Anyone using Porsche Taycan modules on a conversion?
Posted: Sun Oct 16, 2022 11:41 am
by CrAzY_DrIveR
I am thinking of buying some for my car, but because of the bms they need to be cut with a grinder to access the individual cell voltages.
A small window may be a better alternative to cutting the complete side of the module.
What is your experience with these modules?
6S2P 120Ah
Re: Anyone using Porsche Taycan modules on a conversion?
Posted: Sun Oct 16, 2022 11:45 am
viewtopic.php?t=2002
A compatible controller for the bms.
Posted: Sun Oct 16, 2022 2:18 pm
by EV_Builder
Yes; there is. We can balance, read cell voltages and temperature.
(Everything supported by LG).
Posted: Sat Nov 12, 2022 1:24 pm
by CrAzY_DrIveR
This is just horrible to open, i understand why people just cut the complete side panel...
Posted: Sat Nov 12, 2022 1:47 pm
I am so confused why you are not using the CAN bus conversion module from EV_Builder?
This is opening a whole load of potential issues.
Posted: Sat Nov 12, 2022 4:31 pm
by catphish
If there's a slave BMS module in there, you should 100% use it. This will be much more reliable and much safer than trying to wire in your own cell taps.
Unfortunately a lot of people do seem to discard OEM slave modules though, because they want to use Orion BMS for CCS system compatibility, but unless you have a very good reason, you're better off not cutting them open!
Posted: Sat Nov 12, 2022 4:47 pm
catphish wrote: ↑Sat Nov 12, 2022 4:31 pm
Why that, you can easily programme gateqays to do the connections. Then again this all depends on end installer experience and capability.
I know many projects where the SimpBMS has been used in conjuction with many other systems. A customer is using ID3 battery with Nissan Leaf powertrain/charger with a Resolve Controller, and with my gateway and BMW I3 CCS.
Posted: Sat Nov 12, 2022 4:53 pm
by CrAzY_DrIveR
tom91 wrote: ↑Sat Nov 12, 2022 1:47 pm
how am i supposed to use this with a nissan leaf bms?
Posted: Sat Nov 12, 2022 4:57 pm
CrAzY_DrIveR wrote: ↑Sat Nov 12, 2022 4:53 pm
Why are you stuck with a Nissan Leaf BMS? People have swapped lead packs and added leaf packs to nissan leafs and all this info is public.
Are you using a full Nissan Leaf drivetrain in a new build or are you replacing a Nissan Leaf battery in a Leaf?
Posted: Sat Nov 12, 2022 6:25 pm
by CrAzY_DrIveR
Posted: Sat Nov 12, 2022 6:45 pm
CrAzY_DrIveR wrote: ↑Sat Nov 12, 2022 6:25 pm
Full Nissan Leaf or with a Resolve controller?
Posted: Sat Nov 12, 2022 6:48 pm
by CrAzY_DrIveR
Full Nissan Leaf, a complete car for parts so i'll be putting wiring, power steering, everything if i can.
Posted: Sat Nov 12, 2022 9:00 pm
by EV_Builder
If you are building a new car then why not ditch the OEM BMS?
Buy a CMC TPL with Blue BMS and OpenInverter Leaf motor controller.
Posted: Sun Nov 13, 2022 5:40 pm
by CrAzY_DrIveR
Your bms is perfect for most applications but i don't think it's good for my specific case.
openinverter will not control the leaf charger.
ZombieVerter will work with your bms and leaf charger but no leaf power steering and power brakes.
And also i'm in Poortugal we don't really swim in money around here (it's ruled by communists and socialists) so i use what i have...
To spend an extra 350+conectors on zombieverter and 460 on bluebms there goes more than one month salary,
i could have bought e2008 modules for the same total price and those modules are easy to open.
I think a little slave board inside each module should work, and with fuses because Damien said so.
If i'm wrong at least i learn something.
Posted: Sun Nov 13, 2022 6:24 pm
by EV_Builder
CrAzY_DrIveR wrote: ↑Sun Nov 13, 2022 5:40 pm
Ok, but its possible the lead BMS complains about the increased size of the battery.
And soldering those wires to your ready made board is quite the act so to speak!
Nice board btw!
Posted: Sun Nov 13, 2022 9:34 pm
by CrAzY_DrIveR
soldering is easy, desoldering was not a joke with the small window i almost destroyed the battery because the heat
travelled through the aluminium tape that i used to protect the cells.
That is why i had to cut the complete side and it was very easy.
The board is just a little easyeda pin to pin conection, let's hope it fits.
Posted: Fri Nov 25, 2022 10:36 am
by boekel
these 6s modules are also available without internal CMU's, why not use those... (for example in VW e-up)
Posted: Fri Nov 25, 2022 12:12 pm
by CrAzY_DrIveR
haven't seen any for sale, it's really about availability.
Could have bought a complete peugeot 2008 pack but it would have cost me an extra 1000e.
Posted: Sun Nov 27, 2022 2:53 pm
by boekel
I think
www.ecaraccu.nl still might have some unused 6s from e-up...
