Free Kona 64kwh BMS for reverse engineering
Zapatero
Has thanked: 27 times
Been thanked: 58 times
Post by Zapatero »
I have the BMS including the slave modules and the wiring harness. I'd like to donate it to someone who wants to play around with it.
Any's volunteers :twisted:
paaa
Been thanked: 13 times
Re: Free Kona 64kwh BMS for reverse engineering
Post by paaa »
If no-one else takes it it I will , would like to workout if it's possible to run. A kona pack with less than the full number of modules.
addvalue
Has thanked: 7 times
Post by addvalue »
I'm interested, already using re-use kona modules to build affordable electric propulsion kits for small boats. Would be great to investigate the possibilities of re-using (some of) the bms components too.
mattiasclaesson
Post by mattiasclaesson »
Still available? Was looking for a way to safely test the integration of the battery emulator project support for Hyundai/Kia batteries.
https://github.com/dalathegreat/BYD-Bat ... -For-Gen24
Tachopis
Has thanked: 6 times
Been thanked: 14 times
Post by Tachopis »
Hi there, I'm interested in this battery pack, any update on this?
