LDU parameters showing reverse when in forward
Posted: Thu Nov 24, 2022 7:29 pm
by Roadstercycle
Trying to make sense of what's happening here. When motor going forward it shows reverse on parameters page on laptop. When in reverse it shows forward. Even trying to use the button swapped setting on perimeters page it shows the same thing. Should I just ignore it or is there a reason or a fix? I do refresh the page after each change to let the new input show up. I'm using 5.20 firmware.
Re: LDU parameters showing reverse when in forward
Posted: Sat Nov 26, 2022 3:36 pm
by jon volk
I'd just ignore it. Mine has always been swapped.
Posted: Sun Nov 27, 2022 10:50 am
by Boxster EV
Roadstercycle wrote: ↑Thu Nov 24, 2022 7:29 pm
How have you found the new firmware?
Posted: Wed Dec 21, 2022 8:54 pm
by Roadstercycle
Posted: Wed Dec 21, 2022 9:18 pm
by catphish
The SDU has always run backwards, so I guess the LDU is the same. Forward and reverse function exactly the same, so just ignore it.
