Land Rover Series 3 - Leaf Powered
Posted: Wed Feb 01, 2023 12:34 pm
Hi all, new member here today.
Im currently in the middle of a total nut and bolt resto of a 1981 Land Rover series 3, 109 LWB.
Ive a new chassis arriving any day, and so I can start the rebuild.
Ive been scouring various forums, youtube etc and here is my current "plan".
Leaf motor/inverter, with adapter plate to connect a propshaft. That prop drives a divorced LT230 transfer box, which in turn drives all 4 wheels.
To improve range and reduce stress on front axle, I plan to fit a 2wd/4wd selector the LT230, in conjunction with free wheeling hubs. So 95% of time it will run RWD.
I was thinking of a resolve controller, but Im learning more about the Zombie VCU, and has me interested to say the least. In fact Im talking to someone that can provide most of this kit.
Ratios will be 1.6 in the transfer box, standard 4.7 in axles. I think this will work.
Not sure yet on battery size, but prob around 40kwh. More if I can afford it!
The areas still unsure about:
1. Brakes. My LR has non-servo 11inch drums all round. Many seem to keep them as the regen helps massively.
2. Heating - this I am not sure at all about yet.
3. Display - need to understand options for displaying battery %, range, drive status (n, d, r) etc.
4. Steering..i have no power assisted steering at present. Do I need this, not sure.
Im a little anxious about the setup of ev stuff, but confident enough to give it a go.
Thats me, so thx for the add, and hopefully I can learn a lot here, and contribute as I go.
