Mini-VCU Based Stm32-VCU?
Posted: Wed Dec 14, 2022 1:15 am
Hello All.
Inquiring to see if we can set some requirements for a 'Mini' Zombieverter.
I'm careful not to fork and crowd this space too much; but I seem to think that there's some space in the Stm32-vcu line for a non-toyota focused VCU, while still maintaining compatibility with the project as a whole.
I've been holding off this as the IO requirements were a bit difficult to make universal, but with Johannes and adding flex IO in the next release, It's becoming flexible enough to have universal IO.
Initial Ideas:
At least hoping this fork isn't frowned upon.
Initial Ideas:
- Leverage Zombieverter Schematics and BOM, maintaining Part designation # to aid troubleshooting/mods across lines
- 48 pin ECU using extremely cheap AliExpress ECU enclosure - https://www.aliexpress.com/item/32839361268.html
- Make footprint match 10cm2 limit for cheap JLCPCB assembly
- Use BOM items for JLCPCB Assembly service
- Downsize some SMD to 0602
- 2 layer board?
- Integrated ESP32 to align with other projects
