Show me your cooling and heating setup (i want to gather this for the wiki)
Posted: Mon Nov 28, 2022 1:43 pm
Hi folks,
It came up to my mind that it could be of great interest, if we'd have a coolong and HVAC threat. Not about Canbus integration or HV integration - how did you solve the mechanical part.
I invite everyone to show off your setup with a few pictures:
Component cooling:
- cooling setup for the components, what's connected?
- pump used, mounted where? Connected on ignition or smarter setup?
- filler neck used?
- did you use an expansion tank?
- dies your system bleed easily?
Heating:
- heater used
- where did you connect the hoses
- which filler neck did you use
- which expansion tank, if any, did you use.
Cooling:
-AC used
- how did you connect the new AC compressor to your car side hoses?
Component cooling:
- filler neck used?
Heating:
- heater used
Cooling:
-AC used
