⸮⸮⸮|⸮F(F⸮⸮
13:49:41.820 -> ⸮⸮⸮#⸮⸮⸮
13:49:41.820 -> ⸮⸮⸮#⸮⸮⸮l⸮FF F⸮⸮⸮⸮,F F8⸮⸮7⸮⸮⸮⸮⸮{%VHL@⸮ ⸮ p⸮F
FL! F⸮r⸮ F!J⸮⸮⸮2F F!⸮⸮⸮⸮⸮ F!⸮⸮⸮ F!⸮⸮⸮ F!⸮⸮ F"!⸮⸮ F"!⸮⸮
⸮⸮ FO⸮R!⸮l⸮ F!⸮⸮⸮⸮p@H⸮@D@D@⸮FFI⸮p⸮I⸮!⸮⸮1⸮
13:49:41.900 -> J⸮(`b⸮⸮⸮H⸮3C⸮J⸮⸮#⸮⸮⸮ZE⸮Bl j 8⸮FL! F⸮⸮ F!J⸮⸮⸮ F!J⸮⸮⸮⸮ F!⸮⸮ F!⸮\⸮ F!⸮B⸮ F"!⸮0⸮ F"!⸮⸮ F"!⸮⸮ F!⸮W⸮⸮⸮8@H⸮A⸮@D@s D@⸮F ⸮⸮]⸮⸮(⸮⸮⸮=H⸮⸮⸮⸮<H⸮⸮⸮⸮<H⸮⸮⸮⸮⸮⸮0C⸮7H⸮⸮⸮⸮6H⸮⸮⸮⸮6H⸮⸮⸮⸮D ⸮⸮A⸮#3LD #⸮⸮⸮;⸮(⸮ ⸮⸮6⸮ ⸮@⸮⸮P"@⸮Ss
13:49:41.900 -> ! ⸮⸮⸮!⸮⸮ ⸮(H⸮⸮(H⸮⸮x⸮⸮⸮ɲt ⸮⸮<⸮$H⸮⸮o⸮⸮⸮ɲu ⸮⸮3⸮!H⸮⸮f⸮⸮⸮ɲv ⸮⸮*⸮H⸮⸮]⸮FH⸮⸮Y⸮⸮⸮㲀⸮⸮HdD⸮⸮⸮M⸮d⸮⸮⸮ C@⸮L( p⸮!y ⸮⸮
13:49:41.900 -> ⸮#x+⸮!y ⸮⸮⸮@⸮⸮⸮⸮⸮D d l h ,@⸮ ⸮ ⸮ r "p⸮
13:49:41.900 -> LF&F⸮⸮B⸮⸮2D⸮⸮⸮⸮1D⸮,p]@⸮ ⸮XBXAp⸮s p⸮LF"F⸮⸮B⸮⸮k03D⸮⸮⸮⸮SU
13:49:41.900 -> D
13:49:41.900 -> ⸮<p⸮⸮ ⸮⸮⸮MF+x+>⸮⸮⸮⸮;>|⸮⸮⸮⸮>⸮⸮⸮⸮⸮d ⸮⸮⸮⸮⸮H⸮⸮⸮⸮!⸮⸮L⸮H⸮⸮⸮⸮#x{⸮"!⸮H⸮⸮⸮⸮!"⸮H⸮⸮⸮P!⸮H⸮⸮g⸮⸮P!H⸮⸮b⸮~K[x+⸮ԁ#x;#p+x3⸮#+p⸮⸮d!⸮⸮⸮⸮vOvN8⸮#3p#⸮⸮b0⸮⸮c0⸮⸮"!lH⸮⸮⸮(⸮⸮!"iH⸮⸮⸮#3p⸮⸮R0;⸮⸮s[#⸮x⸮⸮⸮⸮fI⸮aF⸮⸮(⸮0FO⸮⸮A⸮⸮⸮Ffa⸮⸮V⸮}⸮⸮⸮⸮ac⸮⸮⸮0⸮⸮⸮⸮[NT ⸮⸮⸮⸮2⸮a⸮⸮⸮RK
13:49:41.966 -> Dq!⸮⸮⸮⸮⸮UIp⸮⸮ x⸮⸮⸮K⸮RB⸮⸮"⸮qs2⸮IB
13:49:41.966 -> ⸮v⸮⸮! x"⸮⸮? ⸮"⸮⸮@ l"⸮⸮A k"⸮⸮B "ɲYq⸮r1x⸮⸮L⸮v⸮⸮ FF⸮K1"D6⸮⸮kN)⸮⸮⸮⸮=K⸮⸮N ⸮
13:49:42.031 -> ⸮⸮O :J⸮d+⸮⸮#3⸮⸮⸮#m⸮x ?⸮*L)H⸮⸮⸮#x+⸮"!'H⸮G⸮(?⸮Y⸮!"#H⸮9⸮d!A⸮d!*H⸮⸮⸮⸮⸮#x3G⸮#J⸮x!⸮⸮⸮⸮NO8⸮"!H⸮'⸮⸮"!H⸮⸮#;p⸮⸮d0;⸮⸮s[#⸮⸮⸮*⸮⸮⸮⸮a⸮⸮V⸮⸮⸮⸮ac⸮#⸮⸮b0⸮⸮c0⸮#;p⸮⸮⸮ ⸮ ⸮ @⸮ ⸮ s ⸮Bl j p ⸮ fNT ⸮⸮⸮⸮p⸮dKx⸮⸮ cK⸮⸮⸮L⸮⸮⸮K⸮⸮"0xYq⸮q⸮rs1⸮⸮⸮ fj
13:49:42.065 -> .⸮w⸮w(⸮⸮⸮rRw⸮⸮"⸮v⸮vZwx"⸮⸮U ⸮"⸮⸮V ⸮"⸮⸮W ⸮"OI⸮⸮X
13:49:42.065 -> x F2Ҳ
13:49:42.065 -> p⸮H⸮⸮⸮^ O⸮dD⸮2⸮⸮^ ⸮⸮\⸮#⸮⸮⸮⸮⸮⸮rR⸮v⸮⸮"wYw⸮v⸮⸮D ⸮⸮⸮⸮(⸮"=KO⸮⸮⸮pp⸮:L:H⸮⸮P⸮#x+⸮"!7H⸮x⸮(?⸮!"3H⸮j⸮i!r⸮i!1H/⸮
#⸮⸮!⸮⸮⸮/N⸮"!+H⸮_⸮б"!(H⸮S⸮#3p(N⸮⸮u0[#⸮⸮⸮⸮⸮`a⸮⸮⸮⸮s⸮⸮ac⸮⸮⸮+0⸮⸮W⸮#J3ppR⸮NT ⸮⸮⸮⸮⸮⸮K F⸮⸮ KRBѲ⸮⸮"⸮qs⸮⸮ Yq⸮w⸮⸮ ⸮~⸮r⸮⸮% ⸮~i!⸮⸮& ⸮⸮⸮⸮
13:49:42.127 -> #2⸮#+⸮⸮l j ⸮ n ⸮ ⸮ @] s 8⸮⸮⸮ 0F⸮B
F⸮9⸮⸮⸮D⸮⸮⸮x⸮#⸮⸮ 08⸮O⸮⸮@⸮⸮⸮H⸮⸮⸮⸮ P⸮⸮,@⸮!⸮⸮⸮⸮Kx*⸮"p"Kp⸮⸮ ⸮ ⸮!⸮⸮⸮⸮Kx*⸮"p"Kp⸮⸮ ⸮ !⸮⸮⸮⸮⸮ K
13:49:42.127 -> Ix *⸮⸮
13:49:42.127 -> "p"Kpi#J⸮;⸮⸮⸮⸮⸮⸮ (⸮⸮ ⸮ !⸮⸮⸮⸮⸮F@⸮⸮ ⸮B8⸮FA⸮X0⸮B(⸮F
13:49:42.127 -> "⸮⸮⸮⸮⸮"⸮⸮ "⸮⸮0^ ⸮⸮ ⸮⸮0⸮⸮ ⸮⸮ ⸮⸮ ⸮⸮ ⸮⸮⸮⸮⸮g⸮#jF@⸮1⸮⸮⸮]⸮⸮⸮I⸮⸮xHS⸮툍⸮0⸮#⸮⸮0#x⸮⸮02Ҳ*⸮⸮pp⸮⸮0⸮⸮0⸮⸮0⸮⸮0x⸮#p⸮+⸮+⸮^ ⸮⸮⸮⸮⸮3⸮#jF@⸮)1⸮^⸮⸮]⸮⸮⸮#⸮⸮⸮#⸮⸮ F#⸮⸮⸮0#^ ⸮⸮0⸮⸮0⸮⸮⸮⸮⸮⸮#@⸮;A⸮⸮?⸮⸮]⸮⸮⸮#⸮⸮⸮0⸮(#⸮0#⸮#"⸮!⸮⸮0⸮#^ ⸮⸮0⸮⸮0⸮⸮ ⸮⸮⸮⸮0⸮⸮ ⸮⸮o⸮⸮⸮⸮#jF@⸮?A⸮⸮⸮]⸮⸮#⸮⸮#⸮⸮#⸮⸮⸮J^ ⸮3⸮⸮⸮⸮⸮0
13:49:42.178 -> ⸮⸮0~#⸮⸮0#"⸮⸮0#⸮⸮ ⸮⸮ ⸮⸮ ⸮⸮0⸮⸮@⸮⸮⸮#jF@⸮EQ⸮⸮⸮⸮]⸮⸮⸮ @⸮S⸮Bѱ⸮S ⸮⸮⸮q⸮⸮⸮⸮F⸮pG0⸮!J!K⸮⸮⸮⸮# I!K!L⸮⸮!K!M⸮#⸮⸮0#x^ c⸮⸮⸮0+h 3kD⸮,⸮⸮ ⸮,⸮⸮ ⸮,⸮⸮ ⸮,⸮<⸮⸮ ⸮⸮0⸮⸮⸮⸮⸮p⸮#O⸮⸮a⸮⸮⸮+h3⸮+`#x3⸮#p ⸮0⸮((pV⸮VH⸮H F⸮(⸮ @⸮⸮#⸮B⸮8⸮FA⸮X3⸮B(⸮F$⸮⸮ ⸮⸮D⸮⸮^ ⸮⸮0⸮⸮⸮⸮⸮7⸮jF#O⸮ q⸮b⸮^ ⸮⸮@⸮⸮@⸮⸮⸮⸮⸮(⸮#jFO⸮"q⸮S⸮⸮⸮pGpG⸮K⸮⸮⸮⸮⸮⸮⸮ ⸮K⸮⸮⸮⸮⸮⸮⸮ ⸮K⸮⸮⸮⸮⸮ ⸮K⸮⸮⸮⸮⸮⸮⸮ KxpG⸮ ⸮FI⸮!⸮⸮⸮⸮
L⸮ ⸮⸮⸮⸮⸮] ⸮⸮b⸮⸮⸮⸮#jFd!⸮
13:49:42.247 -> ⸮T ⸮⸮⸮⸮v⸮⸮⸮ A ⸮o ⸮⸮b⸮(O⸮p⸮$$⸮⸮Z⸮⸮4n ⸮⸮U⸮⸮4⸮m ⸮⸮O⸮⸮4⸮] ⸮⸮@⸮⸮1⸮⸮⸮jF#O⸮⸮q⸮⸮⸮Jx3⸮p⸮⸮⸮ ⸮⸮⸮⸮⸮
13:49:42.247 -> "⸮⸮⸮⸮J⸮pG⸮⸮⸮⸮⸮K⸮pG⸮⸮⸮⸮⸮⸮
13:49:42.247 -> "⸮⸮⸮⸮J⸮"K⸮⸮⸮ H⸮⸮⸮⸮8@p⸮FNL0F⸮⸮N⸮! F⸮⸮⸮)F F⸮⸮⸮! F⸮⸮⸮F0F⸮⸮:⸮⸮⸮Czp⸮⸮T 8@p⸮FH
FF⸮⸮0⸮1F H⸮⸮⸮N%D⸮B⸮!0F⸮⸮⸮⸮⸮⸮H⸮⸮⸮p⸮T 8@⸮⸮F
F
13:49:42.383 -> O
13:49:42.383 -> L8F⸮⸮⸮! F⸮⸮1F F⸮⸮)F F⸮⸮8F⸮⸮⸮⸮⸮⸮T 8@⸮⸮! ⸮⸮⸮⸮$ ⸮⸮⸮⸮⸮⸮⸮(Ѐ! ⸮⸮⸮⸮<⸮⸮⸮⸮⸮⸮! ⸮⸮⸮⸮$ ⸮⸮⸮⸮⸮⸮⸮! ⸮⸮⸮⸮<⸮⸮⸮⸮⸮⸮⸮FFHF⸮⸮⸮⸮!H⸮h⸮1F
13:49:42.383 -> H⸮d⸮⸮⸮o,DM⸮(F⸮Z⸮⸮B⸮⸮H⸮⸮⸮⸮⸮⸮⸮T 8@⸮⸮FH
FFF⸮⸮⸮⸮9FH⸮C⸮/⸮H⸮=⸮⸮B⸮⸮1F H⸮7⸮N⸮⸮0F⸮/⸮⸮B⸮⸮H⸮⸮⸮⸮⸮⸮T 8@8⸮FM(F⸮⸮}⸮!FH⸮⸮(F⸮⸮r⸮8⸮T 8@8⸮ M L(F⸮⸮k⸮⸮! F⸮ ⸮! F⸮⸮F(F⸮⸮[⸮⸮8⸮T 8@8⸮ M L(F⸮⸮S⸮⸮! F⸮⸮⸮! F⸮⸮⸮F(F⸮⸮C⸮⸮8⸮T 8@-⸮⸮AFFF⸮⸮4⸮
