LDU parameters showing reverse when in forward
- Roadstercycle
- Has thanked: 3 times
Trying to make sense of what's happening here. When motor going forward it shows reverse on parameters page on laptop. When in reverse it shows forward. Even trying to use the button swapped setting on perimeters page it shows the same thing. Should I just ignore it or is there a reason or a fix? I do refresh the page after each change to let the new input show up. I'm using 5.20 firmware.
Re: LDU parameters showing reverse when in forward
I'd just ignore it. Mine has always been swapped.
- Boxster EV
- Has thanked: 35 times
- Been thanked: 26 times
How have you found the new firmware?Roadstercycle wrote: ↑Thu Nov 24, 2022 7:29 pm Trying to make sense of what's happening here. When motor going forward it shows reverse on parameters page on laptop. When in reverse it shows forward. Even trying to use the button swapped setting on perimeters page it shows the same thing. Should I just ignore it or is there a reason or a fix? I do refresh the page after each change to let the new input show up. I'm using 5.20 firmware.
- Roadstercycle
5.20 firmware here. https://github.com/jsphuebner/stm32-sin ... /v5.20.R-2
- catphish
- Has thanked: 94 times
- Been thanked: 179 times
The SDU has always run backwards, so I guess the LDU is the same. Forward and reverse function exactly the same, so just ignore it.
