Page 1 of 1
VW Can Log with Engine running
Posted: Thu Dec 15, 2022 2:50 pm
by Bigpie
Does any one happen to have a can bus log from a VAG car engine can bus with the engine not running and then starting it?
While I have no dash warnings, I'm not convinced my ABS is working as it should and I wasn't smart enough to take a log before removing the engine.
Re: VW Can Log with Engine running
Posted: Thu Dec 15, 2022 3:33 pm
by arber333
Bigpie wrote: Thu Dec 15, 2022 2:50 pm Does any one happen to have a can bus log from a VAG car engine can bus with the engine not running and then starting it?
Yeah... i also made a mistake.
After i pulled engine from Mazda ABS was working as before just on 12V. But some idiot (wonder who) went and cut ECU cables which were probably supplying some signals to brake booster or maybe GND level...
Posted: Thu Dec 15, 2022 4:48 pm
by Bigpie
The ABS is broadcasting it's own can messages, so I'd assumed it was working. Had a colder winter this year and ice so far so was able to test and lock the wheels up.
I'll consult the wiring diagram incase I've missed something obvious.
Posted: Thu Dec 15, 2022 5:34 pm
by Doig5710
What sort of spec vehicle? I have a 2007 passat manual diesel 4wd or a 2009 A4 fwd cvt I can get logs from this weekend if you give me a good description of how to lol I have a working savvycan as well.
Both cars do have engine fault codes but abs and traction control works fine in both
Posted: Thu Dec 15, 2022 6:34 pm
by Bigpie
2003 Beetle, but don't think they change the messages that much. I'm not sure where you could easily access though on those cars I'll have to consult Google
Posted: Thu Dec 15, 2022 9:18 pm
by johu
Just realized I took one single log file before pulling the engine. Hope it's of some use
Posted: Fri Dec 16, 2022 8:47 am
by golfdubcrazy
on the mk3 golfs the ABS was completely independent , on the mk4 golf (same as the beetles) the ABS should still be completely independent its only if you have a ESP where it would listen for engine information (rpm, torque) to then send out torque limitations (when required).
Posted: Fri Dec 16, 2022 9:31 am
by Bigpie
I do have ESP, but I'm sending the RPM, I think I might be missing the torque though. Thanks for the log, will have a look :D
I notice on your log for 0x288
Which I'm not replicating, I need to navigate the german in the DBC and experiment when we get ice again.
Posted: Sun May 05, 2024 4:32 pm
by RetroZero
DId you get your ifon from the log, or do you still need one. I have a Golf VI petrol...
Posted: Mon May 06, 2024 6:06 am
by Bigpie
Thanks. I don't need one. I verify my ABS is working over the winter just gone
Posted: Fri Aug 02, 2024 10:36 pm
by golfdubcrazy
as far as i remember the ABS works without many additional canbus messages,(defiantly standalone on the mk3 golfs) the ESP sends out max torque request to the ECU which you don't have so just getting ignored. i cant remembered if it looks for a reply from the ECU.
so your abs should work, your ASR might and ESP probably not doing anything. would be a nice add on to the inverter to read the signal and reduce max torque at the wheels when needed.
Posted: Sat Aug 03, 2024 11:25 pm
by golfdubcrazy
here are the messages the abs sends