L@F⸮⸮6⸮! F⸮⸮⸮9F F⸮⸮⸮1F F⸮⸮⸮)F F⸮⸮⸮@F⸮⸮⸮⸮⸮⸮⸮T 8@"C!, ⸮⸮⸮⸮⸮⸮⸮@C"+ F⸮⸮Ͽ"C!, ⸮⸮ʿ⸮#⸮⸮⸮⸮⸮0⸮⸮0⸮⸮0⸮⸮0⸮#⸮⸮0⸮#⸮⸮0⸮#$⸮⸮0⸮#⸮⸮@⸮⸮0⸮⸮@⸮⸮@⸮⸮@⸮⸮@⸮⸮@⸮⸮@⸮⸮@⸮⸮@⸮⸮ @⸮⸮
13:49:42.421 -> @⸮⸮@⸮⸮@⸮⸮
@⸮⸮@⸮⸮@⸮⸮@⸮⸮@⸮⸮@⸮⸮@⸮⸮@⸮⸮@⸮⸮@⸮⸮@⸮⸮f⸮⸮⸮⸮⸮#! ⸮⸮⸮⸮⸮'!$ ⸮⸮⸮⸮⸮jF! F⸮⸮⸮⸮! ⸮⸮⸮⸮⸮! ⸮⸮⸮⸮⸮! ⸮⸮⸮⸮⸮! ⸮⸮⸮⸮⸮! ⸮⸮⸮⸮⸮b ⸮⸮1⸮(⸮@!* ⸮⸮u⸮⸮!) ⸮⸮q⸮⸮!( ⸮⸮m⸮b ⸮⸮ ⸮X⸮N!* ⸮⸮e⸮⸮!) ⸮⸮a⸮⸮!( ⸮⸮]⸮⸮⸮⸮⸮⸮⸮⸮\ ⸮⸮⸮⸮⸮ ⸮ ⸮0⸮⸮⸮F⸮⸮⸮F⸮⸮3⸮k3⸮jF
!⸮ ⸮⸮⸮⸮-⸮⸮ ⸮⸮0,⸮!⸮⸮!p⸮⸮⸮⸮⸮⸮`` ⸮⸮0#r⸮⸮0cr⸮5⸮q⸮⸮0⸮r⸮⸮0⸮r⸮⸮0#s⸮⸮ 0cs⸮⸮
13:49:42.472 -> 0⸮s⸮⸮0⸮s⸮⸮0#t⸮0⸮⸮(⸮⸮jF
!⸮ ⸮⸮![ ⸮⸮!pc`⸮⸮)⸮
13:49:42.472 -> ⸮p⸮⸮⸮⸮p⸮⸮@C0
13:49:42.472 -> PpppG#@Pp
13:49:42.472 -> ⸮p⸮pppGp⸮%NF5pup⸮p⸮p⸮⸮⸮⸮K⸮xp⸮⸮2F!x`h⸮⸮⸮⸮@ 1F"z⸮ ⸮⸮8⸮⸮ ⸮⸮_⸮ p⸮yj⸮2F!x`h⸮⸮⸮⸮B 1F"z⸮ ⸮⸮%⸮⸮ ⸮⸮yk⸮2F!x`h⸮⸮⸮⸮D 1F"z⸮ ⸮⸮⸮⸮ ⸮⸮(F⸮⸮⸮% ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮}pG@⸮#⸮B⸮@⸮3s⸮B⸮@⸮#⸮B⸮S⸮⸮⸮⸮C ;⸮Sh⸮pGSxy⸮B8⸮F(;C⸮pGh⸮⸮CҲ⸮B8⸮F(;⸮⸮pG⸮FF I⸮⸮⸮I⸮s⸮I⸮⸮⸮⸮⸮aF⸮⸮@T ⸮⸮!⸮⸮⸮D⸮B@F0#⸮FjF⸮@⸮q1#@h⸮⸮JK`h⸮⸮#@⸮!jF#⸮⸮O⸮tQO⸮] ⸮⸮⸮⸮⸮⸮⸮W⸮#jF@⸮!⸮⸮⸮⸮⸮⸮9⸮⸮⸮z3۲+⸮r⸮]⸮⸮"⸮ir] ⸮⸮2⸮⸮⸮⸮⸮5⸮#jF@⸮!⸮`⸮⸮⸮K`pG⸮⸮-⸮⸮G⸮⸮m⸮⸮+LO⸮⸮8D⸮#F⸮bS⸮⸮B⸮⸮⸮⸮⸮⸮O⸮rO⸮⸮1hF⸮⸮⸮⸮⸮FmF&⸮⸮8F⸮⸮⸮⸮⸮⸮⸮.⸮⸮8F⸮⸮⸮⸮⸮F8F⸮⸮⸮⸮⸮⸮08F%⸮<⸮⸮k⸮6E⸮⸮⸮O⸮⸮qhF⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮?⸮ F⸮B⸮%`Z⸮5⸮⸮⸮⸮o⸮⸮⸮⸮⸮⸮⸮⸮
⸮m⸮⸮⸮⸮⸮⸮Ap⸮⸮⸮LD⸮⸮⸮O⸮⸮q F⸮⸮⸮⸮⸮7⸮B⸮⸮⸮f ⸮⸮⸮⸮⸮⸮(F⸮#⸮3⸮ah⸮⸮T⸮(F⸮x⸮⸮⸮⸮4⸮B⸮⸮ p⸮O⸮⸮0⸮⸮⸮⸮AK`pG⸮< 0⸮L#\⸮⸮
13:49:42.543 -> Kh}⸮
13:49:42.543 -> K
13:49:42.543 -> IJph⸮3⸮⸮U`"D⸮"T`0⸮0 < @ , ⸮ #FJ3+⸮⸮⸮pG⸮0 KxpG⸮@ K⸮⸮⸮yJS⸮10R⸮$ ⸮⸮⸮]F⸮H⸮⸮⸮⸮⸮t⸮Գ0⸮8⸮ Lch#⸮⸮⸮8@H⸮⸮⸮⸮%`h0⸮⸮5⸮⸮⸮⸮-⸮⸮8⸮⸮ @⸮pG⸮⸮0pG-⸮⸮O$⸮F4pO⸮ FO⸮⸮z⸮⸮⸮⸮)ܴ⸮⸮⸮E%⸮⸮eF⸮⸮⸮⸮⸮ݵ⸮⸮⸮E⸮ ⸮⸮⸮*y` ⸮⸮⸮ ⸮⸮⸮
13:49:42.703 -> ⸮`⸮⸮⸮⸮⸮⸮t'F⸮⸮5⸮⸮⸮⸮*⸮⸮24⸮⸮4x⸮⸮⸮,⸮⸮ ⸮⸮0⸮$#aCJ⸮⸮TRX⸮h⸮⸮2⸮⸮3⸮⸮3dh⸮⸮⸮"F⸮⸮t⸮⸮⸮⸮0⸮⸮⸮⸮⸮⸮pG⸮⸮FF⸮⸮t!FF⸮⸮⸮#9FF⸮⸮e⸮⸮t⸮⸮⸮(⸮⸮⸮,(⸮⸮⸮⸮⸮c)h0⸮⸮⸮jh⸮⸮⸮s⸮⸮⸮#⸮⸮,⸮⸮,5+⸮!⸮⸮t⸮⸮⸮⸮@⸮⸮⸮-⸮⸮OFO⸮⸮y⸮25⸮2</FKE⸮#O⸮
13:49:42.703 -> ⸮⸮3⸮⸮0⸮⸮*⸮<⸮F+⸮5⸮2#jF0F⸮⸮⸮⸮⸮⸮⸮⸮⸮2⸮⸮⸮⸮⸮⸮⸮Kx+⸮⸮⸮⸮⸮⸮⸮4⸮<⸮ ⸮⸮@*⸮⸮⸮⸮⸮⸮XC⸮<⸮,
13:49:42.764 -> ⸮⸮@;*⸮⸮ :⸮@⸮C⸮⸮⸮⸮⸮*⸮⸮⸮⸮⸮@⸮C⸮⸮⸮⸮L -⸮⸮OFF⸮F'O⸮⸮z⸮⸮⸮⸮⸮ ⸮⸮⸮#⸮#⸮SE ⸮⸮⸮⸮<⸮F+⸮⸮,⸮⸮5⸮⸮⸮⸮⸮!⸮⸮⸮⸮G⸮⸮*⸮⸮⸮24⸮⸮F'⸮⸮⸮⸮t/⸮⸮⸮⸮⸮⸮⸮(ڿKS⸮ pG⸮D ⸮F⸮⸮,5+⸮Z⸮⸮⸮ys⸮⸮⸮⸮⸮⸮⸮3⸮⸮t⸮#F⸮⸮⸮(⸮⸮⸮,5;⸮⸮,5⸮⸮⸮⸮,5;⸮!⸮⸮t⸮⸮⸮@⸮ξ⸮⸮⸮F&⸮Fv⸮⸮&h⸮⸮⸮⸮⸮@⸮⸮Fb⸮v⸮⸮[R⸮⸮⸮⸮⸮⸮⸮#;`*h2*`〣⸮c⸮#⸮⸮⸮-⸮⸮A#FO⸮⸮x⸮⸮t.J⸮⸮3⸮B⸮⸮,K⸮⸮w⸮⸮⸮:⸮&%⸮⸮⸮#⸮5⸮2⸮AE.F⸮⸮⸮⸮C*#⸮⸮⸮iF F⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮2⸮⸮%⸮4V⸮⸮p⸮⸮B⸮O⸮C⸮6⸮3kD*#⸮⸮⸮iF⸮⸮⸮⸮ F⸮⸮⸮⸮⸮⸮5⸮⸮⸮x3kD⸮⸮a#⸮⸮iF F⸮⸮⸮⸮z⸮⸮⸮⸮⸮⸮⸮d@`@⸮⸮p%⸮*
13:49:42.829 -> ⸮⸮B2⸮⸮4⸮⸮p%⸮⸮⸮⸮ ⸮ ⸮⸮"⸮⸮p%⸮⸮⸮O⸮⸮p#⸮⸮r⸮⸮qKs⸮tKv⸮w⸮⸮%0⸮⸮+0⸮⸮1021⸮B⸮⸮pG⸮FF⸮⸮⸮⸮ F⸮⸮q⸮⸮⸮⸮ F⸮⸮@⸮⸮[⸮#⸮⸮Z⸮⸮B⸮23⸮⸮⸮⸮⸮ ⸮-⸮⸮C⸮⸮o⸮F⸮⸮vFF⸮F2⸮?/3⸮ .4⸮F⸮⸮⸮⸮8⸮O⸮⸮rHF⸮⸮⸮⸮h⸮⸮⸮⸮0⸮⸮0+⸮0⸮⸮3%н⸮(0⸮C⸮qFqO⸮⸮q ⸮23⸮2\F⸮B⸮⸮⸮⸮⸮⸮2⸮ݽ⸮⸮⸮O⸮⸮0⸮⸮o⸮⸮⸮o⸮⸮⸮o⸮⸮⸮o⸮⸮⸮⸮⸮⸮@⸮⸮⸮⸮4F
13:49:42.829 -> FF⸮⸮⸮⸮⸮⸮0⸮⸮⸮⸮⸮$PF⸮⸮⸮⸮5F
13:49:42.829 -> F⸮⸮q⸮⸮⸮⸮F F⸮⸮⸮⸮(F⸮0⸮⸮⸮⸮⸮pF⸮⸮S+F$⸮⸮x⸮(I⸮B⸮⸮B⸮⸮⸮D⸮#x@+⸮ah⸮⸮⸮⸮p⸮###p#"F0F⸮⸮x⸮⸮a⸮⸮⸮⸮@⸮⸮⸮⸮"+⸮⸮⸮⸮⸮⸮C#``⸮⸮⸮@S⸮⸮⸮_"⸮⸮x⸮)⸮#x@+⸮⸮eh⸮⸮
13:49:42.902 -> ⸮⸮,⸮-⸮⸮⸮}⸮⸮⸮⸮⸮(⸮ڀ##p0##q#cq #⸮q#⸮q⸮⸮⸮⸮⸮⸮⸮⸮##p##qcq#⸮⸮-⸮⸮OFFO⸮⸮⸮萋⸮#⸮
⸮⸮⸮⸮⸮"⸮⸮t⸮⸮⸮⸮⸮⸮(WЕ⸮x5⸮⸮⸮c⸮Bѝ⸮0+⸮!F(F⸮⸮r⸮⸮⸮⸮0+⸮⸮(F⸮⸮q⸮⸮⸮⸮⸮⸮⸮
13:49:42.902 -> ⸮⸮'F)⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮<⸮⸮+⸮⸮ ⸮⸮ ;9"⸮⸮4⸮⸮@[⸮⸮⸮O⸮c⸮⸮⸮⸮YF4⸮<H⸮ز⸮⸮ ⸮⸮⸮
