ZEVA BMS24 System
Posted: Tue Jan 24, 2023 6:31 am
by KimchiKimKim
Awhile back I made a bunch of BMS24 units for a project that has to monitor a ton of parallel groups. I ended up selling the battery pack and dropped it to 96 cells so I have a ton of extra BMS units left over. Since they are based on the hard-to-find LTC6802 IC I hand-calibrated and assembled them using a fluke as a reference. Different die revisions of the LTC BMS ic cause slight drifts to the voltage sense stored in registers! I don't have thermistors to test the temp sensing but I assume that it would work perfectly with the recommended sensors as per the user manual as I didn't change anything about that side of the board.
I 3D printed the enclosures using high temp ABS
I conformal coated the LTC ic to keep ingress from shorting the tiny leads together but these are NOT waterproof!
Even though I calibrated and tested every single unit. due to the safety nature of a BMS its UP TO THE USER to properly install the unit - for this reason, I can't provide any sort of warranty or support
I changed the layout and schematics to use parts that are easier/possible to source but the functionality is the exact same.
I have a total of 20x units for sale. If you are interested in more than a few (4 units) I would be happy to entertain offers.
They come with the terminal-style connectors shown in the pictures
Looking for $250 each BMS24 Unit.
I am still working on sourcing parts for EVMS V3s but I plan on selling some later.
Re: ZEVA BMS24 System
Posted: Tue Jan 24, 2023 8:33 am
by johnspark
Have you or are you going to create the Zeva current sensors?
I have bought the Zeva system for my car to install once I get to that stage, so I am very glad you have created these items
Posted: Tue Jan 24, 2023 8:34 am
by johnspark
PS: i love the LED you have added
Posted: Tue Jan 24, 2023 6:19 pm
by KimchiKimKim
johnspark wrote: ↑Tue Jan 24, 2023 8:33 am
Yes, I will. These require a complete redesign since the current sensor used is extremely old and very difficult to buy in any sort of quantity. I understand the CAN protocol pretty well so it shouldn't be too much work but since I don't need one for myself I haven't spearheaded the project unless there is interest in others for me to sell them.
Posted: Tue Jan 24, 2023 9:38 pm
by johnspark
Ok well you have orders for 3 from me when you have the time,
Kind regards,
Posted: Tue Jan 24, 2023 11:50 pm
by KimchiKimKim
johnspark wrote: ↑Tue Jan 24, 2023 9:38 pm
Kind regards,
PMed
Posted: Thu Feb 02, 2023 8:42 pm
by johnspark
KimchiKimKim, I love the overall design of these boards, (thank you Ian Hooper). But I have never been keen on the terminal connector with the screws only a mm away from each other. A potential short circuit could occur. Do you know of a different connector to the black ones that have say crimped ones so that there is more plastic insulation between wires?
Posted: Sun Feb 05, 2023 11:19 pm
by KimchiKimKim
johnspark wrote: ↑Thu Feb 02, 2023 8:42 pm
The best way to fix concerns like that is simply with a wire ferrule crimp. I was going to replace them with some crimpable TE superseal connectors, but wiring this way is so much easier.
Posted: Mon Feb 06, 2023 3:41 am
by johnspark
Ah do you mean bootlace ferrules? that fixes stray wire strands, there would still be the issue of the screws 1mm apart. Crimpable TE superseal connectors sounds interesting. I would be happy to pay more for it.
Kind regards.
Posted: Mon Feb 06, 2023 4:37 am
by KimchiKimKim
johnspark wrote: ↑Mon Feb 06, 2023 3:41 am
Kind regards.
I could help but it depends on how many you want to purchase.
Posted: Mon Feb 06, 2023 4:45 am
by johnspark
So for my first car I only need those 3 current BMS modules so probably not enough for these superseal connectors...
Posted: Mon Feb 06, 2023 5:01 am
by johnspark
So for my first car I only need those 3 current BMS modules so probably not enough incentive for you to invest in these superseal connectors...
Posted: Mon Jan 01, 2024 11:34 pm
by KimchiKimKim
Dropping price to $175 a unit
Posted: Thu Apr 18, 2024 5:28 pm
by Tito
Hi! Messaged you on eBay.
Just curious, will these work with the ZEVA BMS directly or do they need reflashing? It’s for expanding a battery system currently equipped with the V2 system (but I think they allow reflashing to V3) I would need 7 units. I will be doubling the 10 battery modules to 20 but I actually have 14 extra modules so there is some wiggle room for me. Thank you
Posted: Fri Apr 19, 2024 6:55 am
by KimchiKimKim
Tito wrote: ↑Thu Apr 18, 2024 5:28 pm
Hello! These are ready to work in stock EVMS V3 but I'm pretty sure that V2 system use a different CAN bus protocol so I cannot confirm.
Posted: Fri Apr 19, 2024 10:28 am
by Tito
Ok. I know about the different protocol but I'm positive the EVMS can be reflashed to V3. If not I'll source a V3 or have one made as they are open source now. But i'll take care of that.
Can you do a good deal for me with shipping 7 of them to the Netherlands?
Posted: Sat Apr 20, 2024 3:08 pm
by KimchiKimKim
Tito wrote: ↑Fri Apr 19, 2024 10:28 am
Private messaged
Posted: Wed May 22, 2024 11:39 am
by D@F
Hi TITO,let me know if you do the uprage test on a V2 systeme , i'm in the pretty same situation as your.
Posted: Wed Jun 12, 2024 7:34 pm
by Tito
Sorry bit late… not to active here and just browsed some info and came across this.
I just got the (half) of the boards set up in a temporary setup in the boot of the car with the complete V3 system which I bought from the seller. Works perfectly fine and is a very nice upgrade from the somewhat outdated V2
adding the rest of the boards to the identical battery this weekend and balance the packs for a 2 string system and fit it under the car.
I still have the V2 system for a home solar battery pack (I have 4 battery modules (10kwh) extra that I cannot fit). I pulled the firmware from all the V2 stuff so I have a backup. Need to check the schematics of the V3 to see if the pins match the V2 core. The V2 has the current sensor connected directly to the core which I did not think about. So currently waiting on a PCB and the components and I’ll see if I can add it myself to the V3. Doh.
You can try for yourself to upgrade to the V3 system as I don’t think I’ll work on it anytime soon. I can send you the V2 firmware but I guess you could try to pull it yourself if you can program it too. I don’t think it appreciated that I spread the V2 firmware around the web.
I have the V3 stuff compiled too so I can mess with the can baud rate, as I think that could be the only difference.
The monitor won’t work for sure. So need to figure that out too as it can not be upgraded to V3.
Long story short: I’m no further than you at this moment.
Posted: Tue Aug 06, 2024 10:18 pm
by KimchiKimKim
Im slashing prices to $150 a unit.
I designed a new BMS that I plan on commercially selling that is compatible with the ZEVA system (same CAN bus format) but uses ICs that I have a 10 year commitment on so I no longer have any real use for these.
Posted: Tue Sep 24, 2024 7:14 am
KimchiKimKim wrote: ↑Tue Aug 06, 2024 10:18 pm
Hi
I am interested in getting 5x 24S modules if you stil have them. Let me know of the price (shipping) and availability on PM.
I am located in Slovenia EU.
