For Sale - GS450h motor, inverter, 530e battery pack Zombieverter etc
Posted: Wed Feb 01, 2023 6:49 pm
Sadly, change of circumstances, I'm losing my garage access so have to sell the project parts.
I have a Zombieverter with the latest firmware modded to use the shunt from a BMW 530e, plus the following for sale:-
Complete GS450h transmission - can he demoed working.
Transmission oil pump with bearings replaced.
GS450h Inverter plus 3D printed orange HV terminal cover.
Transmission to inverter HV cables/connectors.
Oil pump controller and harness.
Zombieverter to gearbox harness.
Transmission mount from GS45h.
GS450h transmission radiator.
Used Pierburg electric water pump from BMW.
Laser cut and drilled 6mm steel place with original "clutch" centre mounted to lock the transmission input shaft.
Original GS450h complete propshaft.
BMW 530e battery pack - all cells within a few mVs - circa 348V in total.
Teensy for BMS
Please let me know if you require any additional pics.
Price £3,000 for the lot.
I'm based in Oxted, Surrey, UK
Teensy for BMS