13:49:42.902 -> */⸮⸮⸮⸮⸮ز⸮⸮\⸮⸮⸮!FF⸮⸮05⸮G⸮⸮⸮⸮⸮⸮⸮L -⸮⸮A$F⸮F&FDE⸮U⸮⸮y⸮)hF⸮⸮W⸮4⸮⸮0F⸮⸮⸮⸮ -⸮⸮OF⸮⸮⸮2⸮O⸮⸮s4⸮2⸮⸮⸮E6⸮2#'O⸮⸮⸮⸮⸮0 ⸮
13:49:42.902 -> ⸮⸮*⸮⸮⸮⸮⸮⸮3⸮⸮⸮⸮E"⸮&⸮⸮S⸮⸮7⸮⸮⸮3⸮⸮⸮⸮⸮O⸮⸮3*⸮i⸮⸮ *.⸮ݸ⸮⸮"⸮⸮5⸮24[⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮0⸮⸮⸮FF
F⸮⸮⸮⸮⸮⸮3F)F⸮ F⸮⸮⸮⸮F F⸮⸮⸮3F*F F⸮⸮⸮⸮⸮8F⸮⸮p⸮
13:49:43.015 -> F
FFF⸮⸮⸮⸮*FF⸮⸮q F⸮⸮⸮⸮0Dp⸮-⸮⸮GFO⸮⸮y⸮24⸮2<'FKEФ⸮0
13:49:43.015 -> ⸮⸮*⸮<⸮F+
13:49:43.015 -> ⸮i⸮⸮*%⸮<⸮⸮ݿ⸮⸮⸮⸮2⸮ݽ⸮⸮⸮-⸮⸮GFO⸮⸮y⸮24⸮2<'FKEФ⸮0
13:49:43.015 -> ⸮⸮*⸮<⸮F+⸮5⸮⸮⸮⸮⸮⸮⸮
13:49:43.015 -> ⸮⸮*%⸮⸮⸮ݿ⸮⸮⸮⸮2⸮ݽ⸮⸮⸮⸮⸮⸮KD⸮⸮⸮⸮⸮A⸮⸮F⸮⸮⸮⸮"FFO⸮⸮6!O:p⸮bS⸮⸮B⸮⸮⸮⸮{⸮⸮K⸮ ⸮>⸮6⸮(F⸮⸮⸮⸮⸮v!F F⸮⸮{⸮1F F⸮⸮w⸮"F)F}# F⸮⸮⸮⸮2F⸮⸮q}# F⸮⸮⸮⸮#⸮⸮zq⸮ F⸮⸮⸮⸮⸮.⸮!F F⸮⸮⸮⸮1F F⸮⸮⸮⸮#;p⸮⸮L p⸮F⸮⸮⸮⸮F⸮⸮⸮c⸮9⸮⸮!(F⸮C⸮⸮B⸮}")F F⸮⸮v⸮⸮⸮⸮}"0F⸮⸮q⸮⸮⸮⸮!F F⸮⸮]⸮ F1F⸮⸮Y⸮ p⸮ ⸮⸮-⸮⸮A&FFFTK⸮⸮t⸮⸮05⸮⸮⸮c⸮⸮,e⸮⸮pe⸮F⸮⸮ ⸮ F⸮⸮⸮⸮MK⸮B⸮⸮⸮c⸮BX⸮#⸮⸮t⸮⸮x5⸮⸮AF F⸮⸮)⸮ F⸮⸮r⸮⸮⸮t!⸮⸮⸮⸮t!⸮⸮ F⸮⸮⸮⸮U⸮O⸮s"1F:H⸮⸮⸮O⸮q8H⸮⸮O⸮s"!4H⸮⸮⸮ ⸮⸮⸮! ⸮⸮⸮ ⸮⸮⸮! ⸮⸮ ⸮⸮⸮! ⸮⸮)K`⸮⸮O⸮c")F'H⸮⸮O⸮a$H⸮⸮⸮O⸮S"!!H⸮⸮=⸮ #"1FH⸮⸮ !H⸮⸮⸮@#"!H⸮⸮⸮@ ⸮⸮⸮⸮!@ ⸮⸮⸮A ⸮z⸮⸮!A ⸮⸮⸮? ⸮s⸮⸮!? ⸮}⸮K\`}⸮O⸮S")FH⸮k⸮O⸮QH⸮⸮O⸮S⸮⸮⸮IXd@@D @K!h⸮⸮_⸮⸮D K!h⸮⸮W⸮⸮D Kh⸮⸮~⸮D K!Xh⸮⸮I⸮⸮D K!Xh⸮⸮A⸮⸮D KXh⸮⸮h⸮D ⸮⸮⸮⸮}⸮V⸮7⸮⸮⸮⸮⸮⸮1⸮⸮⸮⸮⸮@⸮+⸮⸮⸮⸮⸮⸮⸮p@⸮"⸮⸮⸮|pG⸮FFI⸮l⸮I⸮⸮⸮-⸮⸮⸮T ⸮⸮@⸮⸮λ⸮⸮D⸮B⸮FD ⸮⸮⸮⸮(⸮⸮Kx ⸮Kx⸮Kp⸮⸮X W ⸮ ;⸮⸮⸮o⸮⸮⸮⸮۳⸮⸮o⸮@⸮pGo⸮pG pG⸮⸮⸮⸮F⸮Sxx⸮ C⸮G⸮⸮q⸮⸮⸮⸮ۺ⸮B⸮#⸮⸮⸮y⸮⸮##⸮t⸮@⸮ZS⸮Bѐx⸮⸮⸮⸮⸮⸮Px⸮⸮⸮⸮ ⸮⸮⸮@⸮yc⸮B⸮ K"p⸮⸮⸮d⸮⸮Sy⸮+⸮K⸮⸮+⸮⸮Jp⸮⸮⸮X W #⸮&⸮qD⸮"⸮⸮⸮⸮⸮O⸮O⸮O⸮⸮⸮⸮C⸮⸮۲⸮⸮K@:⸮ҥB⸮⸮⸮q⸮-⸮⸮CFD ⸮⸮⸮(F@⸮X⸮#⸮⸮0⸮# ⸮I⸮J⸮⸮0x⸮⸮⸮`⸮⸮0⸮C3۲+Rx⸮⸮pp⸮⸮⸮!hF⸮⸮ ⸮⸮`⸮⸮⸮⸮] ⸮⸮⸮⸮⸮⸮f⸮O⸮q#jF⸮⸮⸮⸮⸮#⸮⸮0#-⸮⸮0⸮#ゴ⸮0hF⸮b⸮⸮⸮⸮⸮_/⸮#⸮⸮"⸮<⸮
13:49:43.218 -> C⸮⸮ ⸮J4⸮⸮⸮0⸮⸮0x'⸮3۲+⸮⸮#pD#-⸮⸮0⸮⸮#0#A⸮⸮⸮⸮!⸮⸮0⸮⸮i⸮] ⸮⸮⸮⸮⸮⸮⸮#jFO⸮⸮q⸮⸮I⸮N ⸮⸮⸮⸮DH ⸮⸮⸮⸮⸮⸮⸮#⸮?C⸮+⸮⸮0@#nN⸮⸮D⸮"$⸮⸮⸮@4x@⸮ ⸮⸮@4⸮!䲍⸮hF⸮⸮ ⸮⸮0⸮⸮p⸮⸮3⸮,O⸮]⸮⸮4p7p⸮⸮g⸮⸮⸮⸮⸮jF@⸮⸮#⸮⸮⸮#$⸮⸮0⸮#] ⸮⸮0⸮⸮@⸮⸮@⸮⸮@⸮⸮@⸮⸮@⸮⸮K⸮⸮⸮⸮⸮jF#@⸮Q⸮⸮⸮⸮n#⸮⸮0
13:49:43.218 -> #⸮⸮0#⸮⸮0⸮#GO⸮!>xhF⸮⸮`6⸮⸮⸮⸮0⸮⸮@⸮⸮@⸮⸮⸮⸮.O⸮]⸮⸮>p<p⸮⸮!⸮⸮⸮⸮⸮#jFO⸮⸮q⸮⸮⸮⸮. ⸮⸮⸮O⸮d⸮⸮⸮⸮4N@D0pH ⸮⸮⸮⸮⸮Ȑ2O⸮⸮- ⸮⸮⸮-0L8⸮⸮4 ⸮⸮⸮⸮8⸮3x⸮+4⸮c+⸮⸮⸮⸮⸮1⸮d##p0#⸮⸮0#x⸮ ⸮⸮0 #⸮⸮0⸮#⸮⸮0<#!!J⸮⸮0x⸮⸮⸮⸮03⸮&[۲+O⸮]⸮⸮pp⸮⸮⸮⸮⸮⸮⸮⸮K⸮#jFO⸮⸮q⸮⸮v⸮⸮⸮⸮⸮⸮⸮#3p⸮⸮ ;⸮⸮B⸮3x⸮⸮#x;⸮⸮N#⸮⸮0@#⸮⸮⸮R D⸮M N O \ T Z V P ⸮#s⸮⸮⸮0@#⸮⸮0⸮#⸮⸮0⸮#⸮⸮0⸮#&1M⸮⸮0,x⸮!D⸮4hF䲍⸮0⸮⸮`⸮⸮C⸮,O⸮]⸮⸮,p.p⸮⸮w⸮⸮⸮⸮⸮jF@⸮[Q#⸮⸮⸮#⸮⸮0v#$⸮⸮0#] ⸮⸮0⸮⸮@⸮⸮@⸮⸮@⸮⸮@⸮⸮@⸮⸮X⸮⸮⸮⸮⸮jF@⸮Q#⸮⸮⸮⸮=#⸮⸮0⸮#⸮⸮0⸮#⸮⸮0d#⸮⸮0⸮#⸮⸮0#⸮⸮02#] ⸮⸮0⸮⸮@⸮⸮6⸮⸮⸮⸮⸮#jF@⸮Q⸮⸮⸮⸮⸮p⸮Q ⸮⸮@⸮DCQ⸮⸮⸮⸮⸮⸮⸮FD ⸮⸮⸮(⸮ F⸮⸮@⸮⸮⸮⸮⸮⸮⸮Fi ⸮⸮
⸮+NF3x(⸮C⸮3p⸮s⸮F8F⸮⸮⸮⸮-1- ⸮3x;⸮!i ⸮⸮⸮ ⸮⸮⸮⸮$⸮l ⸮⸮
⸮H⸮⸮@⸮⸮⸮@Cɲm ⸮⸮⸮H⸮⸮6⸮⸮⸮Cɲn ⸮⸮⸮⸮H⸮⸮,⸮⸮⸮⸮Cɲo ⸮⸮⸮⸮H⸮⸮"⸮⸮⸮Cɲp ⸮⸮⸮⸮⸮⸮@q ⸮⸮⸮⸮ H⸮⸮⸮⸮⸮⸮@Fr ⸮⸮⸮d ⸮ L \ ⸮ -⸮⸮An ⸮⸮⸮⸮F ⸮⸮⸮⸮FZ ⸮⸮⸮⸮F?H⸮⸮⸮⸮⸮>H⸮⸮⸮⸮⸮⸮U ⸮⸮⸮⸮V ⸮⸮⸮⸮⸮!hF⸮⸮b⸮!F⸮⸮⸮]⸮T⸮/:⸮ ⸮⸮]⸮9FY ⸮⸮⸮⸮ 8⸮,V⸮/K⸮(E⸮!⸮⸮⸮o⸮!FF⸮⸮⸮j⸮9F⸮F⸮⸮!F⸮⸮⸮⸮D F!I⸮⸮⸮⸮⸮ ⸮⸮5⸮AF8F⸮⸮I⸮⸮8F⸮⸮(⸮Kh⸮⸮s[⸮-⸮⸮2F!⸮⸮⸮b⸮⸮⸮⸮⸮⸮@F⸮⸮(⸮K[h⸮⸮s[⸮-⸮⸮2F!⸮⸮⸮ ⸮⸮⸮⸮⸮⸮ ⸮⸮⸮⸮⸮ ⸮⸮⸮⸮⸮⸮ ⸮⸮⸮ ⸮ AHB s⸮FZ ⸮⸮⸮⸮D⸮ ⸮⸮⸮⸮⸮O⸮⸮6&-⸮⸮⸮⸮k⸮(⸮)KV!FZ ⸮⸮⸮⸮p⸮ ⸮⸮⸮⸮(⸮o ⸮⸮⸮@⸮p ⸮⸮⸮⸮(⸮O⸮⸮4$⸮⸮p ⸮⸮⸮⸮(⸮⸮$⸮礬nr ⸮⸮⸮⸮⸮O⸮o⸮⸮⸮⸮⸮X⸮o ⸮⸮⸮⸮⸮⸮p ⸮⸮⸮⸮(⸮⸮tBd⸮⸮⸮p ⸮⸮⸮⸮(⸮⸮⸮⸮⸮⸮⸮⸮Fp ⸮⸮⸮⸮⸮B⸮⸮o ⸮⸮⸮⸮(⸮p ⸮⸮⸮⸮(⸮⸮⸮⸮4F⸮⸮⸮L⸮-⸮⸮O`KFhF⸮⸮⸮^I⸮⸮FFH ⸮⸮⸮⸮[Kh⸮⸮⸮XI⸮⸮⸮⸮FFI ⸮⸮⸮⸮VKh⸮⸮⸮RI⸮⸮⸮F⸮FJ ⸮⸮⸮⸮QKh⸮⸮⸮LI⸮⸮⸮FN ⸮⸮⸮⸮MKh⸮⸮⸮GI⸮⸮⸮FM ⸮⸮⸮⸮HKh⸮⸮⸮AI⸮⸮⸮FO ⸮⸮⸮⸮DKh⸮⸮CI⸮⸮FP ⸮⸮⸮⸮ ⸮⸮W⸮⸮F$ ⸮⸮S⸮O⸮|Q⸮F@F⸮⸮⸮IF⸮⸮⸮IFF@F⸮⸮⸮!F⸮⸮⸮⸮FF8F⸮⸮⸮GF9FK ⸮⸮]⸮D ⸮⸮,⸮F-H⸮⸮}⸮⸮⸮⸮+I⸮⸮⸮Fh ⸮⸮M⸮YF F⸮⸮⸮⸮⸮16b. ⸮%K⸮⸮h⸮⸮#K⸮⸮h⸮⸮D !⸮⸮)⸮ ⸮⸮⸮⸮/⸮O⸮|QPF⸮⸮!F⸮j⸮⸮⸮⸮i⸮⸮⸮u⸮B⸮M(F⸮⸮G⸮P⸮⸮⸮(h⸮v⸮ ⸮⸮⸮⸮!D ⸮⸮⸮ F⸮⸮⸮⸮P zDT X L D H @ aE4 RC⸮ ⸮ 7⸮F ⸮⸮⸮⸮⸮B<MO⸮]⸮⸮⸮⸮⸮⸮⸮(`⸮⸮
