Leaf based 4x4 conversion... s
Posted: Mon Jan 30, 2023 12:29 pm
Hello forum.
I am about to start a project based around leaf equipment. A little vague at this point as it could go either way between a L200 (Triton Missile) known as the, Long Range Pony, or a Landrover Discovery 2 aka Discoblue. More accuratly this could be a game of which one first.
The Disco is mine and my best mates it is often is my daily driver when its working (Max 50 mile one way with charge available at work). Capable of Southam (nr Coventry) to Wrexham (circa 100 miles) would be the ideal though this is an infrequent journey. This is also used for off roading/greenlaning/camping ect.
The l200 is currently a farm truck and registered accordingly. That would probably be used more like a test bed to see whether it suits mums needs of local trips to pickup feed/take goats to vets ect. Stretch goal with this truck would be towing livestock to the Royal Cheshire show 37 miles away.
I think regardless of which vehicle I would start with baby steps and look at the approach Damien Maguire has put forward of using smaller packs from hybrids and then increasing battery capacity from there. I might have access to some Lithium batteries to get me going.
Outline so far is...
160Kw leaf inverter/motor stack. (I want to go for best performance for the off road purposes).
Zombieverter controller.
Retain donor vehicle gearbox/transfer case.
Charging... Yes.
Regen.. Yes with variable Regen rates.
Vehicle to house (I think this means chademo is the only current option for this).
On vehicle Solar charging. Farm truck to test this to influence whether solar charging could work for wild camping 4x4 expedition stuff. Park up and charge the go for a bit more.
4x4 Winch... Hand winch as backup.
I think that's all I can think of for now.
If anyone's read this far, thank you. Any comments/advice would be welcome. Im a knats whatsit off stopping just thinking about these things and buying some parts and getting into it.
DJ
Charging... Yes.
DJ
