Page 1 of 5
can id´s 4 Gear Selector
Posted: Fri Jan 13, 2023 8:46 pm
by medolino
Hi, does anyone happen to have the can bus ids for the jaguar or land rover gear selector, am testing whether it would be possible to make them usable for the LDU
Best regards
Re: can id´s 4 Gear Selector
Posted: Fri Jan 20, 2023 4:06 am
by Bratitude
medolino wrote: Fri Jan 13, 2023 8:46 pm Image
Best regards
https://savvycan.com/ + a due and im sure you'll be off to the races
Posted: Sat Jan 21, 2023 4:42 pm
by medolino
that´s what i find out
die anderen pins hab ich leider noch nicht herausgefunden
to the can bus messages, I have found the following so far
0x02c 0x00 0x00 0x09 0x00 0x00 0x00 0x00 0x00 rising the Knob
0x02c 0x00 0x00 0x10 0x00 0x00 0x00 0x00 0x00 lower the Knob
0x02c 0x00 0x00 0x00 0x40 0x00 0x00 0x00 0x00 unlock the Knob to spin
all of that, every 100ms
Posted: Sat Jan 21, 2023 6:50 pm
What model year is the part from?
Have you had it working outside the car with just sending those can bus commands?
Posted: Sat Jan 21, 2023 8:22 pm
by medolino
the part is from a Jaguar f-pace, production year 2018, is the same as in Range Rover, yes it works outside the car
Posted: Sat Jan 21, 2023 8:56 pm
Very cool, but the light does not come on on the position?
Can you rotate the knob to select other positions, it should be easy to decode the feedback of that.
Posted: Sat Jan 21, 2023 9:24 pm
by medolino
to rotate the knob, i must send every 100ms this code 0x02c 0x00 0x00 0x00 0x40 0x00 0x00 0x00 0x00, to unlock, but nothing Receives on Savvy
Posted: Mon Jan 23, 2023 8:45 pm
by nkiernan
medolino wrote: Sat Jan 21, 2023 9:24 pm to rotate the knob, i must send every 100ms this code 0x02c 0x00 0x00 0x00 0x40 0x00 0x00 0x00 0x00, to unlock, but nothing Receives on Savvy
I've been looking at a Jaguar XK rotary gear selector which has the EPB and Start/Stop button. This will be an older unit but I must test your CAN data above to see if it responds.
Believe this is the correct pinout for my unit. What connector detail is on your unit? Could it be that it needs a signal like wake-up or P/N etc before you see any more CAN data?
Posted: Mon Jan 23, 2023 8:57 pm
by nkiernan
I saw a few of these units and wondered if they tested all functionality but doesn't look to be. But for the basic testing they do, look to be 6 wires minimum to the connectors:
https://www.aliexpress.com/item/1005004 ... pt=glo2deu
Posted: Mon Jan 23, 2023 10:04 pm
by medolino
I think it's the same message for all models
Posted: Mon Jan 23, 2023 10:12 pm
nkiernan wrote: Mon Jan 23, 2023 8:57 pm I saw a few of these units and wondered if they tested all functionality but doesn't look to be. But for the basic testing they do, look to be 6 wires minimum to the connectors:
I got one of those on the way so hopefully can add some info soon.
Posted: Wed Jan 25, 2023 11:32 am
I got the tested.
Turns out the Yellow wire, ignition, is a switched 12V it raises and lowers the older style Jaguar knob, large connector.
Posted: Fri Jan 27, 2023 5:03 pm
Guess there is some form of check sum in byte 5
This is for raised and P illuminated, byte 4 is cyclising counter, message id 0x02C
1E	0	2F	52	0	21	0	80
1E	1	2F	53	10	BC	0	80
1E	2	2F	54	20	6	0	80
1E	3	2F	55	30	9B	0	80
1E	4	2F	56	40	6F	0	80
1E	5	2F	57	50	F2	0	80
1E	6	2F	58	60	48	0	80
1E	7	2F	59	70	D5	0	80
1E	8	2F	60	80	BD	0	80
1E	9	2F	61	90	20	0	80
1E	10	2F	62	A0	9A	0	80
1E	11	2F	63	B0	7	0	80
1E	12	2F	64	C0	F3	0	80
1E	13	2F	65	D0	6E	0	80
1E	14	2F	66	E0	D4	0	80
1E	15	2F	67	F0	49	0	80
Also found some interesting ones with same check sum but different message info.
1E	0	2F	40	80	FB	1	0
1E	0	2F	41	0	FB	2	0
Posted: Sat Jan 28, 2023 5:12 pm
by medolino
do you have a log file, would like to analyze the whole thing
to turn the nightlight ON is id 0x244, 0xF7 0x40 0x00 0x00 0x00 0x00 0x00 0x00
OFF is id 0x244, 0x00 0x40 0x00 0x00 0x00 0x00 0x00 0x00
Posted: Sat Jan 28, 2023 6:54 pm
https://github.com/Tom-evnut/Land-Rover-Gearknob
Here are the logs I took of it connected to the tester.