⸮⸮⸮⸮⸮⸮⸮H ⸮⸮⸮⸮⸮⸮F⸮⸮⸮⸮⸮N ⸮⸮⸮⸮!⸮⸮⸮(E⸮N ⸮⸮⸮⸮⸮A⸮⸮⸮⸮⸮⸮⸮⸮q⸮⸮⸮q⸮⸮⸮⸮⸮e ⸮⸮⸮⸮F ⸮⸮⸮⸮⸮⸮⸮F(F⸮⸮⸮!F⸮⸮⸮ ⸮⸮
13:49:43.519 -> ⸮⸮f⸮f ⸮⸮u⸮F ⸮⸮q⸮⸮⸮⸮F(F⸮⸮⸮!F⸮⸮⸮⸮⸮ ⸮⸮Q⸮⸮L(F!F⸮⸮P⸮⸮⸮⸮⸮⸮⸮i⸮⸮N ⸮⸮a⸮F⸮⸮ L(F!F⸮⸮⸮(⸮⸮Y ⸮⸮⸮z⸮⸮⸮0⸮⸮⸮ ⸮⸮⸮B8⸮ H⸮⸮⸮⸮FH⸮⸮⸮⸮F)FU ⸮⸮U⸮!F⸮⸮8@V ⸮⸮O⸮⸮⸮ ⸮ 8⸮+ ⸮⸮.⸮FO ⸮⸮*⸮!⸮o⸮⸮O ⸮⸮#⸮⸮@I⸮⸮⸮!F⸮y⸮FH⸮⸮
13:49:43.519 -> MF)F⸮x⸮KP⸮`hQ ⸮⸮8@⸮⸮/⸮O ⸮⸮⸮⸮⸮`⸮⸮⸮⸮B` -⸮⸮C⸮⸮
F⸮⸮4⸮FF⸮⸮N⸮L⸮⸮⸮I h⸮⸮⸮⸮⸮⸮⸮I h⸮⸮⸮⸮⸮BF⸮⸮s⸮SjI+F h⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮I⸮⸮⸮h P⸮U⸮]⸮Y⸮p⸮FF⸮⸮⸮⸮ !F⸮⸮E⸮x+⸮I F⸮⸮p@⸮⸮⸮⸮#!⸮;⸮⸮⸮F(F⸮⸮⸮⸮⸮(⸮1F⸮⸮⸮⸮⸮I⸮⸮I⸮⸮*F F⸮⸮p@I⸮⸮p⸮n⸮⸮⸮⸮⸮⸮⸮-⸮⸮CFF⸮⸮b⸮F⸮⸮D⸮⸮⸮D⸮,! F⸮⸮⸮#xFp F⸮⸮⸮⸮⸮(
⸮⸮⸮p⸮IFF,F0F⸮⸮H⸮,/⸮{⸮н⸮⸮⸮"FAF⸮⸮⸮⸮⸮+⸮-⸮⸮AFF⸮⸮4⸮ !⸮F⸮⸮⸮⸮xF+⸮I(F⸮⸮⸮A⸮⸮'⸮'p@F⸮⸮⸮⸮⸮(F⸮cx!+
13:49:44.063 -> ⸮~+⸮/+⸮aH⸮⸮⸮⸮ ⸮
I⸮⸮'⸮⸮⸮!0F⸮⸮⸮⸮⸮ I⸮⸮⸮⸮⸮⸮⸮⸮BF(F⸮⸮⸮AI⸮⸮⸮⸮⸮ش⸮⸮⸮⸮⸮⸮-⸮⸮OF⸮⸮F⸮⸮⸮⸮F⸮⸮⸮⸮ !F F⸮⸮⸮⸮x3⸮(F.I⸮⸮⸮⸮O⸮⸮ں'⸮F⸮⸮⸮⸮D,! F⸮⸮⸮⸮⸮F⸮⸮⸮⸮⸮⸮ F⸮⸮/⸮TF⸮(⸮⸮⸮⸮kD⸮7⸮⸮0,+⸮ /⸮⸮(F⸮⸮⸮⸮⸮⸮l⸮⸮⸮l⸮(F⸮⸮⸮⸮F⸮. ⸮r⸮⸮⸮⸮⸮⸮IF(F⸮⸮⸮⸮⸮⸮BF⸮⸮H⸮
⸮⸮B⸮⸮⸮⸮⸮⸮⸮⸮FQF(F⸮⸮⸮⸮4JF⸮⸮(FI⸮⸮⸮⸮s⸮⸮>⸮⸮⸮⸮.⸮״⸮⸮B⸮մ-⸮⸮OF⸮⸮F⸮⸮o⸮x6I F⸮&⸮⸮h⸮O⸮ ⸮⸮̐⸮⸮̠⸮⸮̰⸮⸮8F⸮⸮⸮⸮F8F⸮⸮⸮⸮⸮⸮h+B⸮kh⸮h8F⸮⸮⸮⸮n⸮⸮BF⸮⸮⸮ FIF⸮⸮C⸮ ⸮⸮⸮⸮
⸮⸮⸮⸮9F⸮
13:49:44.063 -> ⸮⸮⸮⸮⸮⸮⸮⸮⸮'JK F)⸮F⸮
⸮I⸮⸮⸮⸮⸮
13:49:44.063 -> #⸮⸮!⸮8F⸮⸮⸮⸮⸮⸮⸮+hYF⸮ki F⸮⸮⸮#⸮⸮⸮O⸮,6⸮.⸮⸮ FI⸮⸮⸮⸮O⸮⸮⸮QF F⸮⸮⸮⸮⸮⸮R⸮T⸮ ⸮⸮⸮L⸮G⸮z⸮⸮-⸮⸮OF⸮⸮F⸮⸮⸮⸮⸮⸮⸮⸮⸮p⸮[M ,`⸮⸮⸮⸮ZI⸮⸮H⸮#+`⸮⸮⸮⸮⸮⸮⸮c⸮ ⸮⸮w⸮⸮⸮g⸮SI F⸮⸮⸮⸮O⸮⸮ȹ !⸮⸮w⸮x⸮NI⸮⸮⸮⸮⸮⸮ !F⸮⸮m⸮xF⸮⸮⸮d⸮⸮%8F⸮⸮⸮V[⸮⸮⸮F0F⸮⸮⸮⸮⸮/F⸮AI⸮⸮⸮d
⸮(F⸮⸮F⸮9F⸮⸮⸮F<I F⸮⸮⸮⸮O⸮⸮⸮⸮⸮F
⸮ !0F⸮⸮@⸮x⸮F⸮-⸮⸮0F⸮⸮⸮⸮⸮k⸮-,⸮X⸮!0F⸮⸮⸮O⸮⸮⸮⸮⸮⸮ ⸮⸮⸮t⸮5-F⸮⸮⸮⸮⸮⸮⸮tO⸮⸮⸮⸮⸮⸮⸮⸮
13:49:44.063 -> ⸮3FJF9F⸮⸮Z⸮⸮]⸮C+⸮⸮⸮⸮K⸮%⸮⸮⸮⸮⸮⸮3FJF9F⸮⸮Z⸮⸮W⸮⸮⸮JFI⸮⸮2FI⸮⸮*FI⸮⸮JFI⸮⸮Ik⸮JKI(ȿFF F⸮⸮⸮⸮O⸮⸮-⸮⸮h ⸮o ⸮B⸮.⸮U⸮j⸮~⸮⸮⸮⸮⸮ζa⸮״⸮⸮F ⸮⸮⸮⸮⸮⸮⸮⸮I F⸮⸮⸮⸮⸮⸮⸮IF F⸮⸮@⸮⸮⸮⸮⸮$⸮⸮F⸮⸮⸮⸮8⸮⸮⸮⸮⸮I F⸮⸮@⸮⸮⸮I⸮⸮⸮@⸮T⸮⸮⸮I⸮x⸮+⸮"Kpx⸮+⸮"KppG⸮m ⸮⸮FH ⸮⸮⸮⸮F- ⸮⸮⸮⸮F. ⸮⸮⸮⸮FD ⸮⸮⸮⸮⸮⸮`⸮⸮P⸮⸮&⸮⸮%⸮⸮@⸮⸮$⸮⸮@⸮⸮L⸮⸮`⸮⸮P⸮E ⸮⸮⸮⸮(⸮#xc⸮_⸮⸮0#xa 3۲+⸮⸮##p⸮⸮⸮⸮⸮⸮9⸮#jF@⸮ ⸮⸮d⸮⸮⸮#xc⸮?⸮⸮⸮l ⸮Fx{ ⸮⸮⸮⸮z ax⸮⸮⸮⸮⸮x| ⸮⸮⸮⸮⸮!y K⸮} p⸮⸮⸮⸮⸮yKI⸮ ⸮⸮⸮⸮⸮⸮yKp⸮⸮⸮ z w 8⸮
13:49:44.063 -> %⸮⸮FI⸮⸮⸮⸮ I ⸮⸮⸮⸮⸮⸮~ I⸮⸮⸮⸮I ⸮⸮⸮⸮#xJ⸮ p!xK⸮⸮p⸮ ⸮⸮8@⸮⸮⸮⸮q p 8⸮
13:49:44.063 -> %⸮FI⸮⸮⸮⸮ I ⸮⸮o⸮a⸮⸮ I⸮⸮⸮⸮I ⸮⸮g⸮cyI⸮⸮pI⸮ "yp
13:49:44.063 -> I⸮p I⸮⸮
13:49:44.063 -> pJ⸮pJ⸮⸮p8⸮⸮o v t r n u
13:49:44.063 -> #⸮⸮FI⸮⸮⸮⸮ I ⸮⸮5⸮⸮yJ⸮⸮p⸮⸮s ⸮F⸮x⸮ ⸮⸮⸮%⸮⸮x⸮ ⸮⸮@⸮⸮⸮⸮s⸮H ⸮⸮⸮⸮⸮DH ⸮⸮⸮⸮FN ⸮⸮⸮⸮⸮35
13:49:44.063 -> EC3 ⸮⸮⸮⸮⸮[⸮⸮⸮⸮0
13:49:44.063 -> ⸮⸮0e#0⸮⸮0x⸮a2⸮⸮⸮⸮⸮P⸮⸮@⸮⸮-` $
13:49:44.187 -> ⸮⸮0⸮⸮P⸮⸮@⸮⸮⸮⸮⸮⸮C⸮#jFO⸮q⸮⸮n⸮Jx3۲+⸮p⸮p⸮#p|"⸮⸮0⸮⸮ ⸮⸮0⸮"⸮#` ⸮⸮ ⸮⸮0⸮⸮⸮⸮⸮⸮ ⸮#jF@⸮⸮⸮K⸮⸮⸮⸮⸮ -⸮⸮C⸮K⸮$x` ;+⸮⸮⸮#⸮#⸮⸮0⸮K⸮⸮@x⸮⸮@⸮⸮0⸮⸮@⸮⸮@⸮⸮@⸮⸮z⸮⸮⸮⸮⸮jF@⸮⸮!#⸮⸮!⸮3 ⸮⸮o⸮,#⸮⸮0⸮#O⸮⸮⸮0'⸮#@⸮⸮` ⸮⸮0⸮⸮⸮⸮⸮@⸮⸮p⸮⸮@⸮⸮U⸮⸮⸮⸮⸮jF@⸮2A#⸮⸮⸮⸮P#%⸮⸮0#` ⸮⸮0⸮⸮P⸮⸮P⸮⸮P⸮⸮P⸮⸮P⸮⸮P⸮⸮7⸮⸮⸮⸮⸮jF@⸮Q#⸮⸮⸮⸮O⸮@ ⸮#<&` ⸮⸮0⸮⸮P⸮⸮P⸮⸮P⸮⸮P⸮⸮`⸮⸮@⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮jFO⸮⸮a#⸮⸮⸮⸮ #` ⸮⸮0⸮⸮⸮⸮⸮⸮⸮⸮P⸮⸮P⸮⸮P⸮⸮P⸮⸮P⸮⸮⸮⸮⸮⸮x⸮#jFO⸮⸮a⸮⸮⸮⸮]Jx3۲+⸮p⸮⸮⸮⸮⸮pYJ` h⸮⸮P3`⸮⸮0⸮#⸮⸮0#⸮⸮P⸮⸮0⸮⸮P⸮⸮⸮⸮⸮⸮P⸮jFO⸮Jq#⸮⸮{⸮⸮#` ⸮⸮0⸮⸮@⸮⸮⸮⸮⸮⸮@⸮jFO⸮zq;F⸮⸮k⸮⸮#⸮⸮0⸮#⸮⸮0⸮#⸮⸮0C#⸮'⸮⸮0⸮#` ⸮⸮0⸮⸮p⸮⸮`⸮⸮@⸮⸮⸮⸮⸮⸮⸮#jF@⸮⸮1⸮⸮J⸮3Jx3۲+⸮⸮p⸮"` ⸮⸮ ⸮⸮0⸮⸮P⸮⸮@⸮⸮@⸮⸮@⸮⸮@⸮⸮@⸮⸮⸮⸮⸮⸮⸮⸮jFO⸮?q#⸮⸮'⸮⸮#⸮⸮0⸮⸮0⸮#⸮⸮0#` ⸮⸮0⸮⸮@⸮⸮@⸮⸮@⸮⸮@⸮⸮b⸮⸮⸮⸮⸮jFO⸮(q#⸮⸮ ⸮⸮#` ⸮⸮0⸮⸮@⸮⸮@⸮⸮p⸮⸮@⸮⸮@⸮⸮@⸮⸮@⸮⸮F⸮⸮⸮⸮⸮#jFO⸮hq⸮⸮⸮⸮O⸮⸮⸮ ⸮ ~ ⸮ _#⸮⸮$⸮⸮0#` ⸮⸮0⸮⸮0⸮⸮0⸮⸮0⸮⸮@⸮⸮@⸮⸮@⸮⸮⸮⸮⸮⸮⸮#jF<!⸮⸮⸮⸮+ ⸮⸮⸮bJ⸮⸮h⸮⸮ ⸮⸮`^J⸮⸮x]J` xB⸮⸮⸮ [JxB⸮ ⸮⸮0XK⸮⸮ XJ⸮⸮0x⸮⸮0C⸮⸮⸮0SKx⸮⸮0⸮⸮⸮⸮⸮⸮^⸮jF@⸮⸮1#⸮⸮⸮⸮?!
