SOLVED: GEN3 over Canbus, suddenly turning backwards
Posted: Mon Nov 28, 2022 1:09 am
I converted the GT86 to the GEN3 inverter controlled via CAN only and everything works just fine, except for one thing: when the RPM comes down to quickly the inverter somehow commands the motor not to stop at 0 RPM - it starts to turn backwards until 2500rpm. I then can push the acceleration pedal to get it to stop. It happens only in neutral gear or in reverse. In third gear this does not happen.
Somehow the inverter misses the 0 RPM point if it happens to quickly.
Anyone else experienced this?
