advice on basic trial regen parameters
Posted: Wed Sep 21, 2022 9:13 pm
Hello Forum. Looking for some advice here please. I have set up basic trial regen parameters (I am using a Combi V8 board driven inverter) and try a basic regen with motor off load I can see the braking effect and reverse current but then I have to power down and restart the inverter to be able to run again, any clues please ?
Parameters..
Brake pedal pressed
Regen pot set at 0v or 5v makes no difference (need to sort pot use later)
pot2min 4095
pot2max 4095
SingleRegen set
brknompedal -30
brkpedalramp 5
brknom 0
brkmax 0
brkrampstr 10
brkout -10
Thanks in advance for any suggestions.
Parameters..
Brake pedal pressed
pot2min 4095
pot2max 4095
SingleRegen set
brknompedal -30
brkpedalramp 5
brknom 0
brkmax 0
brkrampstr 10
brkout -10