+⸮#⸮⸮0#⸮⸮0#⸮⸮0i#⸮⸮0&#⸮⸮0⸮#⸮⸮0K#` ⸮⸮0⸮⸮@⸮⸮⸮⸮⸮⸮<⸮jF@⸮1A#⸮⸮g⸮⸮#⸮⸮0(#D ⸮⸮0⸮⸮⸮⸮(⸮⸮#O⸮D⸮⸮⸮0⸮⸮⸮⸮(⸮⸮#⸮⸮0#⸮⸮0⸮#⸮⸮05#⸮⸮00#⸮⸮0⸮#` ⸮⸮0⸮⸮⸮⸮⸮⸮
13:49:44.340 -> ⸮#jF@⸮/⸮⸮5⸮#Kx+2⸮H ⸮⸮⸮⸮@⸮⸮}#⸮⸮0K⸮⸮⸮
13:49:44.340 -> ⸮⸮0
13:49:44.340 -> ⸮⸮0K⸮⸮⸮` ⸮⸮0
13:49:44.340 -> ⸮⸮0⸮#⸮⸮0⸮⸮_⸮⸮⸮⸮⸮#jF@⸮⸮!⸮⸮⸮D ⸮⸮T⸮D ⸮⸮Q⸮⸮⸮A⸮6⸮⸮ x ⸮ ⸮ ⸮ ⸮ ⸮ ⸮ ⸮ ⸮ p⸮H ⸮⸮4⸮⸮⸮- ⸮⸮0⸮⸮⸮1 ⸮⸮,⸮F~ ⸮⸮(⸮K⸮⸮x⸮Bȿpx⸮*⸮⸮⸮"px⸮⸮⸮B⸮⸮px⸮*⸮⸮"pJ⸮BxJx
13:49:44.436 -> ⸮H⸮⸮⸮x2p⸮ ⸮⸮p@x⸮⸮"⸮⸮B⸮⸮x⸮⸮2p(⸮x⸮⸮2p)⸮⸮x:⸮⸮⸮⸮ o s Jx;⸮⸮⸮ppG#pJ⸮;⸮
13:49:44.436 -> J⸮;⸮ Jx;⸮⸮⸮<#pJx⸮⸮⸮3⸮⸮| ⸮ ⸮ } ⸮ ⸮⸮FD ⸮⸮⸮⸮(⸮ ⸮⸮| ⸮⸮⸮⸮(:ЕKx;+5⸮$⸮K⸮ !Fp⸮⸮⸮⸮⸮"⸮K p⸮Kp⸮K⸮⸮Kp"⸮KpO⸮r⸮Kp⸮Kp⸮K`-⸮⸮$⸮K!F⸮ p⸮⸮⸮⸮⸮Kp⸮Kp⸮K⸮⸮Kp⸮Kp⸮Kp⸮Kp⸮K`⸮⸮| ⸮⸮⸮⸮(⸮| ⸮⸮⸮⸮(⸮⸮⸮⸮sN3x;+⸮⸮qL⸮ !x⸮⸮⸮⸮#x +S⸮⸮⸮⸮
13:49:44.436 -> *Y⸮⸮⸮@c⸮# gJoIpgJpgJ⸮gJpgJpgJpgJpgJ`hJp
13:49:44.475 -> xDҲ*
13:49:44.475 -> p⸮ pp-⸮⸮⸮"XKXIp#pWI⸮WIpWI
13:49:44.475 -> pWI
13:49:44.475 -> pWJpWJ`XJp2x*⸮#pVKx +SK⸮x2px*⸮"x2"p"p-@⸮⸮#x +⸮⸮K⸮ "@K!p#?Jp?J⸮?JpO⸮⸮aEJ⸮O⸮aDJ⸮!DJp<!CJp"8I
13:49:44.475 -> p8I
13:49:44.475 -> p8I
13:49:44.475 -> pO⸮⸮a7J`8Jp=K⸮+⸮⸮#⸮t⸮⸮#p⸮⸮ "*K-Ip#)Jp)J⸮"
13:49:44.576 -> p*I
13:49:44.576 -> p*I
13:49:44.576 -> pO⸮⸮a)J`*Jp/K⸮2+&K⸮⸮x2px*⸮⸮*Jx*⸮⸮"⸮⸮"&KH pKJpK⸮#pJpJpO⸮⸮bK`Kp⸮⸮⸮⸮KJ⸮⸮(⸮p⸮⸮x3۲+p⸮⸮#x3#p⸮⸮⸮⸮ ⸮ ⸮ ⸮ ⸮ ⸮ x ⸮ ⸮ ⸮ ⸮ ⸮ w ⸮ ⸮ | } z q #QJQIpQJ⸮ p"PK⸮#pOIpOIpO⸮⸮aNK`NKp⸮⸮^⸮(?⸮9⸮#x3#p4⸮"'AKCNpAKpEKx3⸮⸮⸮⸮⸮⸮⸮I⸮<K>Jp#p=JpO⸮⸮b<K`-⸮=Kx⸮B⸮ h⸮#3⸮⸮⸮"0K!p"0Kp"/K⸮4Kp#+Jp-Jp-JpO⸮⸮b,K`/Jx3۲
13:49:44.611 -> +p⸮Ȯ#p#p⸮⸮"K p#JIp"
13:49:44.662 -> ⸮#IpIpIpKpO⸮⸮bK`KxQpI ⸮ ⸮2px
13:49:44.662 -> *⸮⸮⸮ ""p"p-?⸮⸮⸮⸮ "Kp Kp K⸮Kp"KpKpKpK`⸮ x ⸮ ⸮ ⸮ ⸮ ⸮ ⸮ p ⸮ ⸮ z ⸮xKppG⸮ hJ
13:49:44.662 -> ⸮JpChJ⸮⸮#ppG⸮⸮ ⸮ ⸮ Kp(⸮K`K`K`pG⸮ ⸮ ⸮ ⸮ K Jx⸮B(⸮FKph⸮B⸮3`pG⸮⸮;⸮⸮⸮⸮ ⸮ ⸮ "⸮⸮8LO⸮p"p"⸮⸮"5K6Oh6K
13:49:44.662 -> .h;⸮⸮⸮&⸮(C⸮HO⸮!cs⸮⸮&2- F⸮s⸮⸮%%"s⸮s"t⸮⸮⸮⸮O⸮⸮S⸮;⸮⸮"@⸮"p%J H⸮⸮⸮`#t⸮⸮⸮⸮O⸮⸮R⸮:⸮⸮K8⸮hK xKA⸮!x⸮r[C⸮#O?x C⸮#O!s?x⸮rC⸮⸮#O"t?xHC⸮CC⸮C⸮%%pO⸮ue`O⸮ucs
13:49:44.662 -> %⸮⸮s⸮s⸮⸮⸮@⸮⸮Q⸮⸮⸮ ⸮ ⸮ ⸮ ⸮⸮⸮ ⸮ ⸮ ⸮ ⸮}⸮\⸮ ⸮ ⸮Kh⸮⸮⸮Z⸮H⸮⸮,⸮B⸮(3⸮;⸮⸮"
HO⸮qp"⸮`⸮⸮t⸮⸮ ⸮B⸮(3⸮;⸮⸮H⸮⸮⸮H⸮⸮⸮⸮ ⸮ 7⸮8L#x+⸮⸮⸮⸮#;FKS\4H⸮⸮⸮⸮3H⸮⸮⸮⸮#2Hp@⸮!cC`1K⸮`#⸮`t⸮⸮⸮⸮#x3#p⸮0⸮#)Hp*KC`#⸮⸮#&M+p(Kk`@⸮#+⸮):Ѕ#⸮#A⸮dF⸮⸮D⸮⸮r#H⸮r⸮⸮⸮⸮#HpKMC`K⸮⸮S`#⸮⸮#HpK⸮⸮#HpKC`#⸮⸮⸮#HIpB⸮S⸮⸮⸮⸮# HJpA⸮⸮⸮#⸮⸮⸮⸮#⸮⸮r⸮⸮⸮⸮ ⸮ @`⸮⸮⸮r@⸮,⸮QF@ $⸮@'⸮h⸮^⸮⸮hC⸮⸮`pG⸮h⸮B⸮⸮hC⸮⸮`pGJ⸮⸮4C⸮⸮⸮4pG @⸮h⸮C⸮⸮`h⸮⸮pG⸮hC⸮⸮`pG⸮h⸮⸮pG⸮F⸮⸮⸮⸮F⸮⸮⸮⸮(⸮⸮⸮"F⸮⸮⸮2*C⸮⸮⸮"a⸮⸮2*C⸮⸮⸮⸮`⸮⸮h#⸮⸮`pGChC⸮sC`pG⸮h#⸮c⸮`pG⸮hC⸮⸮`pG)⸮⸮$o⸮;O⸮'F#F_⸮⸮⸮⸮B⸮9C⸮S⸮bcDc⸮-
13:49:44.785 -> ⸮x⸮<⸮⸮,C⸮26⸮⸮=-x⸮⸮⸮⸮⸮⸮@/C⸮⸮+C⸮⸮h⸮C⸮⸮`h[⸮⸮pG⸮hC⸮s⸮`pGK⸮B⸮@⸮ @⸮ ⸮s⸮⸮d@-⸮⸮Ah⸮F$⸮`h⸮FD⸮`O⸮⸮t⸮⸮ ⸮⸮⸮$⸮⸮( ⸮⸮<`⸮⸮@p⸮⸮<⸮⸮Dh⸮⸮⸮,h⸮n⸮$⸮ah⸮⸮O⸮D⸮⸮`h⸮⸮K⸮D⸮@`+I⸮hC⸮ `h⸮⸮E⸮C⸮`h)B⸮C⸮`h*?⸮C⸮`⸮i/<⸮C⸮C⸮a⸮i.9⸮C⸮⸮C⸮a⸮
⸮;⸮⸮ C⸮⸮iC⸮CC⸮ah#⸮`O⸮⸮s⸮⸮;⸮⸮+h⸮⸮⸮(h⸮⸮⸮⸮⸮⸮$⸮⸮⸮⸮$⸮@⸮⸮h#⸮ ⸮⸮#⸮⸮⸮#⸮⸮⸮#⸮⸮⸮#⸮C⸮⸮#⸮⸮C⸮⸮ ⸮⸮⸮%$L⸮⸮p⸮⸮⸮/⸮2f⸮@F⸮⸮⸮f⸮⸮⸮⸮C.⸮⸮⸮⸮A⸮⸮⸮)C⸮⸮2⸮⸮⸮&*C⸮`⸮⸮@⸮⸮&⸮`⸮⸮C`Kұ⸮⸮&*C⸮⸮&'⸮⸮⸮&C⸮⸮VJ⸮⸮6#⸮⸮⸮6⸮⸮⸮1@⸮⸮⸮⸮&2@⸮⸮⸮⸮&@⸮⸮f⸮⸮⸮`@0⸮⸮⸮@⸮⸮PD⸮D⸮B⸮C⸮"0⸮!⸮⸮⸮⸮CiCCapGCi#⸮CapG-⸮⸮A⸮F⸮h⸮⸮⸮E⸮*⸮⸮⸮*⸮⸮⸮⸮P⸮O⸮⸮u ⸮"⸮⸮A⸮E⸮⸮#hC⸮#`ch#⸮c`bh⸮Cc`⸮⸮3+*⸮⸮⸮⸮&# O⸮⸮u ⸮⸮O⸮⸮u ⸮⸮I⸮⸮'⸮yc⸮g⸮yc⸮Gsyc⸮'3yc⸮O⸮⸮xc⸮l⸮xc⸮Lsxc⸮,3xc⸮⸮⸮⸮⸮`#hC⸮#`⸮⸮⸮⸮O⸮⸮0⸮⸮!⸮⸮hC⸮ ⸮`pGiC⸮ apG⸮⸮h⸮pGi⸮⸮-⸮⸮G⸮⸮(⸮F⸮⸮V⸮⸮⸮⸮⸮F⸮FO⸮⸮qO⸮⸮p⸮⸮⸮⸮Q⸮`Xg⸮⸮ ⸮⸮⸮⸮`X⸮`X@
⸮`aX⸮⸮⸮@pyh⸮
13:49:45.257 -> pyh
⸮⸮p⸮{h3⸮⸮h⸮h⸮⸮!ip⸮⸮A⸮p⸮⸮!.p+q⸮⸮fiq⸮⸮A⸮⸮c⸮p⸮q⸮q⸮AF F⸮⸮⸮⸮HF⸮⸮⸮⸮⸮J⸮hC⸮⸮`pG0@K`hpG0@#⸮J⸮B⸮h⸮P⸮#@3`⸮⸮0@K⸮⸮⸮pG⸮⸮#"9⸮⸮`⸮`aZa#Bh⸮⸮⸮CA`pG9⸮⸮⸮A`pG9h⸮⸮⸮B⸮ pG#9YC0⸮X$⸮@TPXCP⸮#9YC0⸮X$⸮@dPXCP⸮#9YC0⸮X$⸮@tPXCP⸮#9YC0XC⸮⸮PpG#9YC0XC⸮ PX#⸮CPpG#9YC0X#⸮PpG#9YC0XC⸮PpG#9YC0XC⸮PpG#9YC0X#⸮PpG#9⸮⸮h⸮X⸮apG#9⸮⸮h⸮X⸮BapG#9YC0X⸮⸮pG#9YC0
13:49:45.322 -> PpG)⸮)⸮Y⸮K⸮⸮$C⸮⸮$⸮⸮@ӈ⸮$"⸮⸮⸮pGK⸮⸮$"⸮⸮⸮$⸮⸮$C⸮⸮K⸮⸮$C⸮⸮@K⸮⸮$C⸮⸮$⸮⸮$C⸮⸮pG@K⸮⸮pG@-⸮⸮O⸮F"O⸮'N⸮⸮x⸮⸮⸮x⸮⸮⸮x⸮⸮⸮⸮⸮K⸮B%⸮⸮AE$⸮IE$С⸮
13:49:45.373 -> CBCA⸮⸮⸮ h⸮⸮⸮ ⸮⸮@C `2*⸮ѽ⸮⸮⸮
K⸮B⸮⸮⸮c⸮B⸮##⸮⸮#⸮⸮#⸮⸮#⸮⸮#⸮⸮@@@@@@8⸮M⸮h⸮⸮⸮⸮⸮⸮⸮⸮⸮lC⸮58⸮⸮ @8⸮F
F⸮⸮⸮⸮⸮⸮⸮⸮⸮K⸮J⸮B⸮mB⸮e%⸮⸮u⸮⸮⸮⸮⸮⸮⸮
13:49:45.373 -> K⸮
13:49:45.373 -> J⸮B ⸮m"⸮e8⸮iB⸮a⸮⸮i"⸮a⸮⸮⸮ @⸮⸮⸮F⸮T⸮⸮⸮⸮⸮⸮⸮K⸮J⸮B⸮mB⸮e\emB⸮@e⸮@⸮⸮⸮t⸮⸮⸮K⸮J⸮B⸮m"⸮e⸮iB⸮a\aiB⸮@a⸮⸮i"⸮a⸮⸮⸮ @⸮⸮Jh#⸮C`pG⸮ @KJZ`⸮2Z`pG⸮ @#gEJiC⸮⸮apG @⸮⸮⸮c⸮⸮⸮⸮⸮8⸮FF⸮⸮⸮⸮j⸮!⸮⸮⸮8@⸮⸮d⸮-⸮⸮A&O⸮⸮FhGhL⸮⸮⸮⸮.⸮⸮⸮F⸮F⸮⸮O⸮⸮⸮ <⸮⸮⸮⸮⸮⸮(⸮⸮⸮⸮⸮⸮⸮⸮,CD⸮.⸮⸮#F'F6.⸮⸮`G`⸮⸮⸮⸮JSh#⸮⸮cCCS`pG@apG apG⸮h@pG⸮h⸮!⸮A⸮AapGJ⸮⸮"K`pG⸮0@($⸮⸮⸮⸮ Kh⸮⸮@`pGKh⸮⸮⸮`pGKh⸮⸮@ppG Kh⸮⸮@@pGKh⸮⸮@pGKj⸮⸮KXj⸮⸮ pG⸮@F⸮F⸮⸮⸮⸮(⸮⸮⸮(*⸮⸮⸮⸮
