Orion BMS - High Side Driver
Posted: Thu Dec 01, 2022 12:01 am
The Orion BMS uses low-side switches as output for the BMS but the max output is 100ma (not enough to drive anything serious). I made a board that solves this problem. Probably could save money and skip caps but I used them since my BMS is super far away from my 12v battery (across the car) to prevent high startup currents from browning out the 12v rail.
These Infineon switches can handle up to 8a cont. with an input voltage of anything from 5.5-38v so should work great with a 24v LV setup as well. They have short circuit protection as well (its really fast ~650us from fault to shutdown)
It's tested and works on my EV but I don't want to take responsibility for anything that could go wrong.
I packed everything you need to make it below.
hope that this can help someone out there!
