Increasing SNR
Posted: Mon Jan 16, 2023 7:46 am
To increase the smoothness and reduce drive train noise I'd like to make better use of the dual ADCs in the STM32.
I'd like to extend the ADC (anain) module to use both ADC simultaneously. So the list of analog inputs is distributed over both ADCs
So throttle1 is sampled by ADC1, throttle2 by ADC2, udc ADC1 and so on. I think it must be an even number of channels so that both ADCs finish at the same time. First advantage is doubled throughput, second advantage is adjacent channels are sampled simultaneously, most of all il1 and il2. I'd even consider weaving those two between the other channels so they get sampled more often
Be aware that ADC2 cannot use DMA independently of ADC1. It uses the upper 16 bits of the ADC data register.
Now that both ADCs are running I'd also oversample the resolver. Like sin on ADC1, cos on ADC2, both sampled 4 times (or just 3 if the first sample is noisy again). And again simultaneously.
In FOC I'd try running the forward transformation 3 times (ilx_1-3) and take the average or median of the result. I think that can be more useful than filtering the AC values
ANA_IN_ENTRY(throttle1, GPIOC, 1) \
ANA_IN_ENTRY(throttle2, GPIOC, 0) \
ANA_IN_ENTRY(udc, GPIOC, 3) \
ANA_IN_ENTRY(tmpm, GPIOC, 2) \
ANA_IN_ENTRY(tmphs, GPIOC, 4) \
ANA_IN_ENTRY(uaux, GPIOA, 3) \
ANA_IN_ENTRY(il1, GPIOA, 5) \
ANA_IN_ENTRY(il2, GPIOB, 0)
ANA_IN_ENTRY(il1_1, GPIOA, 5) \
ANA_IN_ENTRY(il2_1, GPIOB, 0)
ANA_IN_ENTRY(il1_2, GPIOA, 5) \
ANA_IN_ENTRY(il2_2, GPIOB, 0)
ANA_IN_ENTRY(il1_3, GPIOA, 5) \
ANA_IN_ENTRY(il2_3, GPIOB, 0)
