I was watching Damien Maguire latest video https://www.youtube.com/watch?v=qjh6rvFDR-U in which he talks about using low[ish] capacity packs from an OEM.
He talks about combining multiple packs if you need greater capacity.
Is it as simple as just joining them in parallel? In my mind, if there is any difference in voltage between the packs, things will get fruity so how should it be done?
Thanks,
Andy.
Combining multiple OEM batteries = How best? [SOLVED]
- acollins22
- Has thanked: 9 times
- Been thanked: 6 times
- Has thanked: 74 times
- Been thanked: 299 times
Re: Combining multiple OEM batteries = How best?
Make sure they're the same voltage before paralleling. I keep my parallel connection off with contactors when not driving or charging.
VW Beetle 2003
Outlander front generator
Outlander charger
3x Golf GTE batteries
Chademo Charging
Outlander water heater
Outlander charger
Chademo Charging
- acollins22
Thanks Bigpie.
Does your system do any voltage checks before closing the contactors?
Cheers,
Andy.
Cheers,
Andy.
Re: Combining multiple OEM batteries = How best? [SOLVED]
Nope. Probably should for extra caution. I just manually checked first couple of times
VW Beetle 2003
Outlander charger
Chademo Charging
Outlander charger
Chademo Charging
- acollins22