13:49:45.416 -> $JhC⸮⸮s`pGJhC⸮⸮c⸮⸮
JhC⸮⸮S⸮⸮
13:49:45.416 -> JhC⸮3⸮⸮JhC⸮⸮⸮JjC⸮bpGJSjC⸮SbpG@JSh#⸮CS`pG⸮@JSh#⸮pC⸮CS`pG@JSh#⸮3C⸮CS`pG@JSh⸮⸮n⸮#⸮3C⸮@CS`pG@Kj⸮@pG⸮@JjC⸮CbpG@(;⸮⸮⸮⸮555%5KjB⸮bj⸮⸮⸮j"⸮@rbjB⸮rbpGKZjB⸮ZbZj⸮⸮⸮j"⸮@rbjB⸮r⸮⸮KhB⸮2`h⸮⸮⸮j"⸮@rbjB⸮@r⸮⸮Jj#⸮@sbpG⸮@JSh#⸮@CC⸮3S`pG@JSh#⸮`SC⸮⸮#S`pG@JSh#⸮⸮cC⸮#S`pG@JSh#⸮⸮C⸮S`pG@⸮ ⸮⸮*⸮⸮⸮ ⸮ ⸮⸮U⸮ ⸮⸮"⸮⸮⸮⸮ ⸮⸮M⸮ ⸮⸮⸮⸮ ⸮⸮⸮⸮ ⸮⸮⸮⸮ ⸮⸮⸮⸮ ⸮⸮V⸮ ⸮⸮E⸮ ⸮⸮L⸮ ⸮⸮S⸮⸮⸮⸮⸮⸮⸮⸮ ⸮⸮.⸮KJI`J`J`⸮⸮⸮J⸮ Q%⸮ ⸮ "C ⸮C⸮3h⸮⸮⸮C`pG"C ⸮C⸮3h⸮⸮⸮C`h"⸮`pGK⸮⸮(⸮⸮⸮⸮⸮(B⸮⸮⸮(pG @K⸮⸮("⸮⸮⸮(⸮⸮(⸮⸮⸮pG @8⸮F%O⸮gp⸮⸮⸮⸮@⸮0⸮⸮⸮⸮⸮1⸮ FL⸮⸮⸮⸮⸮X⸮⸮X⸮⸮⸮⸮⸮⸮⸮⸮O⸮⸮s⸮⸮X⸮⸮X⸮⸮X⸮⸮X⸮⸮ 8⸮⸮$8⸮⸮⸮⸮⸮⸮8#⸮⸮⸮8⸮⸮8⸮⸮8⸮ @⸮⸮⸮⸮⸮K⸮⸮⸮⸮@⸮⸮(⸮⸮⸮⸮@⸮⸮⸮⸮⸮ @K⸮⸮⸮⸮8C⸮@pG @⸮⸮⸮⸮⸮K⸮⸮⸮⸮(⸮⸮⸮⸮@⸮⸮⸮⸮ @⸮⸮⸮⸮(
⸮(⸮0⸮J⸮⸮8C⸮⸮⸮8⸮⸮@⸮⸮}⸮J⸮⸮8C⸮⸮⸮J⸮⸮8C⸮⸮⸮⸮ @(
13:49:45.680 -> ⸮(⸮0⸮
13:49:45.680 -> J⸮⸮8#⸮⸮⸮8pGJ⸮⸮8#⸮⸮⸮J⸮⸮8#⸮⸮⸮⸮ @⸮O⸮gp⸮⸮⸮@⸮0⸮⸮⸮⸮⸮K⸮⸮("⸮⸮⸮(⸮⸮(⸮⸮⸮⸮(⸮⸮⸮⸮⸮ @8⸮FO⸮gpF⸮⸮⸮⸮@⸮0⸮⸮⸮⸮⸮⸮;⸮⸮⸮⸮8@⸮⸮п(F⸮⸮-⸮ F⸮⸮8@⸮⸮^⸮hC⸮@`pG⸮`⸮h⸮⸮⸮⸮h⸮⸮pGhC⸮s`Ch#⸮C`pGhC⸮s`pG)⸮⸮h#⸮C`pG0⸮h⸮⸮>⸮AT,C⸮,CCCChCD⸮C⸮C`` 0⸮⸮hC⸮`pGiB⸮ pG⸮CapG⸮hC$⸮\t
13:49:45.755 -> C"C`⸮hC⸮⸮`pGh#⸮`pGh#⸮`pGhC⸮`pGh#⸮`pG⸮bpG⸮bpG)z⸮⸮⸮⸮y3ycy⸮⸮i#⸮⸮a⸮i⸮a⸮i#⸮p⸮a*h⸮⸮⸮⸮3
⸮iC⸮⸮apG⸮iC⸮ ⸮⸮iC⸮0⸮⸮iC⸮@⸮⸮iC⸮P⸮⸮iC⸮`⸮⸮iC⸮p⸮⸮i#⸮@s⸮a⸮i⸮a⸮i#⸮⸮C⸮a*9⸮⸮⸮⸮
13:49:45.782 -> ⸮i⸮⸮iC⸮S⸮⸮iC⸮S⸮⸮iC⸮@S⸮⸮iC⸮C⸮⸮iC⸮⸮C⸮⸮iC⸮⸮C⸮⸮iC⸮⸮C⸮⸮⸮i#⸮⸮a⸮i⸮a⸮i#⸮p⸮a* ⸮⸮⸮⸮3
⸮iC⸮⸮apG⸮iC⸮ ⸮⸮⸮iC⸮0⸮⸮⸮iC⸮@⸮⸮⸮iC⸮P⸮⸮⸮iC⸮`⸮⸮⸮iC⸮p⸮⸮⸮i#⸮@s⸮a⸮i⸮a⸮i#⸮⸮C⸮a*⸮⸮⸮⸮⸮
13:49:45.817 -> ⸮i⸮⸮⸮iC⸮S⸮⸮⸮iC⸮S⸮⸮⸮iC⸮@S⸮⸮⸮iC⸮C⸮⸮⸮iC⸮⸮C⸮⸮⸮iC⸮⸮C⸮⸮⸮iC⸮⸮C⸮⸮) ⸮⸮⸮⸮
jC⸮bpGjC⸮⸮⸮jC⸮s⸮⸮jC⸮S⸮⸮jC⸮⸮⸮jC⸮@⸮⸮jC⸮c⸮⸮) ⸮⸮⸮⸮
j#⸮bpGj#⸮⸮⸮j#⸮s⸮⸮j#⸮S⸮⸮j#⸮⸮⸮j#⸮@⸮⸮j#⸮c⸮⸮)⸮⸮⸮⸮
13:49:45.817 -> BcpG⸮cpG⸮cpGdpGClC⸮CCdpG@jpGAbpGJK⸮Bh⸮Kh⸮Q⸮⸮⸮⸮`pG⸮8@⸮ ⸮ ⸮h)⸮#⸮SC⸮S⸮`pGi#⸮@SCapG⸮h#⸮⸮cC⸮`pG⸮h#⸮C⸮`pGCi#⸮@sCCapG⸮hC⸮S⸮`pG8⸮F
F⸮⸮)F F⸮⸮8@⸮
13:49:45.853 -> ⸮CiC⸮@CapGCiC⸮⸮CapG⸮⸮A`pG@h⸮⸮pGh⸮⸮pGhB⸮ pG⸮⸮pG8⸮JKI⸮B⸮!J⸮B⸮O⸮⸮"⸮⸮=LC⸮sM⸮⸮=⸮B⸮LM⸮B⸮⸮⸮⸮⸮LM⸮B⸮8⸮R⸮C⸮⸮⸮C⸮⸮⸮T⸮;⸮G⸮⸮T⸮;⸮G0C⸮⸮⸮⸮T⸮;⸮G⸮⸮⸮x⸮ ⸮ ⸮ l⸮l⸮l⸮x⸮x⸮x⸮O⸮⸮#J⸮⸮-⸮⸮⸮"C ⸮⸮`C⸮⸮aC⸮⸮`pGC(⸮⸮⸮`@K⸮⸮d@⸮⸮⸮TppG⸮⸮⸮JhC⸮s`pGp@p⸮O⸮⸮L⸮⸮l⸮T⸮⸮U⸮⸮⸮⸮⸮⸮⸮,D⸮⸮!⸮LQ#⸮LSP⸮5⸮R⸮5A⸮C⸮8Р⸮⸮O⸮⸮⸮⸮⸮B⸮⸮⸮O⸮⸮⸮V⸮⸮⸮N⸮⸮⸮⸮⸮⸮d⸮@t⸮_⸮NmAF⸮B⸮⸮!A⸮UQO⸮⸮ @⸮^PO⸮⸮.⸮⸮⸮⸮⸮⸮⸮⸮oؾ⸮O⸮_⸮PP⸮A⸮Qp⸮⸮FF⸮@⸮⸮⸮⸮⸮\¿⸮⸮A⸮Qp⸮A⸮O⸮<⸮⸮6 ⸮Ap⸮⸮⸮ <5⸮4⸮⸮⸮⸮ ⸮⸮ ⸮⸮⸮⸮@⸮⸮B!⸮A⸮⸮p!⸮⸮B⸮^⸮C⸮ ⸮⸮pp⸮⸮⸮⸮⸮ ⸮⸮ ⸮⸮⸮⸮@⸮⸮A⸮⸮pA⸮^⸮C⸮ ⸮⸮pp⸮⸮⸮ ⸮⸮N⸮ ⸮⸮⸮⸮C⸮!⸮⸮⸮A!⸮⸮ ⸮⸮⸮p^⸮C⸮ ⸮⸮pp⸮⸮⸮⸮⸮F@A⸮⸮⸮<⸮⸮A⸮⸮⸮⸮pG⸮FRC⸮⸮⸮=⸮⸮C⸮pG⸮⸮⸮U⸮⸮⸮⸮P⸮A⸮R⸮C⸮с⸮⸮AO⸮p⸮P⸮A⸮FFR⸮CД⸮⸮P⸮6ѕ⸮⸮R⸮6⸮FF
13:49:46.069 -> с⸮⸮AA⸮⸮AA⸮pO⸮p⸮A⸮⸮AA⸮xp⸮⸮⸮A⸮⸮⸮⸮C0⸮O⸮AO⸮C⸮⸮⸮⸮⸮⸮T⸮U⸮⸮d\⸮e\⸮⸮O⸮TT⸮⸮UU⸮⸮mB⸮,D⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮6-⸮⸮0⸮⸮OO⸮1O⸮L⸮1⸮@Ba⸮A⸮OO⸮3L⸮3⸮RBc⸮C⸮⸮𧀤⸮⸮⸮
⸮⸮⸮"⸮⸮A⸮⸮⸮C⸮⸮YA⸮⸮ ⸮ *⸮⸮(⸮L⸮C⸮⸮⸮Q⸮⸮q⸮E⸮O⸮⸮⸮~⸮n⸮⸮⸮⸮ӱ⸮⸮I_⸮0O⸮<⸮O⸮DR⸮⸮⸮⸮Ow⸮u⸮_⸮PP⸮A⸮QA⸮0⸮_⸮L@AA⸮<(⸮⸮⸮⸮⸮ґ⸮⸮F ⸮⸮⸮⸮⸮ 3⸮⸮⸮⸮ ⸮2⸮⸮⸮⸮⸮⸮!⸮⸮⸮⸮ؿ⸮⸮ ⸮⸮ ⸮⸮ܿA⸮⸮@⸮⸮⸮⸮Q)C0⸮o⸮<⸮4⸮⸮⸮⸮ ⸮⸮⸮⸮@⸮!⸮⸮E⸮0⸮⸮⸮⸮⸮ ⸮⸮⸮⸮@⸮)F0⸮!⸮⸮)F0⸮⸮⸮⸮⸮⸮⸮⸮4=N⸮⸮d\⸮⸮e\)Д⸮⸮⸮⸮⸮T⸮⸮FF0⸮⸮⸮⸮! 0⸮_⸮T\⸮@IA(⸮A⸮A0⸮⸮⸮<⸮⸮⸮0⸮⸮EE⸮⸮AA⸮pO⸮0⸮⸮d\⸮FF⸮e\⸮FFP⸮4⸮R⸮5⸮⸮A⸮!0⸮⸮⸮⸮⸮!pG0⸮O⸮d⸮2O⸮O⸮P⸮⸮⸮⸮⸮!pG0⸮O⸮d⸮2⸮EH⸮@BO⸮>⸮⸮BO⸮⸮O⸮1O⸮p⸮⸮C⸮⸮O⸮⸮`QpG2⸮B⸮pG⸮⸮O⸮A⸮!pG0⸮O⸮`t⸮E!⸮A⸮⸮P⸮⸮pG0⸮O⸮
13:49:46.224 -> ⸮P⸮⸮pG0⸮⸮E⸮@Ba⸮AO⸮d⸮2_⸮\?⸮خO⸮_⸮⸮⸮2_⸮⸮⸮2⸮⸮⸮⸮ ⸮⸮ ⸮⸮⸮⸮@⸮!⸮⸮D⸮⸮⸮O⸮A⸮⸮⸮C$⸮⸮⸮⸮⸮⸮\
⸮⸮LO⸮⸮L⸮Pp⸮⸮O@⸮⸮ ⸮pG⸮⸮O!⸮⸮8r⸮⸮⸮@pGA⸮O⸮RR⸮⸮⸮⸮ ⸮⸮ ⸮⸮⸮@⸮O⸮⸮#O⸮⸮#⸮⸮@⸮#⸮⸮O⸮C⸮⸮⸮bS⸮P⸮3⸮O⸮⸮@@⸮@pG⸮@@⸮⸮@@⸮pG⸮⸮⸮@⸮⸮⸮⸮AB⸮_⸮A⸮⸮⸮"l⸮#lj⸮O⸮b⸮⸮c⸮⸮⸮A@H@A@⸮⸮[B+⸮⸮pG⸮O@⸮ ⸮@⸮@B⸮OA⸮!⸮A⸮IB⸮⸮?Т⸮A⸮⸮⸮⸮⸮ ⸮⸮⸮C⸮IB`⸮@⸮⸮Ӱ⸮⸮@O⸮1⸮⸮*Qұ⸮O@⸮⸮P⸮ ⸮@⸮pGI@⸮:(⸮⸮⸮⸮Ұ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮PRBC⸮⸮⸮@CpG⸮⸮⸮⸮⸮⸮⸮2;⸮⸮O⸮A⸮"l⸮⸮⸮"⸮#l!В⸮В⸮⸮FpG⸮⸮⸮ pG⸮O⸮@(⸮@⸮@pG⸮r<⸮⸮pG⸮CC⸮⸮@@⸮pG⸮"b⸮F⸮#cFB⸮_⸮A#⸮⸮@⸮pGO⸮⸮⸮⸮CH⸮@B_⸮⸮pGC⸮CFO⸮⸮P⸮⸮pGO⸮
13:49:46.452 -> ⸮⸮P⸮⸮pG⸮C⸮@Ba⸮A_⸮⸮⸮FF C⸮C⸮⸮⸮S⸮⸮⸮⸮⸮⸮:⸮⸮⸮S⸮⸮⸮cD⸮⸮⸮⸮ ⸮⸮O ⸮⸮C⸮⸮ ⸮pG⸮ ⸮⸮⸮⸮ P⸮L!⸮⸮C⸮⸮ ⸮⸮ppGO⸮⸮⸮⸮R⸮⸮⸮S⸮⸮⸮⸮o⸮D⸮⸮@⸮_⸮A!⸮O⸮cC⸮PC⸮Q⸮⸮1⸮@⸮⸮>⸮IA⸮⸮q[@⸮b⸮⸮*س⸮O@⸮⸮P⸮ ⸮pG⸮⸮⸮L⸮IL⸮P @⸮Q :¿⸮⸮⸮@⸮⸮PpG@⸮O⸮:]⸮⸮ܿ⸮@pG⸮⸮A!⸮⸮⸮⸮ ⸮⸮_⸮1@⸮S⸮L⸮ ⸮⸮ppG⸮⸮⸮L⸮@⸮:⸮⸮@⸮⸮⸮⸮L⸮I⸮;⸮⸮A⸮⸮⸮⸮⸮S⸮⸮⸮⸮⸮
13:49:46.519 -> ⸮0⸮L⸮1⸮L⸮р⸮⸮@pG⸮⸮⸮⸮⸮OF⸮⸮⸮⸮OВ⸮⸮Bѓ⸮⸮K⸮Fр⸮⸮@@⸮⸮@@⸮pG@⸮⸮@@⸮@pGO⸮⸮⸮⸮R⸮⸮⸮S⸮⸮⸮⸮iТ⸮⸮⸮IO⸮@ 7⸮O⸮⸮SC⸮C⸮⸮@⸮B8⸮[B⸮}O⸮⸮B$⸮[@⸮⸮⸮Q$⸮⸮⸮Q@⸮\⸮⸮$⸮⸮⸮@⸮⸮⸮⸮$⸮⸮⸮⸮@⸮⸮⸮_⸮⸮⸮⸮*?⸮P⸮⸮B@⸮⸮P⸮ ⸮pG⸮LL⸮P 2¿⸮⸮⸮@⸮⸮PpG@⸮O⸮:7⸮⸮⸮L⸮@⸮:⸮⸮@⸮⸮⸮⸮L⸮I⸮;⸮⸮A⸮⸮⸮⸮⸮S⸮⸮⸮B⸮}⸮⸮⸮⸮p⸮Fv⸮⸮⸮K?⸮L⸮Fn⸮0⸮L⸮1⸮L⸮⸮0⸮B⸮\⸮1⸮C⸮<⸮_⸮⸮O⸮⸮<⸮⸮O⸮⸮⸮O⸮M⸮⸮O⸮@O⸮A⸮"l⸮⸮#l⸮⸮R⸮S⸮⸮⸮X⸮⸮⸮⸮⸮⸮8⸮o⸮⸮p⸮⸮9⸮@⸮pG⸮"l⸮_⸮@,⸮⸮#l⸮⸮_⸮A,⸮⸮]⸮pG⸮⸮FFaF⸮⸮⸮⸮⸮⸮⸮(H⸮⸮⸮M⸮⸮⸮⸮⸮⸮⸮ ]⸮⸮⸮M⸮⸮⸮⸮⸮⸮4⸮ ]⸮⸮⸮M⸮⸮⸮⸮⸮⸮⸮⸮ ]⸮⸮⸮M⸮⸮⸮⸮⸮⸮⸮⸮ ]⸮⸮⸮M⸮⸮⸮⸮⸮⸮4⸮ ]⸮⸮⸮O⸮@⸮⸮⸮O⸮O⸮⸮⸮b
