LG Chem Lithium Ion 60.8v 2.6kWh (12 qty) - Los Angeles CA USA
Posted: Thu Nov 10, 2022 6:47 pm
Used
Harvested from Chrysler Pacifica, the LG Chem battery modules have excellent stability based on the proprietary separator technology. With the lightweight pouch design it makes it easy to change the designs according to customers' requirements. Each module is arranged in a 16s configuration providing 2.6kWh and rated at 200-400 amp continuos with 800 amp max discharge.
$600 per module for a total cost of $7,500
If less than 12 are desired please purchase through eBay listing: https://www.ebay.com/itm/265960096297?m ... media=COPY
Buyer responsible for arranging pick up from Pasadena, California (Los Angeles County) 91101
Capacity: 2.6Kw
Height: 14.25 Inches
Width: 8.00 Inches
Length: 6.25 Inches
Weight: 38.00 Pounds
Bolt Size: M6
Voltage nominal: 3.8V/Cell, 60.8V/Module
Charge voltage cut-off: 4.2V/Cell, 67.2V/Module
Discharging cut-off: 3.3V/Cell, 52.8/Module
Maximum Discharging Current (10 sec.):800 Amps
Note: Batteries have special HazMat shipping requirements. Buyer responsible for arranging shipping and pick up from Pasadena, CA 91101. These batteries are used and will have normal wear.
Capacity: 2.6Kw
Width: 8.00 Inches
Length: 6.25 Inches
Bolt Size: M6
