Page 1 of 1
Rate limiting server access
Posted: Fri Nov 04, 2022 10:10 am
by johu
Starting yesterday I noticed an excessive number of accesses from a specific IP address. They seemed to be downloading the entire forum or whatnot.
By the time I noticed it had been going on for 12 hours, the access log file had swollen to 700 MB instead of the usual 20 MB or so!
I have now implemented rate limiting. So if a given IP address makes too many requests within a certain time it will be completely blocked after a while.
Re: Rate limiting server access
Posted: Mon Nov 07, 2022 1:13 pm
by mjc506
Not a twitter/Elon IP was it? :)
Posted: Mon Nov 07, 2022 1:30 pm
by johu
Unless he moved the head quarters to Darmstadt, Germany, no ;) Was thinking maybe TOR exit node?
Posted: Mon Nov 07, 2022 1:37 pm
by mjc506
Posted: Wed Nov 23, 2022 1:24 pm
by janosch
Slight tangent:
Are forum & wiki dumps available actually (w/ user table reduced to nickname & PMs stripped out obviously)?
If it's easy to setup I would be interested to keep some local backups, otherwise we have to rely on archive.org if something ever happens to this website.
I noticed recently that for certain short search terms the forum search isn't producing the best results, so I have gone to google:
"site:openinverter.org BMS" to find short or specific terms.
Posted: Wed Nov 23, 2022 2:03 pm
by johu
I do a more or less weekly backup of the entire data base and web server content. It sits here on a raid5 array (3 disks)
Current configuration wouldn't allow a dump to be pulled externally, at least not without rate limit from the client side.
Posted: Thu Nov 24, 2022 8:16 am
by Scrappyjoe
Johu, I think it’s worth considering distributing backups between a small number of trusted members, who are known to the community. I have been in situations where forums just disappear when the admin loses interest or just ghosts. It’s a terrible loss, and sometimes the community never recovers.
Posted: Mon Nov 28, 2022 4:27 pm
by TheSilverBuick
Probably someone paranoid that with Damien's departure/hiatus that this forum will vanish off the internet.
Posted: Mon May 08, 2023 9:44 am
by Ammar
Please do not use RAID5 for anything you care about. RAID6 cost you just one more disk, and will save you a lot of agony.
Posted: Mon May 08, 2023 5:49 pm
by johu
Why?