⸮O⸮#C⸮C⸮O#⸮⸮⸮@BpGO⸮pG⸮a⸮B⸮⸮@⸮o⸮@pGO⸮pGBҲ⸮⸮O⸮O⸮⸮⸮b ⸮O⸮#C⸮C#⸮⸮pGO⸮pG⸮a⸮B⸮O⸮⸮0pGO⸮pG⸮Vehicle ModuleInverter0=Leaf_Gen1, 1=GS450H, 2=UserCAN, 3=OpenI, 4=Prius_Gen3, 5=Outlander, 6=GS300HVehicle0=BMW_E46, 1=BMW_E65, 2=Classic, 3=None , 5=BMW_E39 , 6=VAGTransmission0=MAN, 1=AUTInverter_CAN0=CAN1, 1=CAN2Vehicle_CANShunt_CANLIM_CANCharger_CANThrottlepotmindigpotmaxpot2minpot2maxregentravel%regenmaxregenramp%/10mspotmode0=SingleChannel, 1=DualChanneldirmode0=Button, 1=Switch, 2=ButtonReversed, 3=SwitchReversed, 4=DefaultForwardthrotrampthrotramprpmrevlimbmslimhighbmslimlowudcminudclimidcmaxidcmintmphsmax°CtmpmmaxthrotmaxthrotminthrotdeadGearbox ControlGEAR0=LOW, 1=HIGH, 2=AUTOOilPumpCruise Controlcruisestepcruiseramprpm/100msregenlevelContactor⸮n$ Controludcswcruiselight0=Off, 1=On, 2=naerrlights0=Off, 4=EPC, 8=engineCommunicationcanspeed0=250k, 1=500k, 2=800k, 3=1Mcanperiod0=100ms, 1=10msCAN3Speed0=k33.3, 1=k500Charger Controlchargemodes0=Off, 1=HV_ON, 2=EXT_CAN 3=EXT_DIGI, 4=Volt_AmperaBattCapkWhinterface0=Unused, 1=i3LIM, 2=Chademo, 3=Leaf_PDMVoltspntPwrspntIdcTermCCS_ICmdCCS_ILimCCS_SOCLimSOCFCChgctrl0=Enable, 1=Disable, 2=TimerHeater ModuleHeater0=None, 1=Ampera, 2=VW0=Disable, 1=Enable, 2=TimerHeatPwrRTC ModuleSet_Day0=Sun, 1=Mon, 2=Tue, 3=Wed, 4=Thu, 5=Fri, 6=SatSet_HourHoursSet_MinMinsSet_SecSecsChg_HrsChg_MinChg_DurPre_HrsPre_MinPre_DurISA Shunt ControlISA_INITversion4=1.11.Aopmode0=Off, 1=Run, 2=Precharge, 3=PchFail, 4=Chargechgtyp0=Off, 1=AC, 2=DCFClasterrstatus0=None, 1=UdcLow, 2=UdcHigh, 4=UdcBelowUdcSw, 8=UdcLim, 16=EmcyStop, 32=MProt, 64=PotPressed, 128=TmpHs, 256=WaitStartudc2udc3deltaVINVudcpowerkWidcKWhkwhAMPhAhSOCVeh_Speedkphtorquepotpot2potbrakebrakepress⸮⸮⸮urepotnomdir-1=Reverse, 0=Neutral, 1=Forwardinvvehinv_canveh_canshunt_canlim_cancharger_cancan3SpeedTRANSChargertmphstmpmtmpauxuauxcanio1=Cruise, 2=Start, 4=Brake, 8=Fwd, 16=Rev, 32=Bmscruisespeedcruisestt0=None, 1=On, 2=Disable, 4=SetN, 8=SetPdin_cruisedin_startdin_brakedin_forwarddin_reversedin_bmsdin_12VgphandbrkGear1Gear2Gear3T15StatInvStatGearFBCableLimPilotLimPlugDetPilotTyp0=Absent, 1=ACStd, 2=ACchg, 3=Error, 4=CCS_Not_Rdy, 5=CCS_Rdy, 6=StaticCCS_I_AvailCCS_V_AvailCCS_ICCS_IreqCCS_VCCS_V_MinCCS_V_ConhvChgCCS_COND0=NotRdy, 1=ready, 2=SWoff, 3=interruption, 4=Prech, 5=insulmon, 6=estop, 7=malfunction, 15=invalidCCS_StateCP_DOOR0=CLOSED, 1=OPEN, 2=ERROR, 3=INVALIDCCS_ContactorChgTHeatReqTestMG2RawMG1RawcpuloadBaud rate now 921600
13:49:47.389 -> enableuartfastuartUnknown command sequence
13:49:47.389 -> 8@@@@D@@@ H@@@-%X%X%X
13:49:47.389 -> Parameter attributes
13:49:47.389 -> Name min - max [default]
13:49:47.389 -> %s %f - %f [%f]
13:49:47.389 -> AvailP⸮⸮
13:49:47.389 -> able parameters and values
13:49:47.389 -> %s [%s]
13:49:47.389 -> Defaults loaded
13:49:47.389 -> getflagstreamdefaultsalllistatrsavejsonserialerrorsreset⸮⸮-pB⸮⸮pF⸮⸮pK⸮⸮qR⸮u2[⸮=2_⸮2d⸮⸮1h⸮Eu⸮uum⸮yrD⸮⸮sr⸮u1y⸮q1⸮⸮⸮u(null)6a⸮⸮K/⸮⸮⸮⸮}F⸮B⸮D⸮B-DC⸮B⸮B⸮B C⸮KqN⸮BOyO⸮NuN⸮N⸮N⸮N⸮NsNqNV⸮U;U⸮U UU!U+U7UsN[%u]: %s - %s
13:49:47.389 -> No Errors
13:49:47.389 -> STOPDERATEWARN0=NONE, 1=BMSCOMM, 2=OVERVOLTAGE, 3=PRECHARGE, 4=THROTTLE1, 5=THROTTLE2, 6=THROTTLE12, 7=THROTTLE12DIFF, 8=THROTTLEMODE, 9=CANTIMEOUT, 10=TMPHSMAX, 11=TMPMMAX,BMSCOMMOVERVOLTAGEPRECHARGETHROTTLE1THROTTLE2THROTTLE12THROTTLE12DIFFTHROTTLEMODECANTIMEOUTTMPHSMAXTMPMMAX״⸮⸮⸮⸮⸮%⸮/⸮:⸮I⸮V⸮a⸮j⸮L⸮Q⸮X⸮P 1]⸮!@qN⸮eyh⸮d5d⸮cddd/dsN⸮⸮UU@⸮⸮⸮can rx tx %s %d %d %d %d
13:49:48.056 -> No parameter value given
13:49:48.056 -> Set OK
13:49:48.056 -> Value out of range
13:49:48.056 -> Unknown parameter %s
13:49:48.056 -> Unknown parameter: '%s'
13:49:48.056 -> No flag given
13:49:48.056 -> hiddenUnknown flag
13:49:48.056 -> Flag change OK
13:49:48.056 -> Usage: stream n val1,val2...
