Toyota's electric power steering motor
Posted: Sun Nov 20, 2022 1:49 am
Hey everyone. Would need some kind of help here.
I recently replaced the electric DC motor, attached to a Corolla steering column, and instead of throwing it away, I just thought, it would be helpful in my planned electric bicycle conversion.
The electric motor, is rated 25VDC, without any information about it's amperage capacity.
It has three thicker wires ( which I believe, are for the 25V input, colored, red, black, and white; while there are four tiny wires(red, blue, yellow, and black), which goes to the steering ECU.
Can someone pls point me to how I can at least, bench test this motor, without the aid of it's ECU?
Here is what I have done so far:
Jumped the black/white thicker wires of the motor, and applied a 48VDC power supply to it, without making any attempt to run.
Because it didn't ran, I thought, hey, maybe I could jumper the tiny black/blue/yellow wire connectors, to mimic the signal communication between the wires and ECU.
I have tried several times, to see if I could run the motor, on a bench, without the steering ECU as was in the car.
