Page 1 of 1
Shunt needed with OI board?
Posted: Wed Dec 07, 2022 2:14 pm
by ardillolambo
Guys,
I'm panning using a custom digital dash board to display info such as speed, temperature and all that kind of things....can I get all that data from the OI inverter board or do I need a shunt resistor?
Re: Shunt needed with OI board?
Posted: Wed Dec 07, 2022 2:19 pm
by arber333
ardillolambo wrote: ↑Wed Dec 07, 2022 2:14 pm
Guys,
Hm... OI can output CAN data stream. But i dont know if you can directly use the DC current data. Maybe not really accurate...
Speed and temp info is there and can be slaved to CAN.
Posted: Wed Dec 07, 2022 4:42 pm
by johu
The DC current figure is as accurate as the current sensors are calibrated, That said it doesn't include miscellaneous currents like DC/DC, heater etc. Better source current from the BMS (or a shunt)
Posted: Thu Dec 08, 2022 5:56 pm
by ardillolambo
johu wrote: ↑Wed Dec 07, 2022 4:42 pm
Johu
Any particular shunt that you will recommend for a dual motor set up?