13:49:48.056 -> %s%ftruefalse{%c
13:49:48.056 -> "%s": {"unit":"%s","value":%f,"canid":%d,"canoffset":%d,"canlength":%d,"cangain":%d,"isrx":%s,"isparam":true,"minimum":%f,"maximum":%f,"default":%f,"category":"%s","i":%d}"isparam":false}
13:49:48.056 -> }
13:49:48.056 -> All message definitions cleared
13:49:48.056 -> Missing argument
13:49:48.056 -> %d entries removed
13:49:48.056 -> Invalid CAN Id %x
13:49:48.056 -> Invalid Offset %d
13:49:48.056 -> Invalid length %d
13:49:48.056 -> Cannot map anymore items to CAN id %d
13:49:48.056 -> Max message count reached
13:49:48.056 -> CAN map successful, %d message%s active
13:49:48.056 -> CANMAP stored
13:49:48.056 -> Parameters stored, CRC=%x
13:49:48.056 -> Parameters loaded
13:49:48.056 -> Parameter CRC error
13:49:48.112 -> ⸮&⸮,9\ ⸮⸮⸮⸮⸮⸮⸮@⸮⸮⸮⸮ ⸮⸮ ⸮@⸮⸮⸮⸮@8Aq⸮⸮⸮⸮
13:49:48.112 -> ⸮%⸮⸮⸮⸮⸮@⸮⸮⸮⸮@⸮@@) ⸮`1⸮⸮⸮
13:49:48.112 -> @4⸮C⸮L⸮⸮4⸮⸮⸮⸮⸮⸮4⸮ߥ⸮ N4⸮⸮⸮⸮ F4⸮⸮⸮ G4⸮!⸮⸮ H4⸮+⸮⸮ I4⸮3⸮⸮ J?⸮H⸮O⸮⸮⸮?⸮S⸮O⸮⸮⸮⸮⸮?⸮Z⸮O⸮⸮⸮⸮⸮ ?⸮b⸮O⸮⸮⸮⸮⸮
13:49:48.112 -> ?⸮j⸮v⸮⸮⸮<?⸮x⸮v⸮⸮⸮⸮⸮@⸮⸮⸮=?⸮⸮⸮⸮⸮⸮⸮D?⸮⸮⸮⸮⸮ ?⸮⸮⸮⸮⸮⸮ ?⸮
13:49:48.112 -> ⸮⸮⸮⸮⸮
?⸮⸮⸮⸮ ⸮ ?⸮!⸮⸮⸮ ⸮'ߡ?⸮(⸮v⸮⸮@?⸮3⸮v⸮⸮⸮⸮⸮⸮⸮⸮⸮?⸮=⸮⸮}@8?⸮D⸮⸮}A?⸮K⸮⸮⸮qq?⸮R⸮⸮⸮⸮⸮⸮⸮⸮⸮?⸮Y⸮b⸮@⸮⸮
13:49:48.112 -> ?⸮f⸮b⸮⸮⸮%⸮%?⸮n⸮v⸮⸮⸮?⸮w⸮v⸮⸮⸮⸮⸮⸮⸮⸮⸮?⸮⸮⸮v⸮@@L⸮⸮⸮⸮⸮⸮@⸮⸮⸮⸮v⸮⸮@⸮⸮̧⸮ }⸮⸮ק⸮ }⸮⸮⸮⸮״`@⸮⸮ ⸮⸮}@) ⸮⸮⸮⸮ !⸮⸮-⸮7⸮⸮"N⸮\⸮e⸮` #N⸮⸮⸮⸮⸮ $N⸮⸮⸮⸮⸮ M⸮⸮ƨҨ⸮%⸮⸮⸮⸮@⸮&⸮⸮⸮⸮`'⸮⸮E⸮⸮}`1(⸮⸮N⸮Щ⸮⸮⸮)⸮⸮V⸮⸮⸮⸮8⸮⸮^⸮⸮⸮⸮*⸮⸮g⸮⸮⸮⸮+⸮+⸮⸮p⸮v⸮⸮
13:49:48.112 -> ,⸮⸮{⸮v⸮⸮@O⸮⸮⸮⸮⸮⸮@-⸮⸮⸮⸮⸮⸮@9⸮⸮ħҩ@:⸮⸮⸮Щ⸮,;⸮⸮⸮
13:49:48.112 -> ⸮⸮Nf⸮⸮.⸮⸮:⸮C⸮⸮/⸮⸮I⸮Q⸮`0⸮⸮V⸮^⸮`1⸮⸮c⸮C⸮⸮2⸮⸮k⸮Q⸮`3⸮⸮s⸮Q⸮⸮%4⸮⸮{⸮C⸮`5⸮⸮⸮⸮Q⸮`6⸮⸮⸮⸮Q⸮⸮7⸮⸮⸮⸮⸮ K⸮⸮⸮⸮⸮⸮⸮ƪ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮ëȫ⸮˫v⸮⸮Ӭ⸮⸮ϫ٫⸮ݫO⸮⸮⸮O⸮⸮⸮O⸮⸮⸮O⸮⸮⸮⸮O⸮⸮⸮v⸮⸮⸮⸮⸮0⸮L⸮⸮4⸮⸮⸮⸮
13:49:48.200 -> ݴ⸮8⸮⸮@⸮⸮H⸮⸮R⸮⸮Z⸮⸮f⸮⸮⸮ p⸮⸮!v⸮Ҩ⸮~⸮b⸮⸮⸮⸮b⸮⸮⸮⸮b⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮ͬ⸮⸮٬⸮⸮⸮⸮⸮⸮⸮⸮ ⸮⸮⸮*⸮⸮⸮6⸮⸮⸮B⸮⸮⸮J⸮⸮T⸮⸮⸮\⸮⸮⸮b⸮⸮⸮h⸮⸮⸮n⸮⸮⸮v⸮⸮⸮~⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮S⸮j⸮⸮⸮⸮⸮'⸮⸮ 1⸮⸮
13:49:48.445 -> 7⸮@⸮⸮⸮a⸮⸮⸮⸮⸮
ۮ⸮⸮
13:49:48.485 -> ⸮>⸮⸮⸮#⸮⸮⸮Z⸮t⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮O⸮⸮O⸮ ⸮v⸮⸮⸮M⸮⸮⸮⸮%⸮⸮⸮_⸮⸮_a⸮⸮RK⸮⸮⸮@⸮t⸮⸮⸮⸮a⸮⸮RK⸮⸮⸮⸮⸮⸮aK⸮⸮⸮⸮⸮⸮aK⸮⸮⸮⸮⸮⸮⸮⸮_⸮⸮_⸮⸮a⸮⸮RK<⸮4⸮⸮H⸮⸮aK<⸮4⸮⸮K⸮⸮aK<⸮4⸮⸮K⸮⸮⸮a⸮⸮I<⸮4⸮⸮⸮F ⸮⸮a⸮⸮8⸮⸮??⸮K-⸮⸮⸮⸮`⸮⸮
13:49:48.875 -> ]⸮zzz⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮ݰ⸮⸮
13:51:12.505 -> fastuart
13:51:12.727 ->
13:51:12.727 -> json
13:51:56.580 -> 3⸮3@#8⸮⸮⸮⸮⸮⸮⸮⸮p⸮⸮⸮⸮⸮{⸮⸮⸮⸮⸮⸮⸮@⸮~⸮⸮⸮⸮9⸮/⸮2D⸮
Posted: Mon Feb 20, 2023 12:54 am
by sigdigits
Tl:dr all would have been fine if I was using Linux from the beginning....
But now do I swap the 56 pin header, or try swapping in another stm32 chip?
I confirmed my suspicions that the uart from the stm32 chip is dead, but I have no clue how I killed it. I’m entirely open to the possibility that I shorted something at some point or sent 5v somewhere it didn’t belong but I’ve had the same behavior from the very beginning... I programmed the board “successfully”, but never got parameters in the web interface. At first, this was due to the fact that the GigaDevices aka “GD” version of the stm32 can’t load the standard firmware. Since the firmware “programs” successfully, but fails to load, obviously there is no data being sent and the bootloader loops 2D2D2D... on the serial port. I’m not sure if the source of that issue was found, but a workaround solution was posted to the wiki. I spent a bunch of time trying to get the code to compile on my old MacBook, but traced the compile errors to some dependency (I think the arm libraries) that needed a newer os. I think I tried on my windows 10 VM, but got other errors and decided it was likely easier to desolder the GD chip from the zombieverter board and replace it with the true ST version. It was previously unavailable due to the chip shortage, and I didn’t even realize there were two versions at first, but I got it and swapped them. I’m thinking ok, I’m in the clear, and programming was again “successful”, this time with the correct heartbeat activity led blinking, great! BUT, again, no data/parameters in the web interface. Then I did a bunch of erasing and reprogramming the chip with different versions and bootloaders and trying to verify if there was serial communication. It’s possible I damaged something in soldering and uart3 never worked on the ST chip. I have to check the esp chip again, because it’s possible I might have damaged or shorted something when I soldered it to the zombieverter. It’s hard for me to think of another reason why the ST chip didn’t work out of the gate. After double and triple checking things was about the time I started this thread to get help to narrow down that the problem was for sure uart. After verifying nothing coming through the serial terminal and probing the lines with an oscilloscope, it’s 100% that it’s dead.
So, thankfully, I have another board, except it has the GD chip. Now I’m back to square one, but THIS time, I have a laptop running Linux that’s controlling my new 3D printer. I cloned the git, made the changes to the 2 files as per the wiki and compiled the “GD” version of the firmware. I flashed the hex file with the stlink and note there’s parameters in the web interface!!!!!!!
But, I’m left with another dilemma. I’m dumb and previously soldered the 56 pin header to the “bad” board. I’m also unsure (and it’s a huge pain with a single soldering iron) of replacing the chip again will bring uart back. I’m thinking the easiest thing is to order another enclosure, but I think I should also try swapping in a new chip. If the board is defective, or I somehow messed it up, it will just cost me the time to replace it and another chip. The uart3 lines aren’t shorted to each other or power or ground, so I don’t think the board is defective. This really makes me think that swapping the chips was successful, but between programming and connecting the esp board, I somehow killed the uart. What kills ME now is that I’m second guessing myself on what to do next since I’m not sure why it happened. It should have worked right after programming, and I never had an oops moment with wiring, soldering, or powering up. I’d actually be happier accepting that I messed up if it meant I had an answer. I’m open to any suggestions or things to check around the uart/rs232 (I already desolderd the jumpers during troubleshooting) before swapping in a new stm32, but pretense it looked like this is another problem that’s fixed, but not exactly solved!