Posted: Sat Jan 28, 2023 10:09 pm
by medolino
Many thanks for the effort, try to pick up the messages from the tester, not from the Knob, which messages come from the tester
Posted: Sat Jan 28, 2023 11:04 pm
only the 0x02C is the tester. Knob is the other ID.
Posted: Wed Feb 01, 2023 10:41 pm
by LRBen
I've figured out most of the pinout for the 12 pin connector:
1. 12v main feed
2. Ign
3.
4.
5. Can H
6. Can L
7.
8.
9.
10.12v
11.
12. Gnd
On mine once I connect the ignition I get messages on the canbus and the backlight. ID 0x312 at about 20ms intervals. Canbus log attached.
Sending the messages to raise and lower the knob seems to have no effect, similar with playing back logs from Tom. But possibly due not having whatever pin 4 is attached.
Posted: Wed Feb 01, 2023 10:46 pm
You possibly have another version.
What build year is yours?
The Jaguar knob I have, the one with the park brake and other switches also send 0x312. I will upload the captures to the github.
I have not looked at the older knob log to figure out what ids are from my chinese tester and which are from the knob.
Posted: Wed Feb 01, 2023 11:24 pm
by LRBen
Not sure on the year, but model number is BH42-7E453-AJ.
I did have success playing back the Gen 1 Logs with 0x312. Raises the knob, lets me rotate it, changes lights, but doesn't lower again, even playing back awake lower knob.
Edit: looks like 0x3F3 is the only message needed to unlock the knob and change the lights. 0x299, 0x2A0, 0x422 also look like they came from the tester but dont seem to do anything, with only 0x312 coming from the gear selector. It's possible they have something to do with raising and lowering the knob though.
Posted: Thu Feb 02, 2023 9:17 pm
by LRBen
Looked through the canbus logs and figured out the rough patterns. These are the two important messages from what I can tell.
0x3F3 ID from Tester to gear selector
Byte
0. 5C in park, 7C for not parked
1. 66 in park, 24 in R, 25 in N, 24 in D
2. Cycling value in any state, 00, 01, 02, 03, 04, 05, 06, 07, 08, 09, 0A, 0B, 0C, 0D, 0E,
3. Cycling depending on gear.
     In park 82, 83, 86, 87, 88, 89, 8A, 8B, 8C, 8D, 8E, 8F, 90,
     In R: 03, 04, 05, 06, 07, 08, 09, 0A, 0B, 0C, 0D, 0E, 0F, 10, 11
     In N: 04, 05, 06, 07, 08, 09, 0A, 0B, 0C, 0D, 0E, 0F, 10, 11, 12
     In D: 06, 07. 08, 09, 0A, 0B, 0C, 0D, 0E, 0F, 10, 11, 12, 13, 14
4. FF in park, FE in R, FD in N, FB in D
5. 7F in park, FF in not parked
6. 00 in park, 01 in R, 02 in N, 04 in Drive
7. 80 in park, 00 in not parked
0x312 from gear selector
Byte
0.   00 at all times
1. 20 when locked, 10 when unlocked
2.  8F in park, 8E in R, 8D in N, 8C in D, 88 in S
3. Cycling depending on gear state.
4. 00 at all times
5.FF at all times
6. 00 at all times
7. Cycling
        In Park 00, 01, 02, 03, 04, 05, 06, 07, 08, 09, 0A, 0B, 0C, 0D, 0E,
        In R 10, 02, 03, 04, 05, 06, 07, 08, 09, 0A, 0B, 0C, 0D, 0E, 0F
        In N. 10, 11, 03, 04, 05, 06, 07, 08, 09, 0A, 0B, 0C, 0D, 0E, 0F
        In D 10. 11, 12, 04, 05, 06, 07, 08, 09, 0A, 0B, 0C, 0D, 0E, 0F
        In S 10. 11, 12, 13, 14, 15, 16 08, 09, 0A, 0B, 0C, 0D, 0E, 0F
Posted: Sun Feb 05, 2023 11:42 am
by nkiernan
LRBen wrote: Wed Feb 01, 2023 10:41 pm On mine once I connect the ignition I get messages on the canbus and the backlight. ID 0x312 at about 20ms intervals. Canbus log attached.
Model number on mine is BW83-7E453-AC and I get the same result as you. Playing back some of the different logs raises the knob, allows it to rotate, changes light between P-R-N-D but doesn't lower the knob in any. The knob raised on the first playback and stayed there.
Posted: Sun Feb 05, 2023 3:34 pm
by LRBen
nkiernan wrote: Sun Feb 05, 2023 11:42 am Model number on mine is BW83-7E453-AC and I get the same result as you. Playing back some of the different logs raises the knob, allows it to rotate, changes light between P-R-N-D but doesn't lower the knob in any. The knob raised on the first playback and stayed there.
Haven't figured out how to get the knob back down yet either. What wires do you have to the connector? I'm thinking potentially whatever is on pin 4 is somehow important, since canbus messages alone are not enough to lower it it seems.
Posted: Sun Feb 05, 2023 3:48 pm
To lower the older knob, remove the ignition power.
Posted: Sun Feb 05, 2023 3:50 pm
by medolino
tom91 wrote: Sun Feb 05, 2023 3:48 pm To lower the older knob, remove the ignition power.
doesn't work on the newer ones
